Old Apr 03, 2012, 12:49 PM
miniman is offline
Find More Posts by miniman
Joined Sep 2004
Thanks. The conversion wasn't a problem. I made some really long sanding blocks from belt sander belts, rough cut out the foam pieces leaving spots at the corners to hot glue the parts to a big flat surface, then sanded them down until I removed all the waves which resulted in about a 3mm thickness. I cut the wings and fuse sides out of these sanded pieces. I only had to do a little adjustment so everything fit.
I was concerned that the bw motor would be a little small, but now that I have the Creators blessing, I'll go for it.
No landing gear. I fly from a field that has a gravel road for a landing strip or rough grass, so it would need really big wheels for rogs. Maybe even too big for a 'toon', if that can be
miniman is offline Find More Posts by miniman
Old May 15, 2012, 11:12 PM
sparks is offline
Find More Posts by sparks
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Big puffy wheels really add to the models character but at the same time it gives them attitude too.
come off the power and they act like speed breaks.
sparks is offline Find More Posts by sparks
Old May 16, 2012, 10:59 AM
miniman is offline
Joined Sep 2004
Progress is slow, but the wing is glued on, spinner mounted, pilot is almost ready, just need to fit the bottom panels and install the rx, esc and battery. Probably fly it before I paint it. Going with gear up because of field conditions. It's been a fun build.
Andy
Old May 16, 2012, 01:23 PM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Well I just tried to remove the gear on mine.
When I tugged on the wire to test the bond I found cracks in the foam.
(hard landings will do that )
I had to simply clip them off flush with the wing.
Headed to the field now to see how well it does with the gear gone.
Old May 17, 2012, 08:55 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Yester day was a learning experience.
The model loved not having the wheels, loops and rolls improved but the slow flight performance did not get much better.
She still tries to tip stall when it gets slow, it's just the nature of a wing with this shape.
Some wash out would improve this but I just plan to keep it at 1/4 throttle until it gets close to landing.
Old May 17, 2012, 11:22 AM
Tsavah is online now
Find More Posts by Tsavah
Watt Waster
Tsavah's Avatar
Joined Oct 2010
Spitfire - Cartoon Style
Interesting observations. How would you go about including washout in the wing design? I have been kicking around a few ideas, but thought it a good idea to ask.
Tsavah is online now Find More Posts by Tsavah
Latest blog entry: Center of Gravity - Airplanes
Old May 17, 2012, 03:34 PM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
That would be easy.
When the top sheeting is being bonded in place slide a shim under the aft outboard corner of the wing.
A tapered wedge piece along the midpoint of the aileron would work too.
I'd go with a wedge cut the length of the wing that starts at 6 or 7mm and tapers to nothing.
Old Jun 20, 2012, 02:53 PM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Anyone else want to post their build?
I'd really like to see the paint scheme you went with.
Old Jun 21, 2012, 10:57 AM
miniman is offline
Joined Sep 2004
Hey,
Mine's ready for the maiden flight, then paint, but every time I have time to fly it's been windy.
The real Spitfire didn't have much for different paint schemes. I was probably going for the tan and green camo job....
Old Aug 01, 2012, 12:01 PM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
All the dogs are on the site now and a few other cartoon pilots as well.
I don't think the boys will fit in this one though.
www.parkflyerplastics.com
Old Aug 01, 2012, 12:04 PM
Pickle72 is offline
Find More Posts by Pickle72
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
Eh heh heh, yeah. Skulls are cool
Pickle72 is offline Find More Posts by Pickle72
Old Oct 04, 2012, 05:02 PM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Said I'd be back with updates
So many of you have asked about adding a rudder.
The Cartoon ME 109 still has its wheels and tends to takeoff in a left hand turn.
little scary and some planning is involved so I decided to add a rudder.
lots of room behind the fire wall and all I had to do to install it is to poke a long wire through the bulkheads.
Taxi testes in the back yard have been very promising.
I'll be taking it to a paved runway this weekend and let you know how it did.
I'm very curious about how it handles having a rudder in flight.
Old Oct 07, 2012, 03:36 PM
RJPIoW is offline
Find More Posts by RJPIoW
Parkesflyer
RJPIoW's Avatar
United Kingdom, Ryde
Joined May 2006
She still tries to tip stall when it gets slow, it's just the nature of a wing with this shape. Some wash out would improve this but I just plan to keep it at 1/4 throttle until it gets close to landing.
A thought before I start my build - putting a 1 or 2 degrees of washout in your wing method would be reasonably easy - how about increasing the wing %depth at the tip; my experience has been fatter tips help ward off tip stall and this might be simpler to build in ? What do you think ?
Is this similar to the motor you used http://www.hobbyking.com/hobbyking/s...idProduct=5430
AX 2308N 1800kv Brushless Micro Motor
Richard
RJPIoW is offline Find More Posts by RJPIoW
Old Oct 08, 2012, 07:28 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
That is the motor I used.
Looking at the spit wing from the tip I have zero wash out built in.
When I build the next one I'll add some , it is sure to help the problems she has.
I wish I could tell you how to do it but it would be speculation.
what I do know is it has to be done with shims at the trailing edge while the top sheeting gets bonded in place.
Old Oct 09, 2012, 06:03 AM
RJPIoW is offline
Parkesflyer
RJPIoW's Avatar
Joined May 2006
Last elliptical wing I built in foam I put a 1.5 degree foam wedge under the wing tip chord, and then measured the trailing edge length back to the root and created a wedge that length and bent it under the elliptical trailing edge. Worked fine.
Ill do this on my cartoon spitfire build when I get my kit from you
Richard
Discussion 3 ch- 5.5 inch span Cartoon Scale DR-1 triplane! Joe Malinchak Scratchbuilt Indoor and Micro Models 4 Sep 26, 2011 12:20 PM
Discussion Cartoon scale warbirds RTF/ARF Roadawg27 Electric Plane Talk 26 Sep 26, 2011 09:24 AM
Discussion Flyrc Cartoon Jets who is going to build one ofletcher Foamies (Scratchbuilt) 2 Sep 15, 2011 09:31 PM
Discussion cartoon/fattie scale warbird rtf or arf Roadawg27 Electric Warbirds 2 Sep 14, 2011 07:53 PM
Discussion cartoon spitfire may-day Foamies (Scratchbuilt) 12 Jul 05, 2009 06:11 PM
