Espritmodel.com Heli Air
Old Oct 09, 2012, 09:02 AM
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Please let me know how it works out.
This little plane has a misbehaving stigma attached to it that I'd like to see squashed.
I am the guy that attached it though.
All of the cartoon models fly great above 1/4 throttle but this one gets unstable at 1/2 .
That’s why I recommend that on the test flight and after the trims are set that you go up high and see how slow you can go.
This precaution will set you up for a good landing.
sparks is offline Find More Posts by sparks
Old Oct 09, 2012, 09:10 AM
Parkesflyer
RJPIoW's Avatar
United Kingdom, Ryde
Joined May 2006
I might just increase the tip chord depth as well, I have done that in the past on elliptical wings, combined with adding 1.5deg washout it stopped all the tip stalling horrors.
Richard
RJPIoW is offline Find More Posts by RJPIoW
Old Feb 13, 2013, 10:25 PM
Medicinal Foam User
Wilfor's Avatar
150 mile house B.C. Canada
Joined Jan 2010
Well apparently its been to long since i built my stang so a little reading is in order to make sure i get my wings right . Good think i read the part i thought was the 6 mm leading edge shim actually glues on top of the wing . If i actually get up at 3 am with my alarm i'll glue them on before work
Wilfor is online now Find More Posts by Wilfor
Old Feb 14, 2013, 07:34 AM
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
yes, that strip is there to keep the leading edge thick so you have material to make it round.
Thin leading edges stall without warning so don't try to make it sharp thinking you are reducing drag.
Old Feb 14, 2013, 07:52 AM
Medicinal Foam User
Wilfor's Avatar
Joined Jan 2010
Reading my mind this morning sir . Didn't have time to glue them on this morning and was thinking I'd bypass them but I won't . Really gonna Try and keep things light unlike my portly stang
Old Feb 17, 2013, 01:43 PM
Medicinal Foam User
Wilfor's Avatar
Joined Jan 2010
3 Wings now have the top sheeting on and the gluing is drying . Heading outside with the kids now to enjoy a beautiful day and hopefully i can sand up some LE tonight and maybe cut out some ailerons .
Old Feb 18, 2013, 01:27 PM
Medicinal Foam User
Wilfor's Avatar
Joined Jan 2010
Starting to look like a wing . Sanding the centre square with dihedral set at tips . I like to lay down tape so I don't dig into the foamName: image.jpg
Description:
Old May 18, 2013, 10:43 PM
tanner331's Avatar
Kenai ,Alaska
Joined Aug 2010
Hi
I am working on a cartoon spitfire.
I have made a modification so that the wing is removable. I am using bolts to hold the wing to the spitfire.
I will show more details when I finish the spitfire.
Here are some pictures.
Tanner
tanner331 is offline Find More Posts by tanner331
Old Today, 07:34 AM
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Cool modification, it should make any adjustments easy.
Thanks for posting it.
Discussion 3 ch- 5.5 inch span Cartoon Scale DR-1 triplane! Joe Malinchak Indoor and Micro Models 4 Sep 26, 2011 12:20 PM
Discussion Cartoon scale warbirds RTF/ARF Roadawg27 Electric Plane Talk 26 Sep 26, 2011 09:24 AM
Discussion Flyrc Cartoon Jets who is going to build one ofletcher Foamies (Scratchbuilt) 2 Sep 15, 2011 09:31 PM
Discussion cartoon/fattie scale warbird rtf or arf Roadawg27 Electric Warbirds 2 Sep 14, 2011 07:53 PM
Discussion cartoon spitfire may-day Foamies (Scratchbuilt) 12 Jul 05, 2009 06:11 PM
