Old Dec 25, 2012, 11:00 PM
redodedo is offline
Find More Posts by redodedo
HD FPV on a 4m glider
Canada, BC, Richmond
Joined Dec 2012
iS IT SAFE TO BUY A DRAGON LINK V2?? ALSO WHERE CAN I GET THE ORIGINAL DRAGONLINK???
redodedo is offline Find More Posts by redodedo
Old Dec 25, 2012, 11:49 PM
TimeTrave1er is offline
Find More Posts by TimeTrave1er
United States, CT
Joined Oct 2012
Originally Posted by polix View Post
i'd suggest doing a video of your binding process, your wiring etc, including the LEDs while you're trying to bind. do a narration while you're doing it. Upload to youtube or your site of choice and post it here, it will help greatly in other DL users helping to diagnose the problem.
Sometimes it's the little things that we miss, and something like a video would help immensely
That's a good suggestion. I just might have to do that.
I made some progress though I think.
My receiver light is solid red and blinking blue and green alternately. What does this mean? It only does this on chan 12 when I have my Naza's PPM port connected (x2).
What's going on here now? Solid red blinking green and blue...
EDIT: Problem appears to be in the "Trainer" menu of my Futaba 9chp Super. For some reason the Trainer options only include "Off" and "Inh". It is missing the "On" option. This is necessary to communicate controls through my Futaba to the Dragon Link via the trainer port. You can view the problem here if you want to see it your self:
Futaba 9chp Super Trainer Port problem with Dragon Link (1 min 18 sec)
Mike aka JettPilot is doing a great job giving me top notch support as well so Dragon Link is not at fault here.
TimeTrave1er is offline Find More Posts by TimeTrave1er
Old Dec 25, 2012, 11:53 PM
CrashAffinity is offline
Find More Posts by CrashAffinity
Crashaffinity on youtube
CrashAffinity's Avatar
Canada, AB, Calgary
Joined Nov 2012
good question, i haven't received my DL yet so when i get it and i'm having problems i'll be recording a video of me bashing a brick into my head while hitting buttons! of course i'll upload for all to giggle over
CrashAffinity is offline Find More Posts by CrashAffinity
Old Dec 25, 2012, 11:59 PM
redodedo is offline
Joined Dec 2012
anyone know where I can buy the original dragon link??? (not the v2)
Old Dec 26, 2012, 01:35 AM
United States, CT
Joined Oct 2012
try the classfields section
Old Dec 26, 2012, 04:27 AM
kefir is offline
Find More Posts by kefir
Poland Gdynia
Joined Feb 2009
Please help me because I send e-mail to the dragon link and do not get a reply: (
I sold my old dragonlink (I want to buy a new one) and the receivers have been me but they probably will not be compatible with the new dragon link what do I do?
These have 3pcs
And so recently I ordered and had to be compatible with the old transmitter (but is not)
kefir is offline Find More Posts by kefir
Old Dec 26, 2012, 08:29 AM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
You've got me on the LEDs. I've never seen what you're describing...so let's back up a little.
1. Make sure you radio is in PPM mode...not PCM or anything else.
2. When you power up your DL Tx, what color(s) is the DL LED on the Tx? It should be ready then quickly turn solid green. Red indicates power but no PPM. Solid green indicates good PPM into the DL.
3. Describe the EXACT steps you are doing when you calibrate and then when you bind. Don't skip anything...list it exactly like you're doing it.
I use my 9X with DL and Naza via the PPM line and it works perctly. YOU HAVE TO be able to rearrange your channel mapping to match what the Naza is expecting. If you can't channel map your Tx then you can't use the PPM on the Naza. This IS a Naza limitation, not a DL limitation.
Vantasstic is offline Find More Posts by Vantasstic
Old Dec 26, 2012, 10:39 AM
Helishoen is online now
Find More Posts by Helishoen
Helishoen's Avatar
United States, MA, Pittsfield
Joined Jul 2012
Redodedo, I really wouldn't hesitate to buy the newest version at all... I bought mine mid-oct and love it. I recently found that I was having an intermittent signal conflict when the antenna was in a certain position, but a proper ground wire and whip antenna cleared it right up.
I found it very easy to install on my DX7 (I wired it internally, just for personal preference) but the calibrate and bind process worked for me right out of the gate. I did make a video of the calibrate and bind process, but didn't post it because it worked so easily. I can post if anyone thinks it would help.
I'm definitely getting another DL Tx for my other Tx and a 3rd receiver for my Schraut5 wing...
Best Regards
Shoen
Helishoen is online now Find More Posts by Helishoen
Old Dec 26, 2012, 10:50 AM
Yabba is offline
Find More Posts by Yabba
Gravity - It's the law
Yabba's Avatar
USA, CO, Denver
Joined Jul 2008
Now I know why Van likes Turnigy
OT but This needs to be posted.
And with DL you can do it farther and more worry free then ever before
Yabba is offline Find More Posts by Yabba
Old Dec 26, 2012, 11:31 AM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
I have no idea what that chinglish was supposed to mean, but...the 9X and ER9X firmware makes for a really veratile system. I use it over my MPX Exo Tx!!!
Old Dec 26, 2012, 12:25 PM
Bill0 is online now
Find More Posts by Bill0
Bill0's Avatar
United States, CA, Oceanside
Joined Aug 2010
Chinese version of dear Abby?
Bill0 is online now Find More Posts by Bill0
Old Dec 26, 2012, 02:08 PM
rognut is offline
Find More Posts by rognut
Joined Dec 2012
Wasted all day trying to get solid blue. Please help:
System:
8FG - connected to TX via trainer port, TX in Low power mode, long whip antenna.
RX - has little yellow box under logo, but outputs PPM on channel 9 not 12.
Link works, but intermittent.
Calibrate, change ID, bind done multiple times. Sometimes get condition of blue led blinking constantly (every second or more often). Best so far is solid blue, but RSSI shown on OSD drops out every 7 to 10 seconds. RX also has blue led go out at that time.
PS: Did a LOT of reading.. tried many suggestions from others with similar issues. No luck. One thing I've noticed is that there seriously needs to be a table/chart/post to clearly list differences in firmware/versions. Could my RX FW be incompatible with TX?
rognut is offline Find More Posts by rognut
Old Dec 26, 2012, 02:29 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
System:
When and where did you get your system? It's been a long time since PPM out used ch9. It sound like you may have a V2 Rx with early (pre-calibration) V2 or V1 firmware. Can you post a picture of your Tx an Rx?
Old Dec 26, 2012, 03:15 PM
Anderson Pedra is offline
Find More Posts by Anderson Pedra
Anderson Pedra's Avatar
Joined Apr 2008
I sent you my Dragon Link equipment to upgrade version 1 to version 2.
I checked the shipping number track and the equipment was delivered to you on 27/11/2012.
Post Traking Number: RQ247281128BR
I did the payment using Pay Pal for cost for return international shipping US$ 25,00.
Any information please contact by e-mail:
If possible, when you send the Dragon Link, please send to me the post track number, for me follow the shipping.
I sent more information in a private message.
Best Regard,
Anderson Pedra (Brazil)
Anderson Pedra is offline Find More Posts by Anderson Pedra
Old Dec 26, 2012, 03:18 PM
rognut is offline
Joined Dec 2012
Can't take pic right now, but will post one later if needed.
RX says "v2.81" on it. Purchased November.
Can I update firmware myself? (done it before for various systems)
Where can I download firmware and instructions for RX update?
New Product Long Range UHF RC system now avail on STOCK thomasscherrer FPV Equipment 14076 Jul 18, 2016 08:25 PM
Wanted Scherrer UHF long Range or Dragon Link patrick21x FPV Equipment (FS/W) 6 Dec 24, 2015 03:50 AM
Yippee! Win a FREE Dragon Link UHF Long range RC system - BEST VIDEO contest for AUGUST !!! JettPilot FPV Talk 60 Aug 21, 2014 03:40 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
Yippee! Win a FREE Dragon Link UHF RC System - Video Contest JettPilot FPV Talk 63 Aug 02, 2011 10:52 PM
