Old Jan 02, 2013, 10:28 PM
egaus is offline
Find More Posts by egaus
Quadrophenia
egaus's Avatar
Seattle
Joined Mar 2009
Wow.
egaus is offline Find More Posts by egaus
Old Jan 02, 2013, 10:31 PM
viper522 is offline
Find More Posts by viper522
United States, FL, Palm Beach
Joined Jan 2011
DragonLink 2 mile attempt #1 - success!
2 miles out with DragonLink LRS (6 min 52 sec)
viper522 is offline Find More Posts by viper522
Old Jan 02, 2013, 10:39 PM
Eastcoast78 is offline
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
Mine was shipped today, EXPRESS should have it by Friday
Eastcoast78 is offline Find More Posts by Eastcoast78
Old Jan 02, 2013, 10:40 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
I need some help with the binding. I got a new RX (newest version), and Im using the old TX with the latest firmware.
I push the button as the turn the TX on, green light starts blinking, let it go and power up the RX. All light briefly turn on, then just the 'power' light stays lit. All others are off. It wont link. Any ideas? I tried the calibration procedure with no luck.
ashdec87 is offline Find More Posts by ashdec87
Old Jan 02, 2013, 10:53 PM
JohnVH is offline
Find More Posts by JohnVH
Qualified
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
Originally Posted by hendrnk View Post
I wouldn't leave the house without RTH function for long distance flights.
how far do you think you need a RTH function?
JohnVH is offline Find More Posts by JohnVH
Old Jan 02, 2013, 11:02 PM
Rick338 is offline
Find More Posts by Rick338
Joined Oct 2012
If you can't see it. You need RTH.
Rick338 is offline Find More Posts by Rick338
Old Jan 02, 2013, 11:12 PM
hendrnk is offline
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
Plus 1
hendrnk is offline Find More Posts by hendrnk
Old Jan 02, 2013, 11:13 PM
scrtsqrl is offline
Find More Posts by scrtsqrl
Just trying to get a nut.
scrtsqrl's Avatar
United States, VA, McLean
Joined Oct 2006
Gents,
What is the turn around time for an upgrade?
Thank you!
Originally Posted by JettPilot View Post
DRAGON LINK UPGRADES
Hi Everyone,
As a thank you for our early supporters, I am doing free firmware upgrades for all Version 1 Dragon Link systems. This is a Very nice upgrade, and will make your Version 1 Dragon Link system better than ever !! Some of the improvements you will see are:
Compatibility to fly without interference together with all - multiple UHF RC systems.
Much better resistance to interference from other sources such as flying in the city.
New features and even more reliable, trouble free operation.
Compatiblity with ALL new Version 2 Dragon Link equipment !!!
To get your free firmware upgrade, you must follow these simple instructions:
1. Send me ALL your Dragon Link Transmitters and Receivers ( Do NOT send your RC transmitter, Dragon Link antennas, or anything else ).
2. Put a NOTE inside the box with your full name and return address. Also let me know if you are having any problems with your system so that I can fix any issues.
3. Send me Return shipping cost to dragonlinklabs@hotmail.com via Paypal. Cost for return shipping will be 10 dollars to the USA. 25 Dollars Tracked International.
4. Send your System to:
Michael Bigelow
100 Giardino Drive
Islamorada, FL 33036
USA
Send the return shipping cost via PayPal to DragonLinkLabs@hotmail.com Systems with the shipping costs not paid will be held hostage and maybe even given away in the next contest
IMPORTANT NOTE - TRANSMITTER CHANGES
NOTE: When you receive your system back, your transmitter will operate differently, and the LED indications will be different. When you hold down the button and power on the system, you will be able to enter the following modes by releasing your button at different times. Here is the list, holding the button down durring power up and then releasing at:
2 - 7 Seconds: Micro Power Range test mode, LED will turn RED, and flash RED once button is released.
7 - 12 Seconds: Binding Mode, LED will turn GREEN, and flash GREEN once button is released.
12 - 17 Seconds: Calibration mode, LED will turn RED, and Flash RED and GREN once button is released.
17 Seconds or More: ID Change Mode, LED will turn OFF, And stay off once button is released.
NOTE: If you do not see the correct LED indication, you are not in the mode you want, try again !
You will need to do the following with EACH of your receivers in the order listed:
1. CALIBRATION:
You will also need to calibrte EACH receiver for 15 minutes by installing the jumper across the signal pins of channels 5 and 6, THEN powering them on with no antenna for 15 minutes. The tranmistter should be continuously running in the Calibration mode for this process with its antenna attached. The transmitter should be about 2 meters away from the receiver, no need to measure, just do not have it right against the RX for this process.
2. BIND:
Rebind ALL receivers to your transmitter after calibration. It is importnat to rebind each time the RC transmitter you are using is changed to a different one. Your transmitter is different than the one I tested your system with, if you do not rebind, it will not work correctly.
scrtsqrl is offline Find More Posts by scrtsqrl
Old Jan 03, 2013, 12:37 AM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
Well its not FPV or long range but heres my latest flown with DragonLink!
It will soon hit the skies for some long range FPV flights
Element 44x (1 min 40 sec)
chanyote66 is offline Find More Posts by chanyote66
Old Jan 03, 2013, 12:44 AM
flohio117 is offline
Find More Posts by flohio117
DroneWorksUSA.net
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
Originally Posted by Helishoen View Post
Mine dosen't rattle.... Yes failesafe is same button
Great video flohio ! Love the cloud work.
http://www.youtube.com/watch?v=jjz3OhMw0b4
Awesome vid Chris your vid went like my new vid lol.
Iconic X FPV Test flight its sick! w/crash. (5 min 5 sec)
flohio117 is offline Find More Posts by flohio117
Old Jan 03, 2013, 12:54 AM
chanyote66's Avatar
Joined Dec 2011
http://m.youtube.com/watch?v=T9C0Wo5cSqI
ya was just watching that! the quad looked better when i saw it in person
Chris
Old Jan 03, 2013, 01:15 AM
DroneWorksUSA.net
flohio117's Avatar
Joined Dec 2011
Lmao we'll this is a different new quad it's wayyyy faster and way more powerful. I still use my other one though.
Old Jan 03, 2013, 01:21 AM
chanyote66's Avatar
Joined Dec 2011
aaah... the "dont tell wife quad" no wonder you are entering the DL contest... got a fleet of multi rotors
Ill have to make a Video of my DragonLink Fleet... They are all flying wings now though
Chris
Old Jan 03, 2013, 01:48 AM
flylite is offline
Find More Posts by flylite
I Like Popcorn
flylite's Avatar
UK, Greater London, London
Joined Oct 2009
Hi,
All version 2 equipment will work together, no matter when it was purchased, no matter if firmware was updated or not, all V2 will work with any V2 TX or RX.
I only recommend against the BEC on the speed controller because many times it is not capable of powering the servos, and will cut out. The Dragon LInk receiver takes only a tiny amount of power, its the servos that you have to worry about. If you have no servos drawing power, then anything would power the Dragon LInk RC itself.
Thanks Mike! Happy New Year!
flylite is offline Find More Posts by flylite
Old Jan 03, 2013, 04:16 AM
marcin.gala is offline
Find More Posts by marcin.gala
marcin.gala's Avatar
Joined Jun 2010
Thanks Mike.Got it.
Now bind and when weather fine I will do test flights ,back asap with results.
Send me PM with address where to send back DL.I know it was somewhere here ,but can't find it ...1067 pages !...
Thanks for helping.Hope will all OK with new set.
marcin.gala is offline Find More Posts by marcin.gala
New Product Long Range UHF RC system now avail on STOCK thomasscherrer FPV Equipment 14070 Yesterday 02:17 PM
Wanted Scherrer UHF long Range or Dragon Link patrick21x FPV Equipment (FS/W) 6 Dec 24, 2015 03:50 AM
Yippee! Win a FREE Dragon Link UHF Long range RC system - BEST VIDEO contest for AUGUST !!! JettPilot FPV Talk 60 Aug 21, 2014 03:40 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
Yippee! Win a FREE Dragon Link UHF RC System - Video Contest JettPilot FPV Talk 63 Aug 02, 2011 10:52 PM
