Old Oct 05, 2011, 09:45 AM
DanF is offline
Find More Posts by DanF
Joined Oct 2005
Question
10% vs. 15% nitro fuels?
I fly mostly sport type engines like the OS LA series 40 & 65.
I'm thinking of changing from 15% to 10% nitro fuels to save a few bucks.The price difference is about $6 a gallon in my area.
How much performance difference will I encounter by doing this?
DanF is offline Find More Posts by DanF
Old Oct 05, 2011, 10:57 AM
jetmech05 is offline
Find More Posts by jetmech05
Jacksonville Fla.
Joined Mar 2007
Nitro acts as an oxidizer for the methonol during the burn....I doubt you'll notice a difference at full power.....you might see a slight difference at idle....once retuned you'll be ok
jetmech05 is offline Find More Posts by jetmech05
Old Oct 05, 2011, 12:10 PM
TGKconnectors is offline
Find More Posts by TGKconnectors
United States, TN, Smyrna
Joined Sep 2011
You will have to retune your engine on the high side and low side. If your engine is newer then this should not be a problem. Sometimes older engines have a temper in adjusting the low setting.
15% lets the engine run cooler, that is all we use in racing Q500.
TGKconnectors is offline Find More Posts by TGKconnectors
Old Oct 05, 2011, 02:01 PM
H&H is offline
H&H
Find More Posts by H&H
H&H
H&H Hobbies
H&H's Avatar
Old mystic CT U.S.A.
Joined Nov 2003
You won't notice a difference.
H&H is offline Find More Posts by H&H
Old Oct 05, 2011, 05:54 PM
Fokker DII is offline
Find More Posts by Fokker DII
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
Sport flying with 40 or 65 engines, you will not notice a difference. I sometimes buy 10% when they are out of 15% and the engine does not run any different even without retuning the low end in an Evo .46 and .60
Fokker DII is offline Find More Posts by Fokker DII
Old Oct 05, 2011, 06:41 PM
Dave Barrow is offline
Find More Posts by Dave Barrow
Hillary Lied, 4 Americans Died
Dave Barrow's Avatar
United States, KY, Covington
Joined Feb 2003
High nitro content is for those trying to wring every last ounce of power out of their engines. If you are just sport flying, you could even try running 5%, or mix 5 and 10 to get 7.5%
Dave Barrow is offline Find More Posts by Dave Barrow
Old Oct 05, 2011, 06:51 PM
H&H is offline
H&H
H&H
H&H Hobbies
H&H's Avatar
Joined Nov 2003
I agree. The only thing one might notice is that 15% may give easier starts in cold weather than 5%
Old Oct 06, 2011, 12:01 AM
downunder is offline
Find More Posts by downunder
downunder's Avatar
Adelaide, South Australia
Joined Sep 2003
They'll run perfectly well with zero nitro but that's hard to find in a shop so go with the lowest nitro content you can get. I use zero nitro in my OS 40/46 VF's with no problem at all but then again if the temp gets down to around 50F I sit in front of my heater so I can't comment on ease of starting in what you guys call cold .
downunder is offline Find More Posts by downunder
Old Oct 06, 2011, 02:01 AM
Elios000 is online now
Find More Posts by Elios000
United States, MO, Springfield
Joined Jul 2010
id run whats cheaper for just sport flying
i run 10% in my new .52 but my 1.00 Saito gets 30% heli fuel
Elios000 is online now Find More Posts by Elios000
Old Oct 06, 2011, 12:54 PM
Joined Sep 2011
You can not run no nitro, that is FAI fuel and you have to have a different glow plug for that plus you have to heat it so hot that it is burnt after one flight.
Stick with 10 or 15 percent, make sure the motor is tuned otherwise you will burn out the piston and sleeve.
Old Oct 06, 2011, 04:52 PM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot, 100 yrs too late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
I heard 4 strokes like higher nitro. I have .70 I'm having trouble getting to run well. I understand could be many things but several have said go to 15 from 10 and then see what you get?
Thermalin is offline Find More Posts by Thermalin
Old Oct 06, 2011, 07:30 PM
downunder's Avatar
Joined Sep 2003
Oh you have to be joking. I've been using zero nitro for more than 50 years in a huge range of engines. Plugs last just about forever although it's best to use a hot plug. On my advice, my son used zero nitro in his car engine and changed one plug in 40 hours of racing.
Old Oct 07, 2011, 12:24 AM
H&H is offline
H&H
H&H
H&H Hobbies
H&H's Avatar
Joined Nov 2003
Misinformation
Old Oct 07, 2011, 01:41 AM
Joined Sep 2011
What plugs are you using.
We use glowbee plugs on the FAI Engines. They are a pain in the butt to get lit.
Old Oct 07, 2011, 01:44 AM
Joined Sep 2011
Try running 30% heli fuel in your four stroke. My saito's used to love it.
Discussion Whats the top 5 nitro fuels to buy? hicks451 Nitro and Glow Power Cars 45 Dec 09, 2015 06:54 PM
Discussion Alternate fuels for nitro engines? lucasavaitor Engines 56 Oct 15, 2009 10:38 PM
Cool I drove all the way to Morgan fuels to get my nitro. RollingR6 Fuel Plane Talk 6 Mar 30, 2009 06:46 PM
Question Mixing Nitro fuels banannabreath Racing Boats - Internal Combustion 0 Jan 17, 2009 11:00 AM
Question Nitro Fuels p51bunny Fuel Plane Talk 2 Apr 13, 2006 07:30 AM
