Old Oct 06, 2011, 05:58 AM
rateoneturn is offline
Find More Posts by rateoneturn
Joined Nov 2010
twist caused by landing gear install on 1.3# 9mm epp
hey,
as the title says, anyone ever encounter this on a profile before?
this was an sbach auw = 40+ oz's 42" w/s with 4mm square carbon in fuse with 9mm doublers full length on each side. tried 2 diff. types of gear, from even with le of wing almost back to cog. to no avail. if you were in the cockpit twist in rear frame and tail was to port. take weight off of gear and twist was gone until i left the gear on over weekend and then the twist never left again. gear was dubro micro profile 935(?) and some no-name aluminum after market stuff.
any thoughts or insight, whether constructive or vindictive is accepted,
rateoneturn
and before some thoughtful person tells me that double posting is frowned upon or against the rules the other post has been closed and the realtor put up a sign that said "moved"
rateoneturn is offline Find More Posts by rateoneturn
Old Oct 07, 2011, 12:11 AM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
If you loosen the LG screws, does it un-twist?
Might be the landing gear bed(s) warped?
Rick
rick.benjamin is offline Find More Posts by rick.benjamin
Old Oct 07, 2011, 01:28 AM
Joined Nov 2010
hey rick,
no it doesn't or didn't. the only thing that would untwist it was taking the weight off of the l/gear.
i have since saved the wing and with much prejudice pulled the rest apart by hand in a fit of rage. even at rest in the plastic garbage bag, in pieces, it is still twisted as we speak or type i'm looking at the wing and it's new "body" and wondering if i should try it again without knowing what caused it initially. i really don't care about the landing gear or the tires, it's the damned wheel pants i like the look of. if 3d aircraft didn't have wheel pants i'd probably be flying crop dusters and huffing pesticides.
oh well
rot
For Sale 1/3 scale retractable Landing Gear Smyk Aircraft - Sailplanes (FS/W) 2 Sep 28, 2011 11:59 AM
Wanted 1 to 3 Landing Gear Pigtail/Extension gasturbineman Aircraft - General - Radio Equipment (FS/W) 0 Sep 12, 2011 05:52 PM
Wanted 1 to 3 Landing Gear Pigtail/Extension gasturbineman Aircraft - General - Radio Equipment (FS/W) 0 Jul 21, 2011 06:44 PM
Wanted Good used CX2 3 in 1,main frame,landing gear and upgraded parts karfrik Aircraft - Electric - Helis (FS/W) 5 May 08, 2011 10:46 PM
Help! How do you install Landing gear on a foamy? kickflipkid687 3D Flying 12 Jan 02, 2005 08:35 AM
