Old Jan 17, 2012, 03:49 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Which item Chester? Post a link. I think we got our wires crossed.
NitroCharged is offline Find More Posts by NitroCharged
Old Jan 17, 2012, 04:55 PM
chester2240 is offline
Find More Posts by chester2240
chester2240's Avatar
United States, CO, Westminster
Joined Jul 2011
yeah no problem i wont be able to order it till friday anyways
http://www.shapeways.com/model/43019...ml?gid=sg40671
chester2240 is offline Find More Posts by chester2240
Old Jan 17, 2012, 05:05 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
OK - updated.
Old Jan 17, 2012, 05:41 PM
Joined Jul 2011
THANKS ive never heard of alumide befor? i just started reading about it and it is aluminum mixed in with the the plastic im not sure how good it would work as an heatsink but for only 2$ more it's worth finding out
Virtox on 2010-02-25 14:12 I'm no expert, but I had a look :
The datasheet for alumide shows 0.5W/(m*K)
While normal Aluminium is 237W/(m*K)
So I don't think it will make a very good heatsink.
Too bad, would have been cool >:-)
ok it will be a terrible heat sink sorry nitro so the heat conductividy of the alumide is correct (0.5W/(m*K)) here is the Data on diffrent matterals http://www.frostytech.com/articleview.cfm?articleID=233 so i would take it in silver then lol
Old Jan 17, 2012, 05:44 PM
Slaanesh is offline
Find More Posts by Slaanesh
Not enough hours in the day
Slaanesh's Avatar
Melbourne
Joined Feb 2009
From Shapeways:
Alumide is White, Strong & Flexible with Aluminum dust mixed in. It is made using the Selective Laser Sintering process. The material has a higher heat resistance than regular plastics. Its melting temperature is above 172 Celsius It costs $1.99 per cubic centimeter (plus $1.50 start up costs per model).
The surface is smoother than White, Strong & Flexible (WSF) and is a matte grey with speckles of shiny aluminum dust thrown in.
Slaanesh is offline Find More Posts by Slaanesh
Old Jan 19, 2012, 12:17 AM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
I have a 25mm shroud for 12mm motors available now.
http://www.shapeways.com/model/44491...2mm_motors.htm
Old Jan 22, 2012, 09:35 AM
bobbyhigh is offline
Find More Posts by bobbyhigh
Field Darter
bobbyhigh's Avatar
Singapore, Singapore
Joined Oct 2011
Hi NC,
Have you tried the 9000kV outrunner sold by SydneyRCJets on your EDFs?
http://sydneyrcjets.com.au/motors-c-...-edf-jet-p-317
I was able to get about 70g thrust on a 2S, 35mm EDF. Would be awesome if this motor fits the 25mm EDF case!
This outrunner is too large to fit into the GWS 30mm EDF case. A 10.5mm motor housing would be perfect.
Rough info on the motor:
10g (including wire leads)
Mounting plate 10mm dia, screw hole-to-hole 8mm
Outrunner can 14mm
Total length 38mm
Shaft 1.5mm (threaded)
bobbyhigh is offline Find More Posts by bobbyhigh
Old Jan 22, 2012, 02:28 PM
Joined Jul 2011
Thanks for shareing that bobbyhigh do u know how many amps it can take and the cell count?
Old Jan 22, 2012, 04:53 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
bobbyhigh, I lathed down the front mount to 10mm so it would fit in a GWS 30mm can...
Old Jan 22, 2012, 06:17 PM
jahel is offline
Find More Posts by jahel
United States, FL, Clearwater
Joined Jun 2011
Nice to go 4s...
jahel is offline Find More Posts by jahel
Old Jan 22, 2012, 08:28 PM
Field Darter
bobbyhigh's Avatar
Joined Oct 2011
The 35mm EDF (5 blades) is gutted from a resale HK MIG 15.
http://www.hobbyking.com/hobbyking/s...dProduct=17309
Specs:
Wing Span: 390mm
Length: 390mm
Flying Weight: 95g
EDF: 35mm with 9000kv Brushless Outrunner Motor
ESC: 6A w/BEC
Servo: 3 x 2g
Can't advise on the amp count as i do not have a watt meter. However, the following are some stats from my last measurement:
Thrust: 80g
2S 500mAh 20C Zippy lipo
TGY 6A ESC (39C) after 30 seconds WOT
Based on similar SkyAngel 35mm EDF planes, this motor can take 3S on 3 blade. It will be interesting to see the results of a hot wind on this.
Old Jan 22, 2012, 08:31 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
For anyone interested, I've just uploaded another request - a 25mm EDF Case with flange for 8.5mm motors.
http://www.shapeways.com/model/44857...5mm_motor.html
Old Jan 22, 2012, 08:41 PM
Field Darter
bobbyhigh's Avatar
Joined Oct 2011
NC,
I can fit the TGY 1015 into the 30mm GWS housing but not this outrunner. You would have to provide more tolerance for a 10mm can in the 25mm housing. How about a rotor with 1.5mm (shaft) to boot?
Old Jan 22, 2012, 09:21 PM
ksqm is online now
Find More Posts by ksqm
United States, VA, Hampton
Joined Mar 2009
That's what I'm after!!!
Ksqm
ksqm is online now Find More Posts by ksqm
Old Jan 25, 2012, 07:32 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
For those wanting to gear up ready for the Great Planes 10mm motor when it lists as a spare part, here is a 20mm EDF case (no flange) to suit: http://www.shapeways.com/model/45289...0mm_motor.html
You will get ~45g of static thrust on 3S using a GWS 30mm rotor chopped to 3 blades and clipped to 20mm.
Discussion Team30 Micro EDF FW-35A Lighting II NitroCharged Micro EDF Jets and Power Systems 29 Dec 11, 2011 03:29 PM
Build Log Team30 Micro EDF UM Habu NitroCharged Micro EDF Jets and Power Systems 11 Sep 09, 2011 07:45 PM
Discussion Team30 Micro EDF T-45 BAE Hawk NitroCharged Micro EDF Jets and Power Systems 481 Feb 08, 2011 03:04 AM
Discussion Team30 Micro EDF 12" Douglas Skyray - Video now online! NitroCharged Micro EDF Jets and Power Systems 160 Jun 11, 2010 01:54 PM
