And lastly..
Pre-Flight Check and Rudder Servo is buzzing, damn. Disconnecy Pushrods, check Arm Post torquet, Re-bend Pushrods, Re-position Servo Arm, disconnect Tailwheel,...buzz, buzz, buzz. Finally sprayed some Silicon lube on the Pushrod pass-through hole in the Fuse and bingo, servo happy. You woudnt think the Foam could grab it like that, wish I had of tried that first and saved 3/4 of an hour.. |
You probably have the DYNAM P-51!! LURCH |
Australia, VIC, Melbourne
Joined Nov 2006
You really want to bend the pushrods to suit their path better. It only needs a faint "Z" bend shape. Then it doesn't even need any lube - but using some also can't hurt.... or can it? I hope it is foam safe! LOL
In general it is best not to use any lube ever (maybe dry lube is somewhat more ok?) because it just grabs dust/dirt and eventually becomes 'sanding lube' instead! hehe |
drafly vs FMS
I also have the 1700mm Ferocious Frankie P-51 from FMS (Doctorfoamy on Youtube). The Durafly P51 is an exact replica (except for cockpit detail and retractable tail wheel) in terms of molding..etc. Every line, every rivet is the same - as if they simply scaled the plane down to fit the 1100mm spec. FMS is Durafly... even the spare parts are the same....labels on the parts bags...etc.
Notwithstanding that you generally hear more from the dissatisfied customers than the happy ones. i want to go 1.7Mtr but am not confident in any of the existing offerings being satisfactory. |
Joined Nov 2006
The FMS 1.7m costs pretty well double the Starmax 1.6m. Seeing you can get the Starmax from HK Aust, but not the FMS 1.7m. $222 for the Starmax delivered. Could be $450 area for the FMS.
So you could own 2 of the Starmax for 1 FMS and they are both excellent finish/quality - but all Chinese planes have shortfalls too..... It would seem it is hard to justify such a huge % cost increase, for...???.. 100mm and gear doors.... and ??? I can (not sure I will bother yet) fit gear doors to the Starmax for little cost ($20 or less). I would hope the FMS has some good reasons to support that huge extra cost, but I don't see it. It is probably more around $300 value in comparison - but you don't get a choice, you just have to pay what they want if you want those differences. |
| Thread Tools | |
| Discussion Retracts servo-operated for Top Flight P-51D Mustang KIT | bono3d | Flight Accessories | 1 | Oct 11, 2011 09:58 PM |
| Discussion P-51D Mustang Parts Recommendations | RoysRC | Electric Plane Talk | 0 | Sep 25, 2011 08:57 AM |
| Sold Tower P-51D Mustang Brand New in Box Rx Ready Low $$ | microDan | Aircraft - Electric - Airplanes (FS/W) | 19 | Sep 17, 2011 11:20 AM |
| Sold Parkzone P-51D Mustang Ultra-Micro Flyer | RCFlyerGuy | Aircraft - Electric - Micro & Indoor Airplanes | 1 | Sep 16, 2011 07:56 AM |
