Old Mar 09, 2012, 04:11 AM
Mike Smart's Avatar
Aylesbury, Buckinghamshire, Great Britain (UK)
Joined Jan 2000
Originally Posted by RFairbairn View Post
Cool. Great idea, something new to play around with
Ron, Is that your Slick? I have that same mtr on my Edge and while the new 1800kv works well on my CY, I think I like the old one better, pretty equal pwr, but with the older mtr I'm getting about 1.5min longer flight times and I like the extended shaft so it holds the prop better/easier.
Mike, on the bigger planes like the Telink, do the grommets need to be somewhat compressed so the torque doesn't compress them and change the angle under load?
I generally use quite hard grommets on the Telinks, but in all cases you need to start to compress the grommets as a 'base setting' to make sure you have a good solid mount before starting to adjust the thrust angle. If you do that, I haven't found that there is any variation under motor torque.
Mike Smart is offline Find More Posts by Mike Smart
Old Mar 09, 2012, 04:20 AM
High Tech Red Neck
Ron_Dog's Avatar
United States, IL, Lawrenceville
Joined Nov 2011
Mike,the weatherman say's low winds tomorrow,can't wait to try out your "mount mod"! This is alot easier,than adding/removing washers! Thanks,Ron!
Ron_Dog is offline Find More Posts by Ron_Dog
Old Mar 09, 2012, 04:23 AM
High Tech Red Neck
Ron_Dog's Avatar
Joined Nov 2011
Originally Posted by shunyata View Post
Great, I install the 1500 and the longer prop and my penetration will not be as deep. Alas, the story of my life.
Don't sell it short,until you have flown it! Diffrent strokes,for diffrent folks! Ron
Old Mar 09, 2012, 05:32 AM
Mike Smart's Avatar
Joined Jan 2000
Ron, for once the weatherman says it will be relatively calm Saturday and Sunday here in the UK as well
Old Mar 09, 2012, 05:35 AM
Mike Smart's Avatar
Joined Jan 2000
Yes you may prefer it, its all down to personal taste.
Old Mar 09, 2012, 05:40 AM
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
Mmm and I'm working all weekend :-( hope to get some indoor action in in the evenings though :-) that's been a life saver this winter.
Aviefly is offline Find More Posts by Aviefly
Old Mar 09, 2012, 06:52 AM
STLAV8R's Avatar
United States, MO, St Louis
Joined Jan 2009
Ron, its about time you get some low winds! So what is the mount mod? You using it to set the thrust angles? Have fun flying! John
STLAV8R is offline Find More Posts by STLAV8R
Old Mar 09, 2012, 08:04 AM
High Tech Red Neck
Ron_Dog's Avatar
Joined Nov 2011
Yeah,Mike came up with the idea to use some servo gomets,or silicone tubing to make adjustable mounts! I've already got a set On the Slick V2,and they adjusted very easy! Sure is alot easier than adding removing washers! http://www.rcgroups.com/forums/showp...postcount=1042 Ron
Old Mar 09, 2012, 08:57 AM
'tis nothing
shunyata's Avatar
United States, CA, Napa
Joined Dec 2011
Trying to dig up some tubing around the ranch here to mess with the thrust angles. Looks like we have two more days of sun and then we're into a wet spell for at least 10 days.
shunyata is offline Find More Posts by shunyata
Old Mar 09, 2012, 09:00 AM
STLAV8R's Avatar
Joined Jan 2009
So are you adjusting the thrust angles by the thickness of the grommet or silicone tubing? John
Old Mar 09, 2012, 09:13 AM
Mike Smart's Avatar
Joined Jan 2000
Yes like this, you tighten the screw to compress it on the side/top/bottom that you want to alter.
Old Mar 09, 2012, 10:01 AM
'tis nothing
shunyata's Avatar
Joined Dec 2011
Didn't find any soft tubing but I did find some rubber bands that might work. I can tape down the loose ends to keep them away from the prop.
Old Mar 09, 2012, 10:08 AM
Mike Smart's Avatar
Joined Jan 2000
I think you'll need something a bit thicker.
Old Mar 09, 2012, 10:10 AM
'tis nothing
shunyata's Avatar
Joined Dec 2011
My god, MAN! Where's the sense of humor around here!?!
Old Mar 09, 2012, 10:11 AM
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
I thought it was funny lol
hone1er is offline Find More Posts by hone1er
Discussion Twisted Hobbys - RC Factory USA Sbach 342 39" Build Thread & Flight Video!!!!! aerofundan 3D Foamies 320 May 22, 2013 01:25 AM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 510 May 11, 2013 03:11 PM
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 990 Apr 19, 2013 10:38 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 76 Aug 30, 2012 12:08 AM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
