Old Oct 24, 2011, 12:33 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Originally Posted by invertmast View Post
Looks like it would be perfect to sand smooth, glass and mold it I think i know what I will do with my 2nd one
While your at it, you can add material to make intakes and increase the size of the tail. Shove a bigger edf in there.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Oct 24, 2011, 12:48 PM
robertboxhoorn is offline
Find More Posts by robertboxhoorn
Flying Dutchman!
robertboxhoorn's Avatar
Nederland, FL, Emmeloord
Joined Sep 2011
this is going to be fun.....!
robertboxhoorn is offline Find More Posts by robertboxhoorn
Old Oct 24, 2011, 05:38 PM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
Very true! The problem is, i've got 5 projects (2 of which are fully molded ones) before this one! lol
invertmast is offline Find More Posts by invertmast
Old Oct 30, 2011, 01:37 PM
Flying Dutchman!
Joined Sep 2011
Mini Viper von Tomahawk Design mit Feigao...Very Fast!!! (1 min 44 sec)
the mine would go faster! 8)
Old Nov 07, 2011, 11:48 AM
bobby67 is offline
Find More Posts by bobby67
crash rc plane is my job....
bobby67's Avatar
Florence area,Tuscany, Italy
Joined Jan 2009
Hi microedf lovers,
I have already tested my first MiniViper with Hacker outrunner, flies very well and is fast. The center of gravity is 45 mm from the leading edge, 2s 450 lipo, one 9 gr. servo and one 3.5 grams., 4.4 propeller. Truly a great little jet! Now I have started the construction of the second with inrunner Hyperion Y12 .... some pix of the work ......
bobby67 is offline Find More Posts by bobby67
Old Nov 07, 2011, 01:47 PM
Flying Dutchman!
Joined Sep 2011
tnx bobby
why did you make that hole so big? did you make one with edf?
i'm still waiting to my little viper
this wil be my colorscheme
Old Nov 07, 2011, 02:10 PM
bobby67 is offline
bobby67's Avatar
Joined Jan 2009
Originally Posted by robertboxhoorn View Post
tnx bobby
Hi rob,
is to put the Hyperion, I hope it's cool enough. The hole is 16 mm, the engine 12 mm in diameter, so you will only see the propeller. I thought of drowning the engine in poly but I do not think it works well ........
I have a 30 mm edf from Aeorc, but the problem is the back.....too little.....
Old Nov 07, 2011, 02:41 PM
Flying Dutchman!
Joined Sep 2011
I have a 12mm drill bit and I want make the hole for the inrunner with that drill
i will make a 12 mm air intake at the bottem to cool down the inrunner
I've already made ​​the motor wall with the cooling holes like you did
you did a nice job i'm very impressed and i'm waiting en thinking more and more at my jet
Old Nov 11, 2011, 08:50 AM
Flying Dutchman!
Joined Sep 2011
Well I got it :-)
it is a nice model very easy to make rc
the foam is the same foam as known from the Funjet is very hard, yet flexible
I opened the intakes because otherwise you have no cooling for the engine and the engine only in insulation material
battery also fits well in the nose only have I done something wrong :-(
When heating the shrink sleeve, I did'nt note that i heat the tail to! the foam bubble a little bit, does anybody know how you can repair this?
I have some pictures that I post later but will first make him ready to fly :-)
Old Nov 11, 2011, 12:32 PM
Joined Nov 2007
Can it be sanded?
Old Nov 11, 2011, 02:58 PM
bobby67 is offline
bobby67's Avatar
Joined Jan 2009
Well I got it :-)
If the bubbles are imperceptible you can sand, or a lightweight filler and paint over (if the final finish will be painting). Be careful when you do the maiden, run at no more than 3 / 4 gas, do not give a strong impetus when you lunch the model. Mine is sensitive to the effect of prop torque ... then when it picks up speed .. no problem. Yesterday I made ​​a video, just adjust and then i'll post. Good luck to maiden.......
Old Nov 12, 2011, 02:35 AM
Flying Dutchman!
Joined Sep 2011
tnx bobby :-)
the maiden is maybe over a view hours :-)
Old Nov 13, 2011, 08:23 AM
Flying Dutchman!
Joined Sep 2011
sh*t!
I glued the wing to the fuselage with thin super glue but there is glue in the controller that makes after connecting lighting
Now I must buy a new one for the maiden to become a Dymond smart 10
Old Nov 13, 2011, 01:09 PM
Flying Dutchman!
Joined Sep 2011
here are the pics:
the color of the fuselage is almost ready here come later photographs of
Discussion Tomahawk Viper Jet like2fly! Foamy EDFs 555 Jul 25, 2016 10:56 AM
Discussion Tomahawk Viper Edf 420flyboy Electric Ducted Fan Jet Talk 2 Oct 07, 2011 08:32 AM
Discussion Tomahawk 70mm Viper edf 420flyboy Foamy EDFs 0 Oct 03, 2011 09:06 PM
Help! Tomahawk Designs Viper JET EDF elevator rates? Kenta78 Foamy EDFs 1 Apr 01, 2011 07:07 PM
Discussion Dodge Tomahawk Mini Bike Akura2 Motorcycles 1 Aug 07, 2008 02:39 AM
