Old Dec 07, 2011, 02:22 AM
KrisW is offline
Find More Posts by KrisW
Eccentricus Magnus
Joined May 2006
Originally Posted by mark hitchman View Post
I flew my Zephyr the other day and noticed the RSSI was really low and it went into failsafe at 2.4km. This was my 2nd FPV flight.
You might think that is bad but I discovered that when I made the antenna for the Dragonlink receiver I used a female SMA plug, the receiver is also female Duh. So when you think about it, 2.4km/1.5miles without the antenna connected aint too shabby
This is video after I redid the antenna plug with a little bit of the previous flight for RSSI comparison.
http://www.youtube.com/watch?v=zR6KG7mospU
Mark
Congratulations on getting the receiver working properly. nice to have a solid RSSI at over 1.5 miles.
The "bouncing" looks to be a shake from the airframe at certain speeds. it does not appear to be as strong at slower speeds (30-35kph) and seems to get stronger as the speed increases (really noticeable above 60kph). You are probably getting a resonance from the motor/prop and the airframe. My large UAV, with a 55cc gas engine, has definite airframe resonance that makes the camera appear to corkscrew slightly at certain engine speeds, due to the inherent imbalance of a 1-cylinder engine, and it looks like you are getting the same effect at higher speeds/prop rpm.
A couple of fixes. . make sure the camera is hard mounted, so it can't move around if the resonance is making the camera itself shake, and then check the airframe for flexibility. Less flexible will equal less camera movement.
KrisW
KrisW is offline Find More Posts by KrisW
Old Dec 07, 2011, 02:46 AM
mark hitchman is offline
Find More Posts by mark hitchman
Zephyr 66" Blunt
mark hitchman's Avatar
New Zealand
Joined Sep 2009
Originally Posted by Daniel Wee View Post
mark hitchman,
If it's any consolation, that happened to me once too, except that mine was the TX antenna was broken. Managed to get out to 4km and back before I noticed the problem. (Disclaimer: This does not mean that you should try this or assume that you can get these kind of distances without antenna attached.)
Daniel
Hey Daniel, long time no see
Did you notice I am still using my original DOSD+ V1, the perfect osd for a wing, I like the text colour too.
Mark
mark hitchman is offline Find More Posts by mark hitchman
Old Dec 07, 2011, 02:52 AM
Zephyr 66" Blunt
New Zealand
Joined Sep 2009
KrisW
Hi KrisW, I have the camera hot glued to the top, maybe it's flexing with the wind pushing on the camera, I will try bracing it and see if it helps.
Mark
Old Dec 07, 2011, 04:33 AM
edsrrrr is offline
Find More Posts by edsrrrr
edsrrrr's Avatar
Brazil, RJ, Rio de Janeiro
Joined Apr 2010
Instalação em Spektrum
Preciso saber mais detalhes da instalação no Spektrum. http://www.terranova.net/~winger/RCV...tion/JR/JR.htm não diz se Dragonlink liga direto nos fios ou nos pinos, e se ao ligar Dragonlink os fios devem ser isolados. Grato
edsrrrr is offline Find More Posts by edsrrrr
Old Dec 07, 2011, 04:48 AM
lrrps is offline
Find More Posts by lrrps
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
I was out of town since monday, just got back home and guess what, the mailman rang the bell 10mn later to deliver my DL.
Thanks for the lightning fast shipping Mike, and no extra customs fee on top of that.
BTW what are theses 2 resistors that come with the TX ?
lrrps is offline Find More Posts by lrrps
Old Dec 07, 2011, 05:18 AM
lrrps is offline
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
English por favor.
Old Dec 07, 2011, 06:51 AM
JettPilot is offline
Find More Posts by JettPilot
JettPilot's Avatar
Miami
Joined Apr 2005
Mark
Hi Mark,
Thank you for the test results, as a weight saving measure for both Mikrokopters and airplanes, I will now start shipping the Dagon Link system without antennas Since we now know it will outperform a standard RC system even without antennas
JettPilot is offline Find More Posts by JettPilot
Site Sponsor
Old Dec 07, 2011, 06:52 AM
JettPilot's Avatar
Miami
Joined Apr 2005
Ola Edsrrr,
Can you remove the back of your RC Transmitter, and take a picture of the inside, and we will show you where to connect the Dragon Link wires.
Grato
Site Sponsor
Old Dec 07, 2011, 06:54 AM
JettPilot's Avatar
Miami
Joined Apr 2005
Salut Lrrps,
These two resistors are needed in some installations to Futaba RC Transmitters, when you use the Pins from the RF module to connect to the Dragon Link. If you do not need them, just save them in case you ever might change RC transmitters.
Site Sponsor
Old Dec 07, 2011, 07:19 AM
lrrps is offline
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
Originally Posted by JettPilot View Post
Salut Lrrps,
I have a DX7, someone recommend me to connect a 100K resistor between RVOSD and Dlink RSSI output.
Old Dec 07, 2011, 07:32 AM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
Mike can you please advise what we can expect regarding firmware upgrades to make the DL compatible with others? Is it the Tx or Rx that is changed? Can we do it at home or does it have to go back to you?
Cheers
Frank
ommadawn is offline Find More Posts by ommadawn
Old Dec 07, 2011, 07:46 AM
JettPilot's Avatar
Miami
Joined Apr 2005
Cheers
Frank
Hi Frank,
We are actively working on this, I am actually doing some testing on this very thing today. Firmware will be soon, and it will be for both the TX and RX. I will have to do this here, but I will make it easy and fast for everyone. Here is how it will work, I will send a new Dragon Link, when the new one with update arrives, you send the old one back. This way no one is without thier Dragon Link, and no waits for it to cross in the mail.
Site Sponsor
Old Dec 07, 2011, 08:13 AM
lrrps is offline
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
I always fly FPV while seated with the radio TX on my lap, now is it safe with the DL.
I don't intend to make children anymore, just wanted to make sure there's no health hazard with this powerful device.
Old Dec 07, 2011, 08:56 AM
schumixmd is offline
Find More Posts by schumixmd
schumixmd's Avatar
Moldova
Joined Jun 2010
Hi Frank,
Very good news Mike.
Keep us posted.
schumixmd is offline Find More Posts by schumixmd
Old Dec 07, 2011, 10:11 AM
teopbako is offline
Find More Posts by teopbako
Ikaruswannab
Joined Sep 2009
Hi Frank,
That is crazy!!!!!!!!!!!!!!
Really glad i went the DL way
teopbako is offline Find More Posts by teopbako
New Product Long Range UHF RC system now avail on STOCK thomasscherrer FPV Equipment 14079 Jul 27, 2016 05:58 PM
Wanted Scherrer UHF long Range or Dragon Link patrick21x FPV Equipment (FS/W) 6 Dec 24, 2015 03:50 AM
Yippee! Win a FREE Dragon Link UHF Long range RC system - BEST VIDEO contest for AUGUST !!! JettPilot FPV Talk 60 Aug 21, 2014 03:40 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
Yippee! Win a FREE Dragon Link UHF RC System - Video Contest JettPilot FPV Talk 63 Aug 02, 2011 10:52 PM
