Old Oct 05, 2011, 08:50 PM
Joined Apr 2007
50cc Sbach 342 E/Rimfire 65cc
Hey guys, Instead of jumping on another thread I thought I would start a new one.
In the middle of testing out a new motor in my Sbach. For the past 2 seasons I ran a Turnigy c8085-170 with a 24x10 prop. Went with Boca bearing from the start with this motor. Still runs good but wanted to try something else.
Monday my Rimfire 65cc showed up. Got it installed and flew it the next day. Here is what I have found out so far.
1st flight. 25x12 Xoar gas prop. Very mild flight. 5050 watts@ 124 amps.
2nd flight. Same prop but normal flight. Mixed flying. 6500 watts @147 amps.7769rpm
3rd flight. APC 24x12 E prop. 5153 watts @ 127 amps. 8141 rpm. I used 3400 mAh in a 5 minute flight.
I mounted up my Xoar 26x10 e prop tonight but I see the winds will be gusting to 25mph tomorrow
I am using 2 5000 mAh TP 65c packs along with a CC ice 160. All data is from the controller and are in flight numbers.
All in all I think the Turnigy when new had more power. Both motors now feel the same. May end up with a 24x 12 Xoar e prop but want to at least check out the 26x10 first.
As soon as I can fly again I will post the numbers on the next prop.
Terry,
c54fun is offline Find More Posts by c54fun
Old Oct 05, 2011, 08:53 PM
flyrobert1's Avatar
United States, GA, Macon
Joined Feb 2009
nice set-up, do you have the part number to the Boca bearings on that turnigy Motor,
flyrobert1 is offline Find More Posts by flyrobert1
Old Oct 05, 2011, 08:57 PM
sml
Joined Jan 2007
Try a 24x14.
Saul
sml is offline Find More Posts by sml
Old Oct 05, 2011, 10:05 PM
Sleepy Hollow, IL
Joined Dec 2008
c54fun,
I assume you are using a 12S-5000 battery setup. You indicate the mAh and C rating but not the number of cells.
ampmaker is offline Find More Posts by ampmaker
Old Oct 05, 2011, 10:15 PM
Joined Apr 2007
I dont remember the part number for the Turnigy Boca bearings but I got the info from this site. I thing his name was Geoff or something. Also think 2 of the bearings were correct but one was not the corect size? It has been a couple of years.
Yes, 12s batterys.
Old Oct 08, 2011, 12:49 AM
Team Park Pilot - Airborne
OzparkPilot's Avatar
Australia, NSW, Sydney
Joined Nov 2006
Great Numbers ! Is it not to heavy ?
OzparkPilot is offline Find More Posts by OzparkPilot
Old Oct 08, 2011, 04:29 AM
sml
Joined Jan 2007
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXZHZ6
http://www.troybuiltmodels.com/items/BP2414.html
In my opinion, electric motors fly better with higher pitch props.
Old Oct 08, 2011, 05:42 AM
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
What is the weight of your plane and how would you rate the vertical performance?
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Old Oct 08, 2011, 11:59 AM
Joined Apr 2007
Originally Posted by sml View Post
I just recieved the 24x14 today. 40mph gust today. We have had crazy wind here the past few days. Tomorrow is only 10 to 15. Will test the 26x10 that is on it now. Then the 24x14 and I may put the 24x10 on and see how it feels. Then I will know what works best for me. My guess will be that the 26 has too much low end and the 24x14 will be the sweet spot.
My plane weighs just under 20lbs. 19.8
Terry,
Old Oct 09, 2011, 07:59 PM
Joined Apr 2007
Tried out some more props today. Here is what I found.
24x14 Xoar gas: 5850 @ 142a 7699 rpm
26x12 Xoar E : 5700 @ 132a 8025 rpm
24x12 Xoar E : 5460 @ 130a 8219 rpm
25x12 Xoar gas: 6500 @ 147a 7769 rpm
24x12 APC E : 5153 @ 127a 8141 rpm
In flight the ones that felt the best were the 24x14 and the 24x12 Xoar E prop. The 24x14 had more speed but the 24x12E prop just felt a little better.
I have the 24x12e prop on now and will try it out for a while. Still to windy around here.
Terry,
Old Oct 09, 2011, 08:00 PM
sml
Joined Jan 2007
AWESOME!! Post some video of the plane with the 24x14
Saul
Old Oct 11, 2011, 05:37 AM
On loan to Texas
Joined Oct 2005
What ESC are you using with the Rimfire 65?
Old Oct 11, 2011, 07:20 PM
Joined Apr 2007
Castle creation ice 160.
Got in two flights after work today. Flew it with the 24x14. This plane flys awesome now. The 24x14 is "sweet" Also the motor is real quiet. The Turnigy motor growled in the air. Unreal how smooth it is now. Love the 14 pitch
Terry,
Old Oct 12, 2011, 06:31 AM
USA, SC, Easley
Joined Sep 2009
That must be a rocket ship since a DA50 will swing a 22x10 at around 7000rpm if memory serves me. Been a long time since I have owned one.
yellowbird2800 is offline Find More Posts by yellowbird2800
Old Oct 12, 2011, 07:02 AM
On loan to Texas
Joined Oct 2005
Terry,
So for a plane that is in the 17-18 lb range do you think still go Rimfire 65 or the Rimfire 50?
Article Horizon Hobby E-flite UMX Sbach 342 BNF Review sun.flyer Micro RTF 46 Apr 08, 2013 08:26 PM
Help! RC Pilot Sbach 342 87"(50cc) iskoos 3D / Fun Fly Fuel Planes 6 Sep 19, 2011 11:56 AM
Discussion Gold Wing RC SBACH-342 50CC Yardbee Giant Electric Planes 47 May 03, 2011 07:06 PM
Sold Pilot Sbach 342 50cc 87" oregonrc Aircraft - Fuel - Airplanes (FS/W) 3 Nov 03, 2010 10:17 AM
Discussion Rimfire 65cc and 50cc Outrunners comming in June PORKCHOP Power Systems 1 Jun 01, 2009 09:58 PM
