Old Mar 09, 2012, 10:29 AM
cwojcik is offline
Find More Posts by cwojcik
Extremely Twisted
cwojcik's Avatar
United States, NH, Epping
Joined Oct 2005
Originally Posted by shunyata View Post
Didn't find any soft tubing but I did find some rubber bands that might work. I can tape down the loose ends to keep them away from the prop.
I simply use rubber screws to soft- mount my motors. Works great!
cwojcik is offline Find More Posts by cwojcik
Old Mar 09, 2012, 10:39 AM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
Me too but it is hard as hell keeping the screw driver in the screw head.
JC
JC Spohr is offline Find More Posts by JC Spohr
Old Mar 09, 2012, 10:41 AM
blueapplepaste is offline
Find More Posts by blueapplepaste
blueapplepaste's Avatar
United States, TX, Keller
Joined Jul 2009
Great idea on the servo grommets!! I think I need to futz with thrust angle on my new Slick, and that'll beat the heck out of washers.
blueapplepaste is offline Find More Posts by blueapplepaste
Old Mar 09, 2012, 10:55 AM
cwojcik is offline
Extremely Twisted
cwojcik's Avatar
Joined Oct 2005
There was a guy I used to fly with who would soft-mount his motors with rubber standoffs and 1/4-20 nylon screws so they would break away in a crash instead of ripping the firewall off his plane. However this was on 15 lb, 1/4 scale planes with a 35cc glow motor. He also used standard plastic gear servos on 4.8V. Interesting guy to fly with to say the least.
Old Mar 09, 2012, 12:11 PM
Ron_Dog is offline
Find More Posts by Ron_Dog
High Tech Red Neck
Ron_Dog's Avatar
United States, IL, Lawrenceville
Joined Nov 2011
Yeah,the fuel tubing worked great,I got the Slick dialed in where you can just let go,and it will hang there torque rolling! Beat's the heck out of add,removing spacer,and washers to get it right! My only concern is if the screws will stay tight? Small O rings would work well also! Ron
Ron_Dog is offline Find More Posts by Ron_Dog
Old Mar 09, 2012, 01:05 PM
JC Spohr is offline
3D Hack
JC Spohr's Avatar
Joined Jul 2010
I really like the tubing/grommet method but I'm reluctant for the reason you stated Ron.
Will they stay put? Occasional tweaking needed?
Mike and others who have used this method - your comments?
JC
Old Mar 09, 2012, 04:12 PM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
JC
This method works great, it only needs occasional tweaking because that's an inherrant characteristic of EPP planes that get bashed around the way these do. The whole point of this mounting system is the ease with which you can do the tweaking. Once you get used to it, if you feel it's out of adjustment all it takes to straighten it out is a couple twists of a screwdriver and your good to go.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old Mar 09, 2012, 04:37 PM
Mike Smart is offline
Find More Posts by Mike Smart
Mike Smart's Avatar
Aylesbury, Buckinghamshire, Great Britain (UK)
Joined Jan 2000
JC
The screws stay tight, I always tap the screws into the wood first, take them out and cyano the threads and then re-assemble so they are tight. They may need adjusting occasionally if you are in the habit of hitting the ground
Mike Smart is offline Find More Posts by Mike Smart
Old Mar 09, 2012, 05:00 PM
Ron_Dog is offline
High Tech Red Neck
Ron_Dog's Avatar
Joined Nov 2011
Hopefully,the wind will lay tomorrow,or if it dosen't I'm going flying anyway! I've had 2 calm days since I've started flying these planes,but tomorrow looks like it will be good! http://www.usairnet.com/cgi-bin/laun...=KLWV&state=IL Ron
Old Mar 09, 2012, 05:23 PM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
The rubber bands might work :-) you could always wind them up for a bit of extra power
Aviefly is offline Find More Posts by Aviefly
Old Mar 09, 2012, 05:37 PM
JC Spohr is offline
3D Hack
JC Spohr's Avatar
Joined Jul 2010
Ron,
You may be in luck. Supposed to be 55* and 5 mph wind here tomorrow.
Guess where I'll be at noon.
JC
Old Mar 09, 2012, 06:19 PM
Ron_Dog is offline
High Tech Red Neck
Ron_Dog's Avatar
Joined Nov 2011
Ron,
JC
Yup,me too! I couldn't stand it anymore and went out for some flights! I flew 4 packs out,or 20 minutes of pure bliss! The wind was @ 10-13mph but almost steady,hardly any gust. My fingers almost froze off,but it was worth it! The mount screws stayed secure,and the plane flew completely neutral,in all axis! Thanks,for the tip,Mike. You have converted me into a dampening/adjustable mount guy! Ron
Old Mar 09, 2012, 07:58 PM
Burke, VA
Joined Sep 2009
Eggs-ack-lee!
Old Mar 10, 2012, 05:52 AM
Ron_Dog is offline
High Tech Red Neck
Ron_Dog's Avatar
Joined Nov 2011
I see some post about getting 6 min flight time out of the 450 battery's? Mine come down at 3.7-8 V per cell stopping at 5 minutes? And they are 460 mAh? Also do you leave your battery's charged ahead of time to go flying? I use to,but left them too long,and had cells "puff" after 2 weeks. Now I charger them right before I go out,to the field. It would be nice to charge them the night before,and save some time getting ready. So how long, is too long,to leave a pack charged? Ron
Old Mar 10, 2012, 08:29 AM
shunyata is offline
Find More Posts by shunyata
'tis nothing
shunyata's Avatar
United States, CA, Napa
Joined Dec 2011
No expert here, but I charge the batteries when I return from the field. They sit all week charged, they'll drop a tiny bit over the week. I don't top them off before use. How much difference is the flight time between 4.20 and 4.18? Nada.
If I run 6 minutes, the 460 Nano's end up around 85%. Timer set to 5 min, and I don't sweat running over if the mojo is flowing.
My sense is no harm to leave them charged for 2-3 weeks. After that, I put them in storage.
shunyata is offline Find More Posts by shunyata
Discussion Twisted Hobbys - RC Factory USA Sbach 342 39" Build Thread & Flight Video!!!!! aerofundan 3D Foamies 497 May 24, 2015 08:01 AM
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 1007 May 21, 2015 03:02 PM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
