Old Dec 07, 2011, 10:12 AM
teopbako is offline
Find More Posts by teopbako
Ikaruswannab
Joined Sep 2009
Originally Posted by lrrps View Post
I always fly FPV while seated with the radio TX on my lap, now is it safe with the DL.
I don't intend to make children anymore, just wanted to make sure there's no health hazard with this powerful device.
And the above needs a responsible answer.
teopbako is offline Find More Posts by teopbako
Old Dec 07, 2011, 10:43 AM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
This device isn't any more powerful (I believe) than most transmitters. The freq is nothing to worry about either. 2.4G would be more of a problem 'cause that's in the 'microwave' frequeny an I've not heard of 'sterile' fliers because of 2.4G radio usage. Fly and be happy. Actually, your cell phone is probably worse for you than the DL.
Vantasstic is offline Find More Posts by Vantasstic
Old Dec 07, 2011, 10:54 AM
HagayB is offline
Find More Posts by HagayB
Joined Mar 2009
Originally Posted by JettPilot View Post
Hi Frank,
We are actively working on this, I am actually doing some testing on this very thing today. Firmware will be soon, and it will be for both the TX and RX. I will have to do this here, but I will make it easy and fast for everyone. Here is how it will work, I will send a new Dragon Link, when the new one with update arrives, you send the old one back. This way no one is without thier Dragon Link, and no waits for it to cross in the mail.
Good news Mike,
I am following this thread having doubts whether I should order DL or not bc I fly with my friends most of the time,
Now my question is should I place the order today or wait for the updated bunch?
HagayB is offline Find More Posts by HagayB
Old Dec 07, 2011, 11:05 AM
Gustavovon is offline
Find More Posts by Gustavovon
Brasil, RJ, Rio de Janeiro
Joined Aug 2011
Guys, could i connect the the rssi from DL rx directly on the "voltage in" from a HK simple osd ?
Gustavovon is offline Find More Posts by Gustavovon
Old Dec 07, 2011, 11:45 AM
lrrps is offline
Find More Posts by lrrps
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
I'm trying to figure out how to power and connect servos to my receiver, the instructions on the DL site is for the old 9 channel receiver, I have the new 12 channel receiver, can someone help me pls.
Thanks.
lrrps is offline Find More Posts by lrrps
Old Dec 07, 2011, 11:46 AM
lrrps is offline
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
Thanks Lee.
Old Dec 07, 2011, 11:54 AM
eyesonsky is offline
Find More Posts by eyesonsky
eyesonsky's Avatar
Switzerland
Joined Jul 2010
Thanks.
Here http://www.rcgroups.com/forums/showt...3#post19530934
eyesonsky is offline Find More Posts by eyesonsky
lrrps is offline
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
OK, I measure each outer pin to ground (middle one is +) and found that all the pins facing the channel markings are connected to ground so i assume they are -.
Therefore the opposite pins are the signal, is that right?
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Thanks.
Look here: http://www.dragonlinkstore.com/v2/node/27 . Click on the tab labeled INSTALLATION, look for and click on the type of receiver you have. You should find the info you're looking for there.
Old Dec 07, 2011, 11:56 AM
lrrps is offline
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
Originally Posted by eyesonsky View Post
Thanks, I was right with my measurements too.
Old Dec 07, 2011, 12:22 PM
lrrps is offline
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
Thank you Lee.
Old Dec 07, 2011, 12:23 PM
gent96 is offline
Find More Posts by gent96
KJ6RCJ
gent96's Avatar
United States, CA, Elk Grove
Joined May 2010
Hi Frank,
If this ain't world class service, what kind of CS is this? Thanks, Mike. Looking forward to the updated firmware. You rock!!!
Gent
gent96 is offline Find More Posts by gent96
Old Dec 07, 2011, 01:29 PM
kenny_dilger is offline
Find More Posts by kenny_dilger
United States, IN, Evansville
Joined May 2001
I just received my Dragon Link. I will be testing and fine tuning my FPV setup on a vehicle before moving to the air. A few questions...
Is the dummy load the gold colored cap that is screwed onto the transmitter?
Also, what are the included resistors for? I am going to hook this up to my Hitec Eclipse and I assume they are for a feature I do not need.
Kenny
kenny_dilger is offline Find More Posts by kenny_dilger
Old Dec 07, 2011, 01:43 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Yes. Don't loose it. Never turn on the DL without either the dummy load or antenna attached...else risk harm done unto the DL rf deck.
Kenny
The resistor is needed for (mostly) Futaba radios to pull up the PPM signal high enough for the DL to use. Don't install the resistor unless it doesn't work without the resistor. Go to: http://www.dragonlinkstore.com/v2/ and click the INSTALLATION tab...select your Tx type and follow the instructions...
Old Dec 07, 2011, 01:49 PM
MK3 is offline
MK3
Find More Posts by MK3
MK3
Aerial Loitering
MK3's Avatar
Joined Sep 2011
I finally got my DOSD back and can see my RSSI again, now for a new problem. In my new Skywalker setup, I went 2 miles out and my RSSI was around 50-60%, and there were momentary drops below 40%
I had the exact same setup in my Easystar, but it used to get 70-80% RSSI during the same exact flight path.
The antenna is even set up much better in the SW, it goes to the edge of the wing and poles are vertical, with positive sticking UP.
The DragonLink RX is sideways inside the plane and is close to the DOSD board (similar to my Easystar setup). Already checked for any loose connections.
What sucks is I lost my dummy cap. Any troubleshooting techniques?
MK3 is offline Find More Posts by MK3
New Product Long Range UHF RC system now avail on STOCK thomasscherrer FPV Equipment 14035 May 24, 2016 08:18 AM
Wanted Scherrer UHF long Range or Dragon Link patrick21x FPV Equipment (FS/W) 6 Dec 24, 2015 03:50 AM
Yippee! Win a FREE Dragon Link UHF Long range RC system - BEST VIDEO contest for AUGUST !!! JettPilot FPV Talk 60 Aug 21, 2014 03:40 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
Yippee! Win a FREE Dragon Link UHF RC System - Video Contest JettPilot FPV Talk 63 Aug 02, 2011 10:52 PM
