Old Jul 31, 2012, 08:44 AM
KamikazePilot is offline
Find More Posts by KamikazePilot
Twisted Do Nut!
KamikazePilot's Avatar
Joined Dec 2010
Ask and you shall receive RC...ha.
Man the hobby has come a long way and companies like Brad's and a few others have kept this hobby worthwhile. From the new designs to the A plus service. And there are you guys here on the threads that help out the new guys like me. All of it is what makes this a whole lot of fun.
KamikazePilot is offline Find More Posts by KamikazePilot
Old Jul 31, 2012, 01:39 PM
Stark is offline
Find More Posts by Stark
Don't worry be happy :)
Stark's Avatar
Joined Sep 2001
Originally Posted by RCAddict16 View Post
Ughh... this is why I hate my Dx5e....... nothing happens until 1/4 throttle
It's probably not your radio, it's more likely the ESC. You have to calibrate the trottle range.
Check your manual. For most ESC you put throttle on full, connect the battery, after two fast beeps close the throttle and then you will get the usual startup tones. Ready!
Stark is offline Find More Posts by Stark
Old Jul 31, 2012, 01:44 PM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
+1. I try to do this every once in a while just to make sure the throttle range is calibrated correctly.
hone1er is offline Find More Posts by hone1er
Old Jul 31, 2012, 02:00 PM
RCAddict16 is offline
Find More Posts by RCAddict16
United States, VA, Ashburn
Joined Apr 2012
Not getting the startup tones...... do I turn the TX off and back on after the tone for the throttle setting?
RCAddict16 is offline Find More Posts by RCAddict16
Reply With Quote  (Disabled)
Old Jul 31, 2012, 02:04 PM
Stark is offline
Stark's Avatar
Joined Sep 2001
No, it is not good to turn of the transmitter in the middle of calibrating the ESC.
Are your digital throttle trim at center?
Old Jul 31, 2012, 02:11 PM
Joined Apr 2012
Is it supposed to be? I thought you always set the throttle trim to zero
Old Jul 31, 2012, 02:19 PM
Stark is offline
Stark's Avatar
Joined Sep 2001
It should be centered when using an electric motor. The ESC is designed with that in mind.
Old Jul 31, 2012, 02:30 PM
Twisted Do Nut!
Joined Dec 2010
It also depends on the ESC, some should be set at the lowest trim setting. Got some 12amp ones that way.
The ones I have from TH do fine at mid setting. Haven't tried the 12amp ones though, using the old 10amp on my planes.
Old Jul 31, 2012, 02:33 PM
Joined Apr 2012
Its weird, my throttle starts at the lowest setting. with 8 up-trims from center on the trim dial.......
Old Jul 31, 2012, 03:09 PM
Stark is offline
Stark's Avatar
Joined Sep 2001
Thats seems to be about normal to me.
You should not need to use the trim. Put it at center, calibrate the ESC and fly!
Old Jul 31, 2012, 03:25 PM
Joined Apr 2012
I guess with my CY I will set it at 9 clicks, it idles slowly at that speed and the throttle curve seems the smoothest as possible.
Old Jul 31, 2012, 03:45 PM
Stark is offline
Stark's Avatar
Joined Sep 2001
I use idle on my balsa Sebart Katana 30, but not on the foamie, because I'm little afraid that the motor or the ESC will be damaged when I done an unscheduled landing and the plane lies on the ground.
Old Jul 31, 2012, 03:52 PM
Sixinarow is offline
Find More Posts by Sixinarow
Addicted
United States, CO, Parker
Joined Dec 2011
You don't have your combo for your CY, right? Every ESC/motor is different so make sure you set your CY's ESC up for the CY motor.
Sixinarow is offline Find More Posts by Sixinarow
Old Jul 31, 2012, 04:03 PM
Aaeolien is offline
Find More Posts by Aaeolien
3d addict
United States, NY, Rochester
Joined May 2011
Let's go flying. Hehehe reasonable flying weather. Hehee
7/31/12 (0 min 44 sec)
Aaeolien is offline Find More Posts by Aaeolien
Old Jul 31, 2012, 04:05 PM
Addicted
Joined Dec 2011
I was going to fly after work (25 minutes) but it's raining. Aghhhhhhhhh!
Discussion Twisted Hobbys - RC Factory USA Sbach 342 39" Build Thread & Flight Video!!!!! aerofundan 3D Foamies 497 May 24, 2015 08:01 AM
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 1007 May 21, 2015 03:02 PM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
