Old Sep 28, 2012, 04:44 AM
missileman is offline
Find More Posts by missileman
United States, FL, Lake Mary
Joined Jul 2012
I just got my Flash D in the mail Wednesday and the Crack Yak I ordered for my son should be here tomorrow. Hope to fly one on Sunday... can't wait!
I am debating on if I should install the landing gear. I always fly in a grass field, not always maintained well. I Have seen gear get ripped off other planes causing damage. Lots of people just belly land in the grass.
Anyone have any thoughts or experiences with these planes and landing gear on grass?
missileman is offline Find More Posts by missileman
Old Sep 28, 2012, 05:26 AM
Kris... is offline
Find More Posts by Kris...
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
Yeah i have landed in grass long and short with know problems with the landing gear, I would not worry your good to go missileman.
Kris... is offline Find More Posts by Kris...
Old Sep 28, 2012, 06:11 AM
docbrew is offline
Find More Posts by docbrew
docbrew's Avatar
United States, TN, Gallatin
Joined Aug 2012
No landing gear here. I float it in and plop it on the ground or hand catch. Heck mine get doinked into the ground way more than floating in As long as you are landing on grass I wound't worry about landing gear.
docbrew is offline Find More Posts by docbrew
Old Sep 28, 2012, 08:19 AM
cdee is offline
Find More Posts by cdee
Team Twisted!
cdee's Avatar
United States, CO, Denver
Joined Jun 2011
Originally Posted by JForbes View Post
Would you say it's worth a motor upgrade for those flying on 2s, or maybe better suited just for the 3s users?
Both the 24g and 26g motors are very nice, the 26g will give you a little more power, but also drains the battery a little quicker, so it's a bit of a trade off. If you are happy with your current setup probably no reason to upgrade, but certainly consider the 26g on your next build.
cdee
cdee is offline Find More Posts by cdee
Old Sep 29, 2012, 11:12 PM
3flyguy3 is offline
Find More Posts by 3flyguy3
3flyguy3's Avatar
United States, IL, Waukegan
Joined Apr 2012
Motor or ESC?
I "borrowed" my orange rx from my Edgd over to another plane to text its esc. Turns out the esc was fine. I put the rx back on the Edge and I have all surface movement and LEDs but no motor. The esc doesn't doesn't arm. So is the issue the motor or the esc? Why would a functioning esc/motor stop working after I reinstalled the rx?
3flyguy3 is offline Find More Posts by 3flyguy3
Old Sep 30, 2012, 12:02 AM
Kris... is offline
Registered Addict
Kris...'s Avatar
Joined Jul 2010
Try adding a couple of down clicks on the throttle trim then see if your esc arms.
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Check your trim and subtrim on your throttle. Make sure your throttle is low. Make sure you haven't reversed your throttle channel. Rebind. Just generic things to try that are related to what your report. After that, try a different ESC with the receiver, or a different motor with the ESC.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Sep 30, 2012, 06:28 AM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
You might have to recalibrate the throttle endpoints.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old Sep 30, 2012, 09:06 AM
3flyguy3 is offline
3flyguy3's Avatar
Joined Apr 2012
Ok, I'll try the suggested. I did rebind, no success. And even tried a different esc with the rx. Rx is fine on the other esc/motor. I even tried a different rx on the suspect esc/motor. The other motor/esc I have, don't fit the bullet connectors. Would I have to solder up some connections to fit the Slicko motor and Twisted esc? Or is it safe to electric tape them temporarily?
Do you know off hand if that's covered in the manual for the DX6i? I can't look at this very moment. If it's not covered, do you know how?
Old Sep 30, 2012, 06:01 PM
Burke, VA
Joined Sep 2009
You have to calibrate throttle endpoints through the ESC, so you have to check the manual for the ESC to see how to do it using your transmitter. Usually you turn on the trans, move the throttle stick all the way up, then turn on the esc and wait for a couple of beeps then move the throttle stick down and it should arm itself and do the normal startup beeps. But check your esc manual to be sure.
Old Sep 30, 2012, 06:18 PM
cdee is offline
Team Twisted!
cdee's Avatar
Joined Jun 2011
ESC Arming....
For the Twisted Hobbys' ESC, there is a short video on how to initialize it, on the Twisted Hobbys' site - ESC pages
cdee
Old Sep 30, 2012, 07:27 PM
3flyguy3 is offline
3flyguy3's Avatar
Joined Apr 2012
Tried setting up throttle calibration per video...nothing. No response.
Old Oct 02, 2012, 01:37 AM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
We had the first proper indoor session on Saturday night. Here is a video of some of the mayhem that ensued, watch for the crash session at the end The only casualty after all that abuse was one eight inch prop and a slightly loose motor mount, we left with everything still flyable fun fun fun
Warning this video contains aircraft abuse
First indoor mayhem and madness 2012 (5 min 16 sec)
Aviefly is offline Find More Posts by Aviefly
Old Oct 02, 2012, 02:51 AM
Kris... is offline
Registered Addict
Kris...'s Avatar
Joined Jul 2010
Man looks like you had fun mate wish there was an indoor session near me.
Old Oct 02, 2012, 05:40 AM
Mike Smart is online now
Find More Posts by Mike Smart
Mike Smart's Avatar
Aylesbury, Buckinghamshire, Great Britain (UK)
Joined Jan 2000
Ours start again on 11th October - can't wait
Mike Smart is online now Find More Posts by Mike Smart
Discussion Twisted Hobbys - RC Factory USA Sbach 342 39" Build Thread & Flight Video!!!!! aerofundan 3D Foamies 497 May 24, 2015 08:01 AM
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 1007 May 21, 2015 03:02 PM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
