Old Feb 05, 2013, 08:02 AM
Dan5.0 is offline
Find More Posts by Dan5.0
Dan5.0's Avatar
Joined Dec 2008
That would be my ph setting right , for acid battery?
Dan5.0 is offline Find More Posts by Dan5.0
Old Feb 05, 2013, 08:52 AM
cale10 is online now
Find More Posts by cale10
3dizzle 4 lyfe
cale10's Avatar
United States, OH
Joined Jul 2011
Originally Posted by Stark View Post
The T-2004 is only good for 3D models up to a weight of 150 grams or 5,3 oz so you probably need another motor.
From T-Motor the older T-2006 is perfect or the new with slightly lighter weight, AT-2204. Twisted Hobbys 2203-1750KV 19g is very similar or maybe even identical.
The slight overweight is nothing to be worried about.
will one of these work?
http://www.hobbyking.com/hobbyking/s...ner_Motor.html
^^^^^^^^^^^^^^ has 240 grams of thruts or 8.5 OZ at a weight of 21.2 grams
http://www.hobbyking.com/hobbyking/s...er_1900kv.html
^^^^^^^^^^ has 360 grams of thrust or 12.7 OZ of thrust at a weight of 20.9 grams.
which is best? remember im on a budget too.
cale10 is online now Find More Posts by cale10
Old Feb 05, 2013, 09:09 AM
Stark is offline
Find More Posts by Stark
Don't worry be happy :)
Stark's Avatar
Joined Sep 2001
The first one I knew about and that's a motor for models at 5 oz of weight and below. The second one is unknown to me.
This motor is really good together with the GWS 8x4.3 SF: TURNIGY 2204-14T 19g Outrunner
Weight of the plane around 6oz.
This one is a re branded T-2006. Very powerful. Can be used for a 7 oz model with power to spare: HobbyKing 2612 Brushless Outrunner 1900KV
Hope this helps.
Stark is offline Find More Posts by Stark
Old Feb 05, 2013, 09:16 AM
swampflyer is offline
Find More Posts by swampflyer
United States, FL, Keystone Heights
Joined Dec 2012
question for you guys
i got a question for you guys that have or have had a Dx6i transmitter...
can you get the servo travel above 100%?
ive seen it mentioned, but for the life of me, i cant get anything to go over 100% throws... be awesome if i could.. i realize this transmitter is severely limited in what i can do..
thanks guys. (i did look in the manual by the way)
swampflyer is offline Find More Posts by swampflyer
Old Feb 05, 2013, 09:19 AM
3dizzle 4 lyfe
cale10's Avatar
United States, OH
Joined Jul 2011
it only goes to 125% throw. futaba however goes to 140%.
Old Feb 05, 2013, 09:20 AM
Joined Dec 2012
how do you get it over 100%?
i roll the wheel and it stops at 100....?
3dizzle 4 lyfe
cale10's Avatar
United States, OH
Joined Jul 2011
Hope this helps.
thanks! will the first onw work for good 3d? also will it work on 3s(maybe idk if i'll ever do that though)? and will it work on a 10 amp esc with a 8x4 prop?
Old Feb 05, 2013, 09:23 AM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
You should be able to go into "travel adjust" in the menu and increase it there. Just make sure whenever you do that the servo moves as you increase the %. If you get to 105% and the servo won't move any further when you keep increasing the travel than back it off back to 104%. This will keep your servos from being over worked which will fry the servo.
hone1er is offline Find More Posts by hone1er
Old Feb 05, 2013, 09:27 AM
Joined Dec 2012
perhaps im thinking of D/R and Expo.... i could swear i tried the travel adjust menu... i'll give it a go a bit later on.. thanks.
Old Feb 05, 2013, 09:30 AM
hone1er is offline
Team Twisted!
hone1er's Avatar
Joined Dec 2011
Most radios can also increase the D/R past 100% but i don't believe you can do that on the DX6i.
On my Hitec Aurora 9 i can go to 140% on the travel adjust("EPA" on my radio)and also 125% on the D/R
Old Feb 05, 2013, 09:33 AM
Kris... is offline
Find More Posts by Kris...
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
Correct to increase over a 100% is done in the travel adjust in the DX6I.
Kris... is offline Find More Posts by Kris...
Old Feb 05, 2013, 09:42 AM
Joined Dec 2012
if 125% travel is 100% of your available throw... what does putting D/R above 100% do? i thought putting D/R to 100% with the travel set to 125% would get you 100% of that travel...
boy thats confusing.
Old Feb 05, 2013, 09:45 AM
Stark is offline
Stark's Avatar
Joined Sep 2001
Yes the Turnigy 2204-14T will work great for 3D. You can probably use the GWS 8x4 DD, but the GWS 8x4.3 SF is the optimal prop for this motor on 2 cells, in my experience. I've used it myself in the Crack Yak Lite.
You can even try the 9x4.7 SF if you are only using short burst of full throttle.
You can use 3 cells but you have to use the throttle wisely or use the GWS DD 7x3.5 prop to not overload the motor. The 10 amp ESC is perfect for the job.
Old Feb 05, 2013, 10:05 AM
3dizzle 4 lyfe
cale10's Avatar
United States, OH
Joined Jul 2011
yay! whats a double D prop?
Old Feb 05, 2013, 10:08 AM
hone1er is offline
Team Twisted!
hone1er's Avatar
Joined Dec 2011
Direct drive.
Discussion Twisted Hobbys - RC Factory USA Sbach 342 39" Build Thread & Flight Video!!!!! aerofundan 3D Foamies 497 May 24, 2015 08:01 AM
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 1007 May 21, 2015 03:02 PM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
