Old Oct 10, 2012, 07:05 AM
fierce is offline
Find More Posts by fierce
fierce's Avatar
LI NY
Joined Sep 2008
1. 22 includes Gas & electric and helis
2. 7 have a heli on he bench now, Pilot Yak in final stages, now my Extra Slick(waiting on servos)
I really like that idea with the neon paint markers, I'm going to get some.
fierce is offline Find More Posts by fierce
Old Oct 10, 2012, 09:31 AM
3171scott is offline
Find More Posts by 3171scott
3171scott's Avatar
United States, OH, Youngstown
Joined Apr 2011
Originally Posted by Azarr View Post
I'm with you, I don't understand the love for the little Hitecs
Futaba 3114: 8g, 21oz torque, .10 sec transit
Futaba 3154: 8g, 21oz torque, .10sec transit
Hitec HS-35, 4.5g, 11oz torque, .10sec transit
Hitec HS-45, 8g, 14oz torque, .14sec transit
To me, the Futaba is a clear winner. I usually run a 3154 on the ailerons and 3114s on the tail. I'll give up a few grams for the torque and at .14sec, the HS-45 is a snail . The advantage of the HS servo is a beefier gear train although I've never broken a set of gears on the Futabas.
For a 5g servo, the Dymond D47s is lightening fast at .08 transit speed with 16oz of torque. The slower D47 @ .14sec transit has 20oz of torque.
Azarr
I agree with you on outdoor planes, i went with 3154 all the way around on my crack slick and on my pits i went with 3156 on the ailerons and 54's on the tail, But we are talking about indoor planes and trying to keep them as light as possible. So if you are putting a 21 oz on the ailerons witch are the the largest control surface, and there are two, why would 11 oz on each tail surface not work? Buy using the 35's you almost save the weight of one servo. Not saying that 54 all the way around would make the new crack yak light fly bad, just fly a little lighter! Just my thoughts
3171scott is offline Find More Posts by 3171scott
Old Oct 10, 2012, 09:59 AM
markl22 is offline
Find More Posts by markl22
Joined Jul 2012
1. 22
markl22 is offline Find More Posts by markl22
markl22 is offline
Joined Jul 2012
2. 4
Old Oct 10, 2012, 10:04 AM
JForbes is offline
Find More Posts by JForbes
Parkfly Padawan
JForbes's Avatar
United States, PA, Waynesburg
Joined Aug 2011
Thanks for the feedback guys. I no longer think I have a lot of planes with just having 5 or 6 ready to go... lol.... This also helps in my conversations with the Mrs.... "Yea, but honey, I only have 6 or 7.... some guys have over 20.... see, it's not THAT bad..." lol....
JForbes is offline Find More Posts by JForbes
Old Oct 10, 2012, 11:37 AM
Aaeolien is offline
Find More Posts by Aaeolien
3d addict
United States, NY, Rochester
Joined May 2011
Lol Jforbes my wife can't figure out why I have more than 1. Her response. You can only fly 1 at a time.
Aaeolien is offline Find More Posts by Aaeolien
Old Oct 10, 2012, 11:38 AM
JForbes is offline
Parkfly Padawan
JForbes's Avatar
Joined Aug 2011
ha... I've finally gotten out of that question.... it had been asked though.
Old Oct 10, 2012, 11:41 AM
Aaeolien is offline
3d addict
Joined May 2011
Not sure my wife pays attention enough to notice that I bring 4 or 5 to fly and only come home with 1 that still is flyable with the rest needing fixing. Haha. Someday it'll click.
Old Oct 10, 2012, 11:59 AM
pugsam is offline
Find More Posts by pugsam
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
Originally Posted by Aaeolien View Post
......Her response: You can only fly 1 at a time.
Tell your wife she should be very happy that you accept that theory -- as applied to women -- but she shouldn't push her luck by trying to stretch it to airplanes!
pugsam is offline Find More Posts by pugsam
Old Oct 10, 2012, 03:05 PM
3flyguy3 is offline
Find More Posts by 3flyguy3
3flyguy3's Avatar
United States, IL, Waukegan
Joined Apr 2012
Numbers on motor
What do the numbers mean on the motors? For instance 2203-1750kv or 2204-1450kv or 2206-1450kv.
I can't figure out if my motor or esc is bad so I was just going to buy new ones to figure out which is bad, as I don't have a spare of either. I currently have the Crack Series 2204-1450, but I want to know the difference between the above so I can decide if I go with the same or different (for different performance I assume).
3flyguy3 is offline Find More Posts by 3flyguy3
Old Oct 10, 2012, 08:18 PM
nkhamlue is offline
Find More Posts by nkhamlue
Build em lite......
Joined Apr 2012
Ask her, "how many pairs of shoes she has?"....you can only wear one at a time....
nkhamlue is offline Find More Posts by nkhamlue
Old Oct 10, 2012, 08:26 PM
MountainMike is offline
Find More Posts by MountainMike
United States, LA, New Orleans
Joined Jan 2012
I am just learning but I believe the first numbers are for the size 22 (diameter)? and 04 (depth)? this is not a standard on every outrunner motor. From what I understand the second set 1750 and 1450 are rpms per volt. The heavier (bigger) the motor the more power you can get out of it but with power comes amps and that draws the batteries down quicker. I am learning as I go along so someone please correct me if I am wrong.
MountainMike is offline Find More Posts by MountainMike
Old Oct 10, 2012, 08:33 PM
3flyguy3 is offline
3flyguy3's Avatar
Joined Apr 2012
So the research I found seems to coincide with what you said. Now how do I determine the motor I need or in my case, I'm replacing my motor/esc can I chose a different motor than I currently have (2204-1450kv)? Why would I want to? Why would I not?
Old Oct 10, 2012, 08:54 PM
KamikazePilot is offline
Find More Posts by KamikazePilot
Twisted Do Nut!
KamikazePilot's Avatar
Joined Dec 2010
I'm a newb to the whole number theme as well. I go by power to weight ratio when I'm hunting for a motor. 5oz plane then a 10oz + thurst motor is on my list. I know some might have a better way to do it but this is how I do it. Sorry to hear you didn't get your problem solved.
KamikazePilot is offline Find More Posts by KamikazePilot
Old Oct 10, 2012, 09:19 PM
Joined Jan 2012
I do not have a twisted hobbys plane YET. But I have been doing quite a bit of research towards which airframe suits me. There 2204-1750 is only good for 2s while the other two 2204-1450 and 2206-1450 are good for 2-3s. Once you determine what battery option you use and if you need all the power and extra weight to fly outdoors (wind) then choose appropriately, but keeping in mind that the more power the more amps and shorter flight times on 2s, 3s should run less amps and provide longer flight times but again I have 0 experience. I am looking to make a decision soon so I can have some fun.
Discussion Twisted Hobbys - RC Factory USA Sbach 342 39" Build Thread & Flight Video!!!!! aerofundan 3D Foamies 497 May 24, 2015 08:01 AM
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 1007 May 21, 2015 03:02 PM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
