Old Oct 21, 2011, 09:47 PM
Sherlock is offline
Find More Posts by Sherlock
Sherlock's Avatar
Milwaukee, WI
Joined Sep 2006
Originally Posted by MegaTesla View Post
Put a prop on it and have some fun
NO! You flew the Bandit at 44 grams with a 22mm EDF. Plenty of intake area on this jet I would love to convert this one. It would even be lighter when you dig a bunch of foam out of it.
I would cut the nose off ahead of the canopy and dig it out to save weight. Then glue the horizontal tail and wings on and cut off the vertical fin and the stabs off where they meet the fuse. This way you can set up all flying stabs for taileron control.
Next saw the fuse in half. Now you can dig out the intake and exhaust to fit a fan with no lip perfectly. You will be able to get 100% fsa no problem with a 22mm. Dig out the canopy and the area under the canopy and you have plenty of room for two servo's and the batts. Glue it all back together and put a magnet or two on the canopy. Done.
Wish I had the time. Maybe later.
Sherlock is offline Find More Posts by Sherlock
Old Oct 22, 2011, 12:30 AM
ksqm is offline
Find More Posts by ksqm
United States, VA, Hampton
Joined Mar 2009
Better yet, drop a 25mm MDF in there. At 15"+ WS, 22mm may move it, but you wouldn't have fun. Go with a 12mm inrunner or micro outrunner on 3S. Keep AUW under 60g-65g and it'll rock.
@Invertmast,
If you haben't ordered yet, I'd be good for 2. And split shipping with you. I'm down in the Norfolk area. PM me if you want to make a go at it.
Ksqm
ksqm is offline Find More Posts by ksqm
Old Oct 22, 2011, 08:19 PM
Sherlock is offline
Sherlock's Avatar
Milwaukee, WI
Joined Sep 2006
The 25 would work good because the tail end is 20mm, which is a perfect 80%.
Old Oct 22, 2011, 08:56 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
20mm minus the wall thickness. Think about it. A 80% FSA with one of my 25/12 fans would yield a diameter of 18.76mm. Area of I.D. minus Area of hub equals FSA.
With the 25/OT you would need a diameter of 18.53mm. Just shoot for 19mm.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Oct 22, 2011, 09:14 PM
Sherlock is offline
Sherlock's Avatar
Milwaukee, WI
Joined Sep 2006
If I get around to doing this one I would probably just chop off the end right at the fuse and reproduce it with a thrust cone to the correct diameter.
Old Oct 23, 2011, 06:49 AM
robertboxhoorn is offline
Find More Posts by robertboxhoorn
Flying Dutchman!
robertboxhoorn's Avatar
Nederland, FL, Emmeloord
Joined Sep 2011
i've ordered mine yesterday so i'm waiting :-)
robertboxhoorn is offline Find More Posts by robertboxhoorn
Old Oct 23, 2011, 10:04 AM
Sherlock is offline
Sherlock's Avatar
Milwaukee, WI
Joined Sep 2006
Do you know how many amps your 25/12 set up would pull with a Fiago 5800 on 3s? I'm wondering if the batteries would have to be bigger than this model could handle with that setup. You could probably get close to 1:1 with a 25/10 and a hi KV Losi on 2s I would think.
Old Oct 23, 2011, 10:05 AM
Sherlock is offline
Sherlock's Avatar
Milwaukee, WI
Joined Sep 2006
Are you going with the pusher or EDF? Should be good fun either way.
Old Oct 23, 2011, 12:06 PM
ksqm is offline
Joined Mar 2009
Sherlock,
I'd say less than 5.5a. I'll let you know in a couple of days..
Ksqm
Old Oct 23, 2011, 01:52 PM
Sherlock is offline
Sherlock's Avatar
Milwaukee, WI
Joined Sep 2006
Sherlock,
Ksqm
At 5.5 amps you should be able to power that with a 3s 250 25c. Maybe a custom pack to keep the weight down. What were you thinking?
Old Oct 23, 2011, 01:54 PM
Joined Nov 2007
Sherlock,
Ksqm
With the 25/12, you need serious rpms. The 5800kv isn't going to do any better than a 1015 11500kv. If you were able to get the 5800kv on 5s (which isn't going to happen), then you might see something worth it. Turboace has a 16800kv 12mm inrunner - Turbo Ace 31714. (I have no idea where to get it though.)
You will also need to use a clipped 40mm rotor, or a trimmed 7-blade 27mm rotor.
Old Oct 23, 2011, 05:13 PM
Sherlock is offline
Sherlock's Avatar
Milwaukee, WI
Joined Sep 2006
So what kind of setup do you believe is ideal for your 25/12? For this plane you need a setup that will give you at least 45 grams or so of thrust for 1:1. This assumes that you will be around that weight after carving out a bunch of foam and putting in lightweight electronics.
A 25/10 seems good enough. Here is Nitro's set up with 47 grams thrust:
http://www.rcgroups.com/forums/showp...3&postcount=65
Old Oct 23, 2011, 05:29 PM
Joined Nov 2007
I never tested any of my units. All the testing was done by Nitro, MT, All4, ksqm, and a few others (which I really do thank them for). I just compiled all of that info to make logical assumptions. The 12 hasn't been proven by anyone, but from Nitro's tests, it's easy to see that a 12mm motor isn't loaded, even the 10300kv one. This means that you would either need more cells or higher kv for more rpm to load a 12mm motor. Nitro did prove the effectiveness of the 10mm though.
All that said, the 12 is still in the x-stage. It's more open to custom motors than commercially available ones.
Old Oct 24, 2011, 07:15 AM
Flying Dutchman!
Joined Sep 2011
i've got an hyperion y12 5800kv motor and 2 dymond d47 servo's
on a 3x2 gws prop
edf would be later this look's good:
http://www.nitroplanes.com/88e-adf30-housing.html
hope it wil fit a 12mm inrunner
Old Oct 24, 2011, 11:31 AM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
Looks like it would be perfect to sand smooth, glass and mold it I think i know what I will do with my 2nd one
invertmast is offline Find More Posts by invertmast
Discussion Tomahawk Viper Jet like2fly! Foamy EDFs 555 Jul 25, 2016 10:56 AM
Discussion Tomahawk Viper Edf 420flyboy Electric Ducted Fan Jet Talk 2 Oct 07, 2011 08:32 AM
Discussion Tomahawk 70mm Viper edf 420flyboy Foamy EDFs 0 Oct 03, 2011 09:06 PM
Help! Tomahawk Designs Viper JET EDF elevator rates? Kenta78 Foamy EDFs 1 Apr 01, 2011 07:07 PM
Discussion Dodge Tomahawk Mini Bike Akura2 Motorcycles 1 Aug 07, 2008 02:39 AM
