Old Jan 28, 2013, 08:59 AM
KamikazePilot is offline
Find More Posts by KamikazePilot
Twisted Do Nut!
KamikazePilot's Avatar
Joined Dec 2010
Originally Posted by 3flyguy3 View Post
No, the motor wasn't doing this before. I originally had the twisted combo. Long story short, I used the rx from my Edge to test something on another plane. When I plugged everything back up I got no response (no happy tune from esc, no motor). So I got a Turnigy motor and HK esc to try to rule out bad motor or esc. Turned out the esc died. So now I'm currently using the Crack 2204/1450 and the HK esc. Start up and ran fine for awhile, now I'm getting the stutter start.
What radio system are you using? The end points lugz mentioned is travel adjustment on the dx6i. Pretty sure it is on the 8 too, waiting for the my 8 to get back from Horizon.
KamikazePilot is offline Find More Posts by KamikazePilot
Old Jan 28, 2013, 09:13 AM
wayfaringdreamer is offline
Find More Posts by wayfaringdreamer
wayfaringdreamer's Avatar
United States, PA, Middletown
Joined Sep 2011
Are you guys talking about end point adjustments on the throttle?
wayfaringdreamer is offline Find More Posts by wayfaringdreamer
Old Jan 28, 2013, 09:16 AM
jimbo320 is offline
Find More Posts by jimbo320
Slopeaholic
jimbo320's Avatar
Joined May 2011
Ive got to the point now, where removing the motor for repairs has meant that when i try to screw my screws into the foam on the other side of the motor mount, i dont get any purchase. That is the holes around where the screws would sit are fresh air. Im using servos screws to attach the motor.
Is there any solution to this? Any way i can fill that gap?
Its not like there is a hole in the foam with crash damage etc, its just that the screws wont hold (any of them).
Cheers,
jimbo320 is offline Find More Posts by jimbo320
Old Jan 28, 2013, 09:35 AM
swampflyer is offline
Find More Posts by swampflyer
United States, FL, Keystone Heights
Joined Dec 2012
maidened a fresh CYL airframe the other day, that i put the carbon fiber uprades on... apparently didnt put enough welders on the motor mount and a slight bump on the prop took the motor mount/screws/motor/prop right off the plane.
holes where the screws where like you are saying.
i just filled em with welders. let it dry. it shrinks a bit after its cured so i added a bit more after it shrunk a few times. built it up and filled the small spots the foam was mising at nicely. glued the motor mount back on really well this time. all the screws grabbed the welders really well also. put a tiny bit of welders on screws before i screwed em in as well.
swampflyer is offline Find More Posts by swampflyer
Old Jan 28, 2013, 09:46 AM
Twisted Do Nut!
Joined Dec 2010
Thick CA works in the same way. Used it when holes were worn on my nitro cars.
Old Jan 28, 2013, 09:47 AM
Joined Dec 2012
good to know.
i was worried it would get too hard and be to difficult (or impossible) to get the screws through the stuff....
Old Jan 28, 2013, 10:52 AM
jimbo320 is offline
Slopeaholic
jimbo320's Avatar
Joined May 2011
So do you drill it out with a pilot after its glued up?
Ive tried the welders trick but i find it just gets gooey and harder to remove the screws.
I seem to be doing a lot of motor maintenance since i started using 3S, so i need to be able to remove the screws at will.
I only have thin cyano. OK?
Old Jan 28, 2013, 10:57 AM
carr52 is offline
Find More Posts by carr52
carr52's Avatar
United States, SC, Irmo
Joined Mar 2012
The first time you use your new esc have the throttle stick at full. Plug in the battery and wait or the tones and then move the stick to the bottom. Unplug the battery, turn off the Tx. At least thats how I do it. Now just turn on the Tx and plug in the battery as you normally do.
carr52 is offline Find More Posts by carr52
Old Jan 28, 2013, 12:24 PM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
Originally Posted by swampflyer View Post
just a friendly reminder from your neighborhood aspiring 3D'er...
props hurt when they hit you in the forehead.
if your going to hover close in make sure the wind isnt blowing AT YOU.
lol.
no real damage. bruised forehead and ego.
had to happen while the mother in law was watching, commenting on how impressed she was. haha.
Hahaaa
I'm now wishing your mother in law had the camera phone out
Aviefly is offline Find More Posts by Aviefly
Old Jan 28, 2013, 01:02 PM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
Hey guys here is a short flight video of the removable wing version of the Telink Extra 330. I'm also uploading a video showing how the wing assembly works.
Telink extra 330 removable wing flight video (1 min 35 sec)
EDIT: Demonstration of the wing assembly
Telink extra 330 removable wing demonstration (2 min 1 sec)
hone1er is offline Find More Posts by hone1er
Old Jan 28, 2013, 03:17 PM
Twisted Do Nut!
Joined Dec 2010
Thin ca might work, I used thick since it takes longer to dry hence time to fill the holes. Here's how I did it back then, apply the ca to screw (or parts your trying to fill holes) and screw it in once it's dry a bit loosen the screw to break the ca loose from the screw.
Nice hone1er looks like the removeable wing works good.
Old Jan 28, 2013, 08:51 PM
lugnutz is offline
Find More Posts by lugnutz
The Twisted Elf
lugnutz's Avatar
USA, NJ, Trenton
Joined Nov 2010
your radio is set to or has a high and low end point,commonly set to 100%,the esc is factory set for a high and low but doesn't see your radios high or low.so what should be done is once you determine that you have your throttle set for correct movement,such as low stick down,you unplug your battery and with the radio still on move your throttle stick to high,plug in your battery on your esc and wait for the double beep ,once heard move your throttle stick to low and it will beep again ,and now your esc will see your radios true high and low
ESC Prg (1 min 55 sec)
lugnutz is offline Find More Posts by lugnutz
Old Jan 28, 2013, 09:17 PM
Twisted Do Nut!
Joined Dec 2010
Oh ok you were talking about throttle calibration. Gotcha!
Old Jan 28, 2013, 09:19 PM
3flyguy3 is offline
Find More Posts by 3flyguy3
3flyguy3's Avatar
United States, IL, Waukegan
Joined Apr 2012
Originally Posted by lugnutz View Post
your radio is set to or has a high and low end point,commonly set to 100%,the esc is factory set for a high and low but doesn't see your radios high or low.so what should be done is once you determine that you have your throttle set for correct movement,such as low stick down,you unplug your battery and with the radio still on move your throttle stick to high,plug in your battery on your esc and wait for the double beep ,once heard move your throttle stick to low and it will beep again ,and now your esc will see your radios true high and low http://vimeo.com/47736257
A couple things. I never set end points when I first got my twisted esc. The video says I would have no response until I completed the setup. Not knowing any better when I first got my power combo I just plugged and played. Worked fine.
My twisted esc died so now I'm using a HK esc. Is the method to set the end points the same or need I check the manual for the HK esc?
So it goes back to my initial question, having never set end points on my current esc and I didn't have any problems until now, why now am I experiencing this stuttering? Are you still suggesting try setting end points?
3flyguy3 is offline Find More Posts by 3flyguy3
Old Jan 29, 2013, 07:28 AM
cdee is offline
Find More Posts by cdee
Team Twisted!
cdee's Avatar
United States, CO, Denver
Joined Jun 2011
Very nice.. thanks for the video on wing Assembly!
cdee
cdee is offline Find More Posts by cdee
Discussion Twisted Hobbys - RC Factory USA Sbach 342 39" Build Thread & Flight Video!!!!! aerofundan 3D Foamies 497 May 24, 2015 08:01 AM
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 1007 May 21, 2015 03:02 PM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
