Old Oct 05, 2011, 07:21 AM
sparks is offline
Find More Posts by sparks
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Build Log
Cartoon Spitfire!
I've had a good time with the other two cartoon War birds seen here:
http://www.rcgroups.com/forums/showt...4&goto=newpost
http://www.rcgroups.com/forums/showt...5&goto=newpost
Thanks to everyone that ordered the Cartoon spitfire based on the video only . Your trust is appreciated.
This may be the most "tooned" model of the flock and if you watched the video this may be the reason it doesn't like to be upside down. ( It tends to get unstable while inverted) it is the cleanest of the flock though that is to say it has a wider speed envelope than the rest.
sparks is offline Find More Posts by sparks
Old Oct 05, 2011, 07:22 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
How could I not do a Spitfire? I'm going for a model that uses the same equipment and is the same size and weight. The control surfaces will have basically the same area in an attempt to make them fly the same as well. Like the Cartoon Mustang and ME-109 It will not require shaping the foam sheets and not be boxy. This will require some formed plastic parts that is available on the website with the printed plans/ patterns.
www.parkflyerplastics.com
You might notice that this thread is very similar to the other threads because it is. The instructions are nearly the same but the sequence may be different and I thought that a separate thread would be easier for your build.
Development
The first one was built to test the airframe for weak points and evaluate the flight qualities and to test the plastic part fit. I went with Cartoon Spitfire title because the model is not as fat as the "Fatty planes " seen elsewhere but skewed enough to "cartoon the model and allow me to exaggerate the features. The model features an easy to build airfoil so the slow flying speeds will be more stable like the rest.
Old Oct 05, 2011, 07:24 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
What you will get is the Plans and plastic parts listed on the site.
The plans would better be described as a pattern page since you don't actually build it over printed paper. The plastic parts is what makes this model go together so fast , there is no foam forming required.
The materials you will need is
One sheet of 3mm foam and less than 1/8 sheet of 6mm
Gorilla glue ( polyurethane glue)
An Out runner motor that can spin a 8 inch prop at 1800 KV
Three cell 800mah battery
10 amp ESC
Two small servos and a receiver.
Hinge material and other pieces of hardware.
Old Oct 05, 2011, 07:26 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Construction.
To build the Cartoon Spitfire I started with the fuselage. I used spray adhesive to bond the patterns to card stock , About the thickness of large mail envelopes is about right.
I carefully cut the patterns out using scissors for the curved edges and a straight edge and hobby knife for the straight cuts. These straight cuts should be made on a smooth hard surface since you have to push down fairly hard; too hard for a craft cutting board.
If you don't have a cutting board get one, when you cut sheet foam it saves blades and keeps them from getting dull.
Old Oct 05, 2011, 07:28 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
The hardest part about cutting the formers was keeping the knife 90 degrees to the building surface it's not hard at all.
When you cut the 3mm side panels cut them at the same time. This ensures that they are identical.
Before they are separated mark the former locations at the same time for the same reason. Note that the wing saddle curve should be cut oversized.
This is to be sure there is material available for a perfect fit when the wing mates with the fuselage. To cut the saddle for some extra material I simply slid the pattern down 1/8inch when I cut that portion of the fuselage sides.
Old Oct 05, 2011, 07:33 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
fuselage crutch
I started assembly with a former test fit. Each former notch is roughly 1/16 small on purpose this makes it necessary to bow the sides slightly to get the formers to fit in the notch. Starting from the front to back I added the formers. Pairs of short tape strips was used to trap the formers in place on the marks and provided clamp pressure. .
We need the wing already but keep in mind that there is still lots that can be done with the fuselage while the wing goes together. Later, when the thread covers it I'll direct you to the steps that can be completed.
Note: there has been a development in the firewall construction.
I have damaged two planes to a cartwheel.
They were gentle enough that it should not have hurt the plane.
When the prop shaft contacts the ground it pushes the motor stick inward.
This caused long cracks from the corners of the mounts and draws the sides inwards.
The models were still intact but has to be dissembled for repair.
So, On the back of F-1 and F-2 add a 3 inch disk, 6mm thick.
This should distribute the force and prevent damage.
Old Oct 05, 2011, 07:44 PM
gustorecoil is offline
Find More Posts by gustorecoil
United States, FL, Miami
Joined Jan 2009
awesome planes spark! i have my kit all ready to start the build. any news on p-40?
gustorecoil is offline Find More Posts by gustorecoil
Old Oct 07, 2011, 10:44 AM
g00se is offline
Find More Posts by g00se
Talk to me...
g00se's Avatar
Joined Aug 2006
Wow, these look great!! I'm interested now ---and if you do build a P-40, I will be ordering it!
g00se is offline Find More Posts by g00se
Old Oct 07, 2011, 12:14 PM
lessram is offline
Find More Posts by lessram
Crash-safe
lessram's Avatar
Baar, Switzerland
Joined Oct 2006
Just watched the youtube vid.
In your comment you write "This is a flight demonstration of the Parkflyerplastics ME-109 Cartoon model."
Shame on you !
lessram is offline Find More Posts by lessram
Old Oct 07, 2011, 05:14 PM
Wilfor is offline
Find More Posts by Wilfor
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
He has built a P40 its just not finalized yet , i want to get it and the 109 once i get the stang and spit done
Wilfor is offline Find More Posts by Wilfor
Old Oct 11, 2011, 06:42 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
The threads, order demands, fun flys, my job , house chores and weather have all caused delays to the P-40.
So far it has not test flown but the drawing is very close to being complete.
All that is left is fitting all the patterns and illustrations on the allotted page space, sort of like a puzzle.
So far I have managed to keep the patterns and instructions in separate areas so you are not reading chopped up print .
It's #1 on my to do list but there is a line. Family, job, website orders, My project list.
Old Oct 11, 2011, 06:46 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
now that we have a fuselage we need a wing
This wing construction method uses no ribs, as a weight saving measure the wing has several tapered spars that give it strength and the airfoil shape we need. The wing is built from the bottom sheeting up by using the pattern from the plans to lay out a 3mm sheet. The pattern will need holes poked in them to locate where the spars start a slight turn. These holes are used to mark the locations.
With the Spar locations transferred from the pattern to the sheeting with a pen. The spars are bonded with polyurethane glue to the bottom sheeting using weights for clamp pressure.
Clamp the straight portion of the spars then bend them to meet the tip marks. not hard to do with a helper.
Old Oct 11, 2011, 06:48 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
The tops of the spars are square and will require light sanding to give them a curve so the top sheeting will not have humps on the surface. Using a sanding bar wide enough to bridge between the spars will help to ensure the angles blend between them.
Before you start sanding, mark the spars with a highlighter pen. This will help you keep track of your progress. Once you are finished sanding; place a strip of foam across the spars and check for gaps.
Old Oct 11, 2011, 06:53 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Cut the top sheeting using the pattern, add about 3/16 inch in chord length to the leading edge to allow for the curve of the wing.
To protect the work surface and to keep from bonding the wing to the table top; use packing tape strips along the edges of the wing. Apply glue to all the spars and the trailing edge.
Have the leading edge shim handy to put under the leading edge and as far around the tip as you can. ip. Bond the sheeting from the trailing edge working forward applying small weights as you go.
Once the sheeting is in place and weighted down, check that the wing tip skins are making contact. To close any gaps small foam wedges can be used. let the panels dry completely.
Old Oct 11, 2011, 06:55 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
In order to get the slight curve to the bottom of the wing a relief cut is made from the first spar to the leading edge at the wing root. The leading edge shim is placed under the leading edge during the top sheeting bonding step to raise it higher making the curve needed.
Discussion 3 ch- 5.5 inch span Cartoon Scale DR-1 triplane! Joe Malinchak Scratchbuilt Indoor and Micro Models 4 Sep 26, 2011 12:20 PM
Discussion Cartoon scale warbirds RTF/ARF Roadawg27 Electric Plane Talk 26 Sep 26, 2011 09:24 AM
Discussion Flyrc Cartoon Jets who is going to build one ofletcher Foamies (Scratchbuilt) 2 Sep 15, 2011 09:31 PM
Discussion cartoon/fattie scale warbird rtf or arf Roadawg27 Electric Warbirds 2 Sep 14, 2011 07:53 PM
Discussion cartoon spitfire may-day Foamies (Scratchbuilt) 12 Jul 05, 2009 06:11 PM
