Old Mar 08, 2012, 09:44 AM
Mike Smart is offline
Find More Posts by Mike Smart
Mike Smart's Avatar
Aylesbury, Buckinghamshire, Great Britain (UK)
Joined Jan 2000
Works really well Ron, I have been using it for years, it enables you to make quick adjustments at the field so you can easily adjust between flights until you get it spot on. I use this method on the larger Telink models as well and when the motor mount holes permit, I use socket head servo screws as they are easier to adjust with an Allen wrench.
Mike Smart is offline Find More Posts by Mike Smart
Old Mar 08, 2012, 11:15 AM
Ron_Dog is offline
Find More Posts by Ron_Dog
High Tech Red Neck
Ron_Dog's Avatar
United States, IL, Lawrenceville
Joined Nov 2011
Mike,you have me thinking now! Do you think I could make some,out of this 3/32 silicone fuel tubing? I think I could cut some rings off the end of the tubing with a razor blade? Ron
Ron_Dog is offline Find More Posts by Ron_Dog
Old Mar 08, 2012, 11:18 AM
shunyata is offline
Find More Posts by shunyata
'tis nothing
shunyata's Avatar
United States, CA, Napa
Joined Dec 2011
Mike is Smart!
shunyata is offline Find More Posts by shunyata
Old Mar 08, 2012, 11:28 AM
Ron_Dog is offline
High Tech Red Neck
Ron_Dog's Avatar
Joined Nov 2011
Yes he is! That's what's great about this forum! Everyone sharing knowledge/experience. If they had had the INTERNET years ago,it would have saved me allot of headaches! Ron
Old Mar 08, 2012, 11:44 AM
Mike Smart's Avatar
Joined Jan 2000
I'm sure you could Ron, make them a bit longer than the final gap planned between the motor and mount, so you can compress them with the screws. I'll post a couple of pictures when I get home.
Old Mar 08, 2012, 11:51 AM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
I've been doing my foamy motor mounts this way for a couple years as well, only way to go. But instead of the rubber hose I use a soft clear vinyl hose for a more positive feel. The added benefit is if you nose in it also acts as a little bit of a shock absorber to help minimize damage.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old Mar 08, 2012, 12:31 PM
Ron_Dog is offline
High Tech Red Neck
Ron_Dog's Avatar
Joined Nov 2011
Yeah,this acts like a "dampa" mount they make for glo/gas engines. This has to be one of the greatest tips,so far! Ron
Old Mar 08, 2012, 02:48 PM
Mike Smart's Avatar
Joined Jan 2000
Here's my Telink Extra Slick and Crack Yak motors on their soft mounts.
Old Mar 08, 2012, 03:53 PM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
Great idea Mike. I've never played with thrust lines on any of my foamies and never thought I had any ill effects from it. Your method makes sense to give it a go and see what difference it can make. When I read about it I wondered about using servo grommets, looks like that's what you have on there. I think someone else mentioned it too, think it was Stark over in the Edge thread. By the way, when you said that you prefer the 1800 motor does that mean you tried the 1480 version?
Aviefly is offline Find More Posts by Aviefly
Old Mar 08, 2012, 04:22 PM
Burke, VA
Joined Sep 2009
The first time I saw the idea of using the hose for adjusting the thrust angle was on a manufacturers kit, but I forget the brand and model. This was a couple of years ago. Although on the Telink kits I havn't done this because it seems to stay pretty solid with the motor mount tied into the cf rods buried in the fuse.
Old Mar 08, 2012, 04:52 PM
Mike Smart's Avatar
Joined Jan 2000
Aviefly,
I started doing it on my Depron indoor models to get them trimmed out properly, or just to trim out any building errors. It also became useful to re-adjust the thrust after the noses got a few repairs.
I first saw it on a CST Katana kit that I bought, but they used pieces of the harder type of petrol fuel tubing. I just adapted it a bit using servo grommets and cap head screws. My favourites were the old style grommets which tapered almost to a point as used on MacGregor servos in the 70's. As I flew for their display team at the time, I had a lot of them - all gone now sadly.
Certainly on my Depron models, after I had found the right CofG, I found that I could improve the tracking in knife edge by playing with the thrust line.
Yes I have tried the 1480 version with the 9" prop, albeit on the Edge, while the 1800 is on my Crack Yak. I just find that the 1800 with smaller prop accelerates better and has better penetration in wind outside.
Old Mar 08, 2012, 09:25 PM
shunyata is offline
'tis nothing
shunyata's Avatar
Joined Dec 2011
Great, I install the 1500 and the longer prop and my penetration will not be as deep. Alas, the story of my life.
Old Mar 08, 2012, 10:16 PM
RFairbairn is offline
Find More Posts by RFairbairn
RFairbairn's Avatar
United States, SC, Simpsonville
Joined Aug 2011
Cool. Great idea, something new to play around with
Ron, Is that your Slick? I have that same mtr on my Edge and while the new 1800kv works well on my CY, I think I like the old one better, pretty equal pwr, but with the older mtr I'm getting about 1.5min longer flight times and I like the extended shaft so it holds the prop better/easier.
Mike, on the bigger planes like the Telink, do the grommets need to be somewhat compressed so the torque doesn't compress them and change the angle under load?
RFairbairn is offline Find More Posts by RFairbairn
Old Mar 08, 2012, 10:31 PM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
And with all that torque, you may need to adjust your thrust angle...
JC Spohr is offline Find More Posts by JC Spohr
Old Mar 09, 2012, 04:07 AM
Ron_Dog is offline
High Tech Red Neck
Ron_Dog's Avatar
Joined Nov 2011
Yes it is! I too favor the lower KV motors! I find just the opposite about wind penetration.My 1500's with a bigger prop seem to "pull" much stronger in the wind,and out of a hover! Plus they help balance the plane,better! Your right about the extended motor shaft! I cut the shaft flush with the propsaver on my first 1500 motor,but now know,that was a mistake.The shaft helps keep the prop running true on the propsaver.Ron
Discussion Twisted Hobbys - RC Factory USA Sbach 342 39" Build Thread & Flight Video!!!!! aerofundan 3D Foamies 497 May 24, 2015 08:01 AM
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 1007 May 21, 2015 03:02 PM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
