Old Mar 05, 2012, 06:12 PM
Gravitycheat is offline
Find More Posts by Gravitycheat
Don't give in to gravity
Gravitycheat's Avatar
USA, FL, Palm Harbor
Joined Dec 2009
Originally Posted by Dan5.0 View Post
In the words of Shawn
"Edge-sick Slick-sicker Yak-sickest"
The Yak is the extreme 3D performer, where the Edge is more docile and floatier, and the Slick falls right in the middle.
Yup
Gravitycheat is offline Find More Posts by Gravitycheat
Old Mar 07, 2012, 05:30 PM
Ron_Dog is offline
Find More Posts by Ron_Dog
High Tech Red Neck
Ron_Dog's Avatar
United States, IL, Lawrenceville
Joined Nov 2011
The V2 Slick,is a great plane,much of the same flying traits as the original,but much more ridged! The roll rate on mine is NUT'S! Ron
Ron_Dog is offline Find More Posts by Ron_Dog
Old Mar 07, 2012, 05:50 PM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
+1
The v1 flew great...
V2 Slick is pure awesome!
Roll rate is insane (set to 45* w/ 75% expo) but super controllable.
JC
JC Spohr is offline Find More Posts by JC Spohr
Old Mar 07, 2012, 06:03 PM
Ron_Dog is offline
High Tech Red Neck
Ron_Dog's Avatar
Joined Nov 2011
Originally Posted by JC Spohr View Post
+1
JC
Yeah,and it flys like it's on rails! The best I can remember! This weather stinks! Ron
Old Mar 07, 2012, 07:57 PM
JC Spohr is offline
3D Hack
JC Spohr's Avatar
Joined Jul 2010
100% agreement on the "rails" - "precision flight" are the words that come to my mind. It tracks extremely well.
I can do waterfall after waterfall with v2. My v1 always kicked out to the right no matter how hard I tried to control it.
JC
Old Mar 07, 2012, 08:36 PM
shunyata is offline
Find More Posts by shunyata
'tis nothing
shunyata's Avatar
United States, CA, Napa
Joined Dec 2011
Think it's time I played with the CG on mine. I set all ours very neutral, and I'm thinking a little more tail heavy might be worth a shot. Ya think?
shunyata is offline Find More Posts by shunyata
Old Mar 07, 2012, 09:17 PM
Ron_Dog is offline
High Tech Red Neck
Ron_Dog's Avatar
Joined Nov 2011
Never hurts to try! I've had planes that I thought flew great, to fly even better with a few adjustments. Now I can't leave them alone! LOL! I even made a copy of your smiley face prop,with a little change,since mine end up in the dirt alot! Oh NO! It's Mister Bill! Ron
Old Mar 07, 2012, 09:40 PM
JC Spohr is offline
3D Hack
JC Spohr's Avatar
Joined Jul 2010
It's rarely mentioned but adjusting your thrust angle may be needed. It was the final tweak that made mine groove.
I talked with Ron on the phone this evening and shared how I tested and what I adjusted. Let me know if you want a phone call (on my dime). PM me your number if you do.
JC
Old Mar 08, 2012, 12:14 AM
Stark is offline
Find More Posts by Stark
Don't worry be happy :)
Stark's Avatar
Joined Sep 2001
.... how I tested and what I adjusted.
I've been thinking about this with the thrust angle to. Please tell us about your findings!
Stark is offline Find More Posts by Stark
Old Mar 08, 2012, 06:49 AM
STLAV8R is offline
Find More Posts by STLAV8R
STLAV8R's Avatar
United States, MO, St Louis
Joined Jan 2009
How do you adjust the thrust angle? And how will it effect the flight characteristics?
STLAV8R is offline Find More Posts by STLAV8R
Old Mar 08, 2012, 07:30 AM
Ron_Dog is offline
High Tech Red Neck
Ron_Dog's Avatar
Joined Nov 2011
Ok,Guy's! I like to either fly the plane or set it up in a hover. Then make note if it want's to fall off,in one direction (this is in a hover). If it falls to the right,just remove the little mounting screw on the right side of the motor mount,then add a small thin washer,between the mount and the motor flange,like a spacer! Test again,and see if it's corrected. Then if the plane (in a hover again) wants to pull to the top (come towards you ) add a washer to the top mount. You should be able to get the plane very stable in a hover this way,and you have corrected the thrust line to near 0 - 0 degrees. Also when outside flying with the plane trimmed out for level flight,and then when you go inverted,it may want to climb (even after setting the C/G the best you can get it) it will need a little "up thrust" to counteract the climbing tendency,while inverted! Once you get the thrust dialed in your plane will fly alot better in all flight axis! Hope this helps! Here's a very fuzzy pic! (My camera/and or operator dosen't take clear closups!) Ron
Old Mar 08, 2012, 08:48 AM
STLAV8R is offline
STLAV8R's Avatar
Joined Jan 2009
Thanks for the info. Ron. Very interesting... I will check mine out. John
Old Mar 08, 2012, 08:52 AM
Mike Smart is offline
Find More Posts by Mike Smart
Mike Smart's Avatar
Aylesbury, Buckinghamshire, Great Britain (UK)
Joined Jan 2000
If you insert a rubber servo grommet or short piece of silicon tube between the motor and the mount on the model when you install it and pass the motor screws through it, you don't need to play with washers. You simply screw in the motor screws until they just start to compress the rubber and then tighten the relevant ones some more to adjust the thrust angle. Makes a quieter mounting as well
Mike Smart is offline Find More Posts by Mike Smart
Old Mar 08, 2012, 08:55 AM
JC Spohr is offline
3D Hack
JC Spohr's Avatar
Joined Jul 2010
Ron beat me to it. See his post #1031 immediately above. And let me add....
i trimmed for upright flight first, then inverted, then knife edge, and finally in a hover. For hover trimming, get the plane to a throttle setting that will let you hand launch to hover. Then... release plane and don't touch the controls. Watch which way it falls. Do this several times - make sure you are holding it reasonably close to vertical as possible. Add a small washer under the motor flange that is in the direection of fall.
Examples: In my case, mine fell toward the left wing and also to the canopy. I added 1 washer on the left wing side motor flange screw and 1 washer on the canopy (top) motor flange screw. That's all mine needed.
bestest to see if more thrust angle change (washers) might be needed.
When you have it correct, your plane will fly perfect upright, inverted and won't as readily fall out of a hover. There will be no ballooning effect from low thottle to WOT. Note - after I trimmed for upright, inverted, and KE flight; mine would slightly climb when a took a long upright high speed pass. that said thrust angle to me.
Make sure you trim in the order above - upright, inverted, KE and hover last.
JC
Old Mar 08, 2012, 08:56 AM
Ron_Dog is offline
High Tech Red Neck
Ron_Dog's Avatar
Joined Nov 2011
That's a great idea,Mike! Ron
Discussion Twisted Hobbys - RC Factory USA Sbach 342 39" Build Thread & Flight Video!!!!! aerofundan 3D Foamies 497 May 24, 2015 08:01 AM
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 1007 May 21, 2015 03:02 PM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
