Old Mar 15, 2012, 02:14 PM
Ron_Dog is offline
Find More Posts by Ron_Dog
High Tech Red Neck
Ron_Dog's Avatar
United States, IL, Lawrenceville
Joined Nov 2011
Originally Posted by Aviefly View Post
You need to get the Yak then, he does have a helmet on
Yah! You know how them Yak pilots fly!
Ron_Dog is offline Find More Posts by Ron_Dog
Old Mar 15, 2012, 02:43 PM
shunyata is offline
Find More Posts by shunyata
'tis nothing
shunyata's Avatar
United States, CA, Napa
Joined Dec 2011
Speaking of the Telink planes, are they in the upgrade stream as well? I may need to own one this summer.
shunyata is offline Find More Posts by shunyata
Old Mar 15, 2012, 03:09 PM
shunyata is offline
'tis nothing
shunyata's Avatar
Joined Dec 2011
Sorry for the cross post, but I think all TH customers need to know who their supplier really is!
Old Mar 15, 2012, 03:27 PM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
Not exactly how I pictured Brad...
JC
JC Spohr is offline Find More Posts by JC Spohr
Old Mar 15, 2012, 03:54 PM
hercdriver7777 is offline
Find More Posts by hercdriver7777
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Columbia SC
Joined Feb 2005
Actually, that is a pretty good likeness for Brad.
hercdriver7777 is offline Find More Posts by hercdriver7777
Old Mar 15, 2012, 04:06 PM
Ron_Dog is offline
High Tech Red Neck
Ron_Dog's Avatar
Joined Nov 2011
I thought it was just a matter of time (being around that much Crack) before he was hooked! Ron
Old Mar 15, 2012, 04:15 PM
Ron_Dog is offline
High Tech Red Neck
Ron_Dog's Avatar
Joined Nov 2011
You can mix and match, too. I have a parallel board with deans and the balance connectors. To charge the 2S bats with the JST connectors, I use a JST cable and get the balance from the para board. That way I don't need a balance cable for the JST bats.
Nice to be able to charge 6 at once.
Just got the 6 lead charge cable,and a 6 lead balance cable! When I hooked them up and started charging 6 battery's,it kicks off and displays "battery over capacitance"? Do I have to set the capacity higher? Ron
Old Mar 15, 2012, 04:21 PM
shunyata is offline
'tis nothing
shunyata's Avatar
Joined Dec 2011
Hmmm. What sort of charger are you using?
I know on my setup, the order in which you plug things in matters. Plug in all battery leads first, then the balance leads. And when I'm using the para board, the charger likes the balance leads attached in a specific order as well or the charger throws an error.
Old Mar 15, 2012, 04:48 PM
Ron_Dog is offline
High Tech Red Neck
Ron_Dog's Avatar
Joined Nov 2011
It's a Gen's Ace IMars Charger. I just hit the charge button again,and it charged for a while,then once more,and it said charge complete! It's reading the capacity of all the packs in parallel I guess? Maybe I should increase the battery capacity on the charger to 2760 mAh? Ron
Old Mar 15, 2012, 05:08 PM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
That would be my guess Ron. By joining six 460mah 2s packs in parallel you've created a 2760mah 2s pack. I've never done parallel charging but it could be a good idea with the amount of packs I can get through these days.
Aviefly is offline Find More Posts by Aviefly
Old Mar 15, 2012, 07:24 PM
Ron_Dog is offline
High Tech Red Neck
Ron_Dog's Avatar
Joined Nov 2011
Yeah,I had to adjust the capacity 2700 mAh to get it to work right! I charged 6 battery's in 23minutes,then I checked each one. They all were in balance,and at 4.19V per cell! I set the current to 4 C,This is going save alot of time. Ron
Old Mar 15, 2012, 07:51 PM
shunyata is offline
'tis nothing
shunyata's Avatar
Joined Dec 2011
Ah, that makes sense. I never considered it since my iCharger came with a default setting of 5000mAh.
Just remember that the batteries should be of similar charge state. If there's a big difference, put them in different groups. You can intermix various capacities of the same number of cells. But you probably already knew that.
I still usually charge at 1C. 6 charge just as fast as one. So sweet.
Old Mar 15, 2012, 07:53 PM
itsmillertime is offline
Find More Posts by itsmillertime
United States, TN, Memphis
Joined Dec 2011
Charge up 6 and fly two, then put those two back on charge while flying the remaining 4 and you can fly all day on just 6 batteries. I only have 5 and can fly indefinitely.
itsmillertime is offline Find More Posts by itsmillertime
Old Mar 15, 2012, 07:57 PM
Ron_Dog is offline
High Tech Red Neck
Ron_Dog's Avatar
Joined Nov 2011
Yeah,this is gonna be sweet! Ron
Old Mar 15, 2012, 07:59 PM
Ron_Dog is offline
High Tech Red Neck
Ron_Dog's Avatar
Joined Nov 2011
Since I'm kinda lazy I like to charge all 10 packs up, then as I start to get low, I throw a few on charge again! Sometimes I don't get to fly all ten packs,so I discharge them when I get home! Ron
Discussion Twisted Hobbys - RC Factory USA Sbach 342 39" Build Thread & Flight Video!!!!! aerofundan 3D Foamies 497 May 24, 2015 08:01 AM
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 1007 May 21, 2015 03:02 PM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
