Old Oct 08, 2011, 08:57 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
I know, I know.. the one thing still missing is 'drop in' high performance 30mm EDF's.
I'm just waiting on a few motors to arrive (still a few weeks away) to test out in 30mm EDF's and if all goes well, may be able to follow up on it.
MK - yes, it's all explained and demo'ed on the Shapeways site.
I got the final model done for the Complete 25MM EDF split Nacelle (each one I do evolves) and the way it has been modelled has made it turn out real sweet. I've actually impressed myself on this one.
NitroCharged is offline Find More Posts by NitroCharged
Old Oct 12, 2011, 06:31 PM
kelberts is offline
Find More Posts by kelberts
Effumall
kelberts's Avatar
Joined Nov 2005
Gamechanger!!!
kelberts is offline Find More Posts by kelberts
Old Oct 13, 2011, 09:13 PM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
man thats WICKED!
corsair nut is online now Find More Posts by corsair nut
Old Oct 13, 2011, 09:52 PM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
How would one of these work out in that Tomahawk mini Viperjet?
invertmast is offline Find More Posts by invertmast
Old Oct 24, 2011, 05:52 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Here's another idea I've followed up on. I always wanted a square to round flange to transfer the air in my box construction 25mm Micro Hawk to maximise efficiency. This will clip on to the case and a drop of CA to keep it there. Let me know if you want one drawn up for your own specific model. Supply the case diameter, how long you want the flange and what the front measurements are. It dos not have to be square. It can be any shape. This one is 25mm diameter to a 30mm sided square, 15mm in depth - 1mm material thickness.
Old Oct 24, 2011, 06:00 PM
ksqm is online now
Find More Posts by ksqm
United States, VA, Hampton
Joined Mar 2009
NitroChrged,
That's the key to the T-50 Golden Eagle!!! I took a 6mm piece of depron aero and made my flange. Reallly helps bring air flow to the fan face. That's great what you're doing!!!
Ksqm
ksqm is online now Find More Posts by ksqm
Old Oct 24, 2011, 06:30 PM
Slaanesh is offline
Find More Posts by Slaanesh
Not enough hours in the day
Slaanesh's Avatar
Melbourne
Joined Feb 2009
Those flanges are absolutely bonus. Great idea!
Can you do customized ones too? ie, custom diameter and custom square?
Slaanesh is offline Find More Posts by Slaanesh
Old Oct 24, 2011, 06:42 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Yes! Anything you like.
I just did another for a 27mm x 31mm rectangular front, 14mm long
Old Jan 06, 2012, 03:38 PM
chester2240 is offline
Find More Posts by chester2240
chester2240's Avatar
United States, CO, Westminster
Joined Jul 2011
These look amazing i want to place an order for 2 of the 25mm edf case's But!!!! Do they all take a 12mm inrunner like the 30mm do?
chester2240 is offline Find More Posts by chester2240
Old Jan 06, 2012, 04:39 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Thanks Chester,
I drew up a 12mm motor version of the 25mm case and it now available:
http://www.shapeways.com/model/43019...2mm_motor.html
Old Jan 06, 2012, 04:48 PM
Joined Jul 2011
Thanks a ton i was just ordering the other one now i am getting 2 of these thanks alot man. And another question is what rotor should i use with these i was thinking of getting the 8 blade and cutting it to 4 blades and the motor i will be using is the 1230 turnigy motor maybe 3 maybe 2 cell
EDIT: ok so after spending hours reading post after post about your work nitro and megatesla and boredom is me i have figured i get the 1220 motor on 3s i think the 1015 will burn out with the 3sn460mah battery i wanna use.i will have to check if the gws rotor cut to 3 or 6 will give the best performence and i have to say thanks for all your hard work on making these things possable
Old Jan 07, 2012, 06:29 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Chester, definitely trim to a 3 blade setup if on 3S.
Old Jan 07, 2012, 06:38 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Just added another model to the collection.
Anyone wanting to seriously crank up their 35mm models can now use a 20mm motor!
http://www.shapeways.com/model/430507/35mm_edf_for_20mm_motors.html
Old Jan 07, 2012, 07:18 PM
Joined Jul 2011
here is a good motor to test with that case S2030-6570 Brushless Inrunner (6560kv) http://www.hobbyking.com/hobbyking/s...r_6560kv_.html running it on 4 cells would reall give a ton of trust
Old Jan 07, 2012, 07:36 PM
pdawg is online now
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Omg NC,
Who the heck is crazy enough to have requested that 35/20 shroud?
pdawg is online now Find More Posts by pdawg
Discussion Team30 Micro EDF FW-35A Lighting II NitroCharged Micro EDF Jets and Power Systems 29 Dec 11, 2011 03:29 PM
Build Log Team30 Micro EDF UM Habu NitroCharged Micro EDF Jets and Power Systems 11 Sep 09, 2011 07:45 PM
Discussion Team30 Micro EDF T-45 BAE Hawk NitroCharged Micro EDF Jets and Power Systems 481 Feb 08, 2011 03:04 AM
Discussion Team30 Micro EDF 12" Douglas Skyray - Video now online! NitroCharged Micro EDF Jets and Power Systems 160 Jun 11, 2010 01:54 PM
