Old Aug 16, 2012, 08:16 AM
JForbes is offline
Find More Posts by JForbes
Parkfly Padawan
JForbes's Avatar
United States, PA, Waynesburg
Joined Aug 2011
Well, you could make your slot a little bigger, and whatever you cut out from that, glue it back in fore or aft from where you cut it out... so essentially, you're just moving the slot forward or back as needed. or you could just stick some velcro on the side of the fuse opposite your rx and esc and that will allow you to move the battery even more. just a thought....
...or you could just hot glue some nickles where you need them to balance it out.
JForbes is offline Find More Posts by JForbes
Old Aug 16, 2012, 08:17 AM
RCAddict16 is offline
Find More Posts by RCAddict16
United States, VA, Ashburn
Joined Apr 2012
Haha I might do that the nickles thing
RCAddict16 is offline Find More Posts by RCAddict16
Reply With Quote  (Disabled)
Old Aug 16, 2012, 09:46 AM
3dflyboy1 is offline
Find More Posts by 3dflyboy1
USA, CA, San Juan Capistrano
Joined Dec 2010
Instead of adding more weight, it would be better to cut more foam out to extend the slot and glue the foam back to fill where you had originally cut, like JForbes suggested.
3dflyboy1 is offline Find More Posts by 3dflyboy1
Old Aug 16, 2012, 09:48 AM
Joined Apr 2012
But I didn't save the foam I cut out
Old Aug 16, 2012, 10:15 AM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
If you need to move it forward, cut more of the front of the slot and glue the foam you cut out to the back of the slot. It will keep it the same size and move it forward. I have 2 slots cut on mine, 1 for 3s and 1 for 2s, so if you want you can also just cut another slot but i'd just move it forward if i were you.
hone1er is offline Find More Posts by hone1er
Old Aug 16, 2012, 10:17 AM
Joined Apr 2012
Oh good point duh! Lol. My battery is right in the middle of the spar, should I move it to right in front of the spar?
Old Aug 16, 2012, 10:24 AM
Joined Dec 2010
Lay it on the wing and move it around to see where it balances, then cut, glue, and go fly!
Old Aug 16, 2012, 10:37 AM
Joined Apr 2012
Perfect now I need some prop bands........currently I'm using a tripled over rubber band and its vibrating horribly. Black dot is the cg.
Old Aug 16, 2012, 10:39 AM
hone1er is offline
Team Twisted!
hone1er's Avatar
Joined Dec 2011
You probably have to balance the prop
Old Aug 16, 2012, 10:45 AM
cdee is offline
Find More Posts by cdee
Team Twisted!
cdee's Avatar
United States, CO, Denver
Joined Jun 2011
New Twisted Hobbys' Servos.....
these have been out for a little bit, but just got my first ones for an upcoming project. They look really nice and solid.
cdee
cdee is offline Find More Posts by cdee
Old Aug 16, 2012, 10:47 AM
Joined Apr 2012
Idk if its the prop but ill check. It was running just fine before I lost the prop band that came wit the motor. EDIT- just checked, its balanced perfectly. When I get some prop bands ill check again, the hub is scraped quite a bit from spinning on the motor. I need to use thicker band. Right now its vibrating so bad I can see the whole airframe vibrating in a hover.
Joined Apr 2012
cdee
Yeah when I get a 3dhs 42" slick I'm using the telink 48" power combo.
Old Aug 16, 2012, 10:54 AM
hone1er is offline
Team Twisted!
hone1er's Avatar
Joined Dec 2011
cdee
They have about the same specs as Hitec 65mg. I wonder how similar they really are. They could save me a bit of cash on my next small build.
Old Aug 16, 2012, 10:56 AM
Joined Apr 2012
Hone1er- edited my post.
Old Aug 16, 2012, 10:58 AM
cdee is offline
Team Twisted!
cdee's Avatar
Joined Jun 2011
yea... very similar horns too, and one nice long one.
cdee
Discussion Twisted Hobbys - RC Factory USA Sbach 342 39" Build Thread & Flight Video!!!!! aerofundan 3D Foamies 497 May 24, 2015 08:01 AM
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 1007 May 21, 2015 03:02 PM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
