Old Dec 04, 2012, 03:46 PM
carguy1994ca is offline
Find More Posts by carguy1994ca
I tell her RC is cheap !
carguy1994ca's Avatar
Quebec, Canada
Joined Sep 2006
As is often the case for this fast paced thread, my question when un-answered. anyway, tested my DL v1 on my Summit and could do 1000 feet not so LOS. Had some trees and a house in between, pretty good I think for a surface vehicle. Goal is 1 km clear LOS.
carguy1994ca is offline Find More Posts by carguy1994ca
Old Dec 04, 2012, 03:53 PM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
The question of distance is harder to estimate on the ground. thats probably no one answered. But clear LOS, you can easily go 1km. I have tested my system by leaving one RX at my dads house 2.2 miles away, went home, and was able to control the servos attached to it. There were glitches but it was in a basement and i was on the 2nd floor of my place out on the deck. There was a small hill and about 40-50 homes in between, even a guy with a 4KW HAM tower (not sure if it was running).
I think you will be fine, and if you set your failsafes to throttle off you will be safe (as long as your not crossing a road when you loose signal)
Chris
chanyote66 is offline Find More Posts by chanyote66
Old Dec 04, 2012, 04:31 PM
flohio117 is offline
Find More Posts by flohio117
DroneWorksUSA.net
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
I'm thinking about trying out a car Fpv I'm thinking about getting my antenna for my ground station high enough with maybe a golf ball retriever that way I won't lose video. Why don't you connect your rssi so you can see how well and strong your dl signal is?
flohio117 is offline Find More Posts by flohio117
Old Dec 04, 2012, 04:49 PM
chanyote66's Avatar
Joined Dec 2011
hmm... idea for antenna!
CF tube about 18" tall, and a Plastic or fiberglass tube the rest of the way (to prevent interference from the CF) making an antenna that is stiff and puts the active element about 24-28" off the car. then you can get even better range on ground!
(you could do just fiberglass for an easier build)
Chris
Old Dec 04, 2012, 05:43 PM
Rick338 is offline
Find More Posts by Rick338
Joined Oct 2012
Mike from DragonLinks, if you read this "please" PM me. I've PM you about a problem I'm have with my DLv2 system. I really need to resolve this problem. Thank you.
Enrico(Rick) or email me; enrico338@hotmail.ca
Rick338 is offline Find More Posts by Rick338
Old Dec 04, 2012, 06:15 PM
Matt Gunn is offline
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
Mike, PM sent your way!
Matt Gunn is offline Find More Posts by Matt Gunn
Administrator
Old Dec 04, 2012, 07:08 PM
Quebec, Canada
Joined Sep 2006
Well, I don't have an OSD in the truck. Also, don't want to use a high antenna because it will go in a Tonka body, so kind of a pseudo scale model
So far, I got a good performance out of the DL on my ground try. Will do a video tonight and post it in here too so you see that distance on the ground looks more far away than in the air.
The failsafe is so that the truck will stop if it kicks in. Don't want it to run onto someone. At 5 kg and 40 Km/h, I wouldn't want to receive it in the leg :O
Old Dec 04, 2012, 10:41 PM
Panzlflyer is offline
Find More Posts by Panzlflyer
Tricopters Rule
United States, NC, Goldsboro
Joined Mar 2012
Ive got 2 Summits now, a great change of pace from "wings and things" this fpv stuff is addictive, now my daughter wants in after driving my Summit fpv.
Panzlflyer is offline Find More Posts by Panzlflyer
Old Dec 04, 2012, 10:53 PM
Rexnoobs247 is offline
Find More Posts by Rexnoobs247
FPV FTW!!
United States, MI, Grand Rapids
Joined Oct 2011
Its been a bit since I've been on here, but heres my latest video from my Reaper XL. Its also my first attempt at using Final Cut 10. Powerful program but its kind of confusing.
Twin Lakes Project Flown WIth Dragon Link (2 min 53 sec)
Rexnoobs247 is offline Find More Posts by Rexnoobs247
Old Dec 05, 2012, 12:39 AM
Jengaleng is offline
Find More Posts by Jengaleng
United States, PA, Norristown
Joined May 2012
I went ahead with jettpilots recomendation and got the futaba 12fga, I'm having trouble getting it to work in 12 channel ppm mode or any ppm mode for that matter, I'm using the futaba trainer port with the supplied cable.
Looks like there are two ppm modes, teacher and student but selecting the ppm modulation is only doable on the student screen and the green light is only solid after I activate student mode 12 channel ppm but still it does not work, in teacher mode the red light flashes.
any help would be great, i purchased the 12fg for sole purpose of using 12 channels ppm with dragonlink, i have version 3.0
-Jeng
Jengaleng is offline Find More Posts by Jengaleng
Old Dec 05, 2012, 05:56 AM
Tricopters Rule
Joined Mar 2012
I had to use the 72mhz module to set ppm on my 12z and then remove it once done, could never get ppm with 2.4
Old Dec 05, 2012, 06:24 AM
marcin.gala is offline
Find More Posts by marcin.gala
marcin.gala's Avatar
Joined Jun 2010
Please answer my PM.Thanks.
marcin.gala is offline Find More Posts by marcin.gala
Old Dec 05, 2012, 08:40 AM
Rick338 is offline
Joined Oct 2012
I've PM you, Mike from DragonLink. Please check. Thank you.
Enrico(Rick)
Old Dec 05, 2012, 10:09 AM
austin.laws is offline
Find More Posts by austin.laws
Night flier
United Kingdom, England, Bromyard
Joined Mar 2008
Hi I have decided to give up rc flying for now so selling alot of stuff including my Dragonlink. Check ebay for condor fpv Futaba 10c and loads more seller name mrpowers1977. Thanks.
austin.laws is offline Find More Posts by austin.laws
Old Dec 05, 2012, 11:41 AM
Yabba is offline
Find More Posts by Yabba
Gravity - It's the law
Yabba's Avatar
USA, CO, Denver
Joined Jul 2008
#1 on the 72mhz module when using a 12Z.
But (I haven't bothered to try) can you get more then an 8 channel PPM stream from your Z ?
Yabba
Yabba is offline Find More Posts by Yabba
New Product Long Range UHF RC system now avail on STOCK thomasscherrer FPV Equipment 14067 Today 02:20 AM
Wanted Scherrer UHF long Range or Dragon Link patrick21x FPV Equipment (FS/W) 6 Dec 24, 2015 03:50 AM
Yippee! Win a FREE Dragon Link UHF Long range RC system - BEST VIDEO contest for AUGUST !!! JettPilot FPV Talk 60 Aug 21, 2014 03:40 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
Yippee! Win a FREE Dragon Link UHF RC System - Video Contest JettPilot FPV Talk 63 Aug 02, 2011 10:52 PM
