Old Jan 30, 2012, 05:21 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Yes, they are printed with working mechanisms. No assembly is required!
If there is clearance between parts - it prints it, or rather - doesn't print it. It's a big block of powder in the end and the parts that get zapped by the laser go solid, the rest remains a block of dust, which is removed afterwards.
The recommended clearance for frosted ultra detail plastic(which is a gel) is 0.1mm for moving parts, which is what I have applied to the design.
See here - 2. Moving parts
NitroCharged is offline Find More Posts by NitroCharged
Old Jan 30, 2012, 11:44 PM
Slaanesh is offline
Find More Posts by Slaanesh
Not enough hours in the day
Slaanesh's Avatar
Melbourne
Joined Feb 2009
Very interesting... Thanks!
Slaanesh is offline Find More Posts by Slaanesh
Old Jan 31, 2012, 09:01 AM
tmtbiker is offline
Find More Posts by tmtbiker
micro scale builder
tmtbiker's Avatar
United States, DC, Washington
Joined May 2008
retracts look excellent dave, thank you again for your hard work. amazing to think that nobody had thought of these before 2012?!
tmtbiker is offline Find More Posts by tmtbiker
Old Jan 31, 2012, 02:36 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Thanks guys.
Old Feb 01, 2012, 06:09 AM
bobbyhigh is offline
Find More Posts by bobbyhigh
Field Darter
bobbyhigh's Avatar
Singapore, Singapore
Joined Oct 2011
That's progress!
bobbyhigh is offline Find More Posts by bobbyhigh
Old Feb 15, 2012, 09:34 PM
Slaanesh is offline
Slaanesh's Avatar
Melbourne
Joined Feb 2009
Any update on those micro retracts? I'm holding off on my order to Shapeways because I want to order everything in the one shot to maximize the shipping cost.
Old Feb 15, 2012, 09:43 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Expected shipping date is 20th of February.
I'm as keen as you are to see these.
Old Feb 17, 2012, 04:14 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Slaanesh, just got word the latest order has shipped.
Old Feb 19, 2012, 05:26 AM
Slaanesh is offline
Slaanesh's Avatar
Melbourne
Joined Feb 2009
Very nice! Can I assume a PZ micro is the target testbed?
Old Feb 19, 2012, 05:03 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Yes, the Mustang - poor thing.. it's been through a lot already...
Old Feb 22, 2012, 11:36 AM
zbrubaker is offline
Find More Posts by zbrubaker
ParkScaleModels
zbrubaker's Avatar
United States, PA, Loganville
Joined Feb 2002
NC...I just got something from Shapeways to try their service out for the fist time. Looking at your varoius ducts, does the process/material yield a sufficiently smooth surface? I went with the cheaper sandstone option for my test subject.
Thx!
-Zeke
zbrubaker is offline Find More Posts by zbrubaker
Old Feb 22, 2012, 06:05 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
I think it does and so far testing the results has shown there is minimum problems with the surface affecting thrust. I am very happy.
Old Feb 23, 2012, 03:56 PM
Jacques.Eloff is offline
Find More Posts by Jacques.Eloff
Jacques.Eloff's Avatar
United Kingdom, England, Cobham
Joined Oct 2007
I have 3 of the 35mm shrouds designed by Nitro and I can honestly say they are great. The surface may not be mirror smooth, but remember that boundary layer principles infer that there is often very little difference in drag/energy loss from a textured surface. In fact, this sometimes has a positive effect - we all know that a dimpled golf ball flies further than a smooth one, and many full size aircraft/gliders use turbulators to change the airflow from laminar to turbulent.
What really impressed me is how snug a 12mm inrunner fits in the housing - you could get away with using motor screws!
In the efficiency comparisons below, all of my setups (apart from the J Power Stock setup) use these shrouds.
Jacques
Jacques.Eloff is offline Find More Posts by Jacques.Eloff
Old Mar 06, 2012, 05:03 AM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Button Retracts update
The first draft set of retracts arrived end of last week. They look way smaller in your hand than on a large computer monitor...
They weigh a tiny 0.3g each!
My space allowance for the separate parts was too close and the sintering heat welded the parts here and there. A slight adjustment to the parts spacing and we'll try again. I did a destructive test on one of them and it's tough to say the least. I used pliers in the end to break the pieces.
Old Mar 06, 2012, 08:53 AM
forsakenrider is offline
Find More Posts by forsakenrider
Canada, BC, Grand Forks
Joined Aug 2008
what about a 25mm and/or 27-28mm case for the GP 10mm motor? Or would that be too much fan for it?
forsakenrider is offline Find More Posts by forsakenrider
Discussion Team30 Micro EDF FW-35A Lighting II NitroCharged Micro EDF Jets and Power Systems 29 Dec 11, 2011 03:29 PM
Build Log Team30 Micro EDF UM Habu NitroCharged Micro EDF Jets and Power Systems 11 Sep 09, 2011 07:45 PM
Discussion Team30 Micro EDF T-45 BAE Hawk NitroCharged Micro EDF Jets and Power Systems 481 Feb 08, 2011 03:04 AM
Discussion Team30 Micro EDF 12" Douglas Skyray - Video now online! NitroCharged Micro EDF Jets and Power Systems 160 Jun 11, 2010 01:54 PM
