Old Feb 28, 2012, 10:58 AM
robertboxhoorn is offline
Find More Posts by robertboxhoorn
Flying Dutchman!
robertboxhoorn's Avatar
Nederland, FL, Emmeloord
Joined Sep 2011
maybe this helps
the out take of the jet is 20mm intakes both about 20 square mm
robertboxhoorn is offline Find More Posts by robertboxhoorn
Old Feb 29, 2012, 01:35 PM
Flying Dutchman!
Joined Sep 2011
now it's ready to fly
I only need to paint it
Old Mar 03, 2012, 05:49 PM
rcbobcat55 is offline
Find More Posts by rcbobcat55
sailplane nut
Herminie, PA 15637
Joined Apr 2007
Hello again from RCbobcat55@yahoo.com. For a low priced motor try HobbyKing.com. I purchase a lot of items from them for my DLG which I kit (look under sailplanes/hand launch/Dyne-O-Mite) and they have a wide selection of motors. I recently got one from them which has specs very close to an Axi outrunner and it was less than $30.00. It will be used in a new kit I am about ready to release- a 6 ft span old timer electric replica and this motor really has the guts.but isn't a current hog. thanks for the info on the Mini Viper Bob M.
rcbobcat55 is offline Find More Posts by rcbobcat55
Old Jul 15, 2012, 05:54 PM
pylot2b is offline
Find More Posts by pylot2b
Virginia Beach, Virginia, United States
Joined Jan 2004
After watching this thread for awhile I took the plunge and built on of these. Finished last night and maidened today. Awesome little plane. 4 flights today.
Hacker A10-12S
2s 360 or a 2s 800 (Have to add 1/2 oz of weight to get it to balance with the smaller pack)
2- HK 2.7g servos
1- HS-55 servo
Turnigy 6 amp esc
APC 4.1 x 4.1
Spektrum AR 400 rx
Total weight: 145 grams
Love this plane. Nice easy under hand launches. Now to build one with a 3s setup!
pylot2b is offline Find More Posts by pylot2b
Old Jul 17, 2012, 02:06 AM
Flying Dutchman!
Joined Sep 2011
did you have one picture from under the canopy?
Old Jul 17, 2012, 08:14 AM
pylot2b is offline
Joined Jan 2004
I can get you a picture later today.
Old Jul 18, 2012, 05:04 AM
Flying Dutchman!
Joined Sep 2011
thank you!
isn't a hs55 servo not to big for this size of planes? you can use an 5gr servo to without having any problems...
Old Jul 18, 2012, 05:35 AM
pylot2b is offline
Joined Jan 2004
I am sure you can use a 5g servo. I just used what I had laying around.
Old Sep 02, 2012, 08:05 AM
itrda is offline
Find More Posts by itrda
Joined Sep 2012
I built one of these set the CG to 40mm hacker outrunner etc.The first flight was on a very windy day , I wasn't even going to fly it was so windy but I had 4 sucessful flights that day. I couldent understand why people were having problems when launching. The next day was flat calm and I couldent wait to fly it again but after launching it did the death roll and slammed nose first into the ground!!! couldent get it to fly at all that day. Also the ailerons became very sensative anyone any idea why that would be?Does the motor cure the roll to the left on take off?
itrda is offline Find More Posts by itrda
Old Sep 03, 2012, 09:44 AM
Flying Dutchman!
Joined Sep 2011
no probably you need to throw harder and launch higher.
when the viper get speed there arent troubles anymore
maybe try bungee (not the one you get but a bigger one)
Old Oct 15, 2012, 12:47 PM
LC640 is offline
Find More Posts by LC640
United Kingdom, Island Magee
Joined Jul 2011
Thanks had a few more successful flights and a load more crashes. Ordered a new airframe I might try my Medusa Inrunner in that with three cells and GWS 3x2 prop. What size / length bungee are u using?
LC640 is offline Find More Posts by LC640
Old Oct 15, 2012, 03:27 PM
Flying Dutchman!
Joined Sep 2011
No bungee just throw in an angle of 45 degree with full power and it should spin one time and get speed and fly
Old Oct 31, 2012, 09:57 AM
micbu is offline
Find More Posts by micbu
Joined Sep 2004
Viper with EDF
Iljas Pico ViperJet EDF (3 min 18 sec)
Post 71 and following ones.
http://www.rc-network.de/forum/showt...ght=mini+viper
Michael
micbu is offline Find More Posts by micbu
Discussion Tomahawk Viper Jet like2fly! Foamy EDFs 540 May 25, 2016 03:35 PM
Discussion Tomahawk Viper Edf 420flyboy Electric Ducted Fan Jet Talk 2 Oct 07, 2011 08:32 AM
Discussion Tomahawk 70mm Viper edf 420flyboy Foamy EDFs 0 Oct 03, 2011 09:06 PM
Help! Tomahawk Designs Viper JET EDF elevator rates? Kenta78 Foamy EDFs 1 Apr 01, 2011 07:07 PM
Discussion Dodge Tomahawk Mini Bike Akura2 Motorcycles 1 Aug 07, 2008 02:39 AM
