Old May 16, 2012, 07:05 PM
buster7467 is offline
Find More Posts by buster7467
morgantown, wv
Joined Mar 2004
The way i understand it is that if you have a charger that will charge a 6s lipo than with a paraboard you can charge three 2s packs at once. That would be perfect.
And i am getting the paraboard from epbuddy also.
buster7467 is offline Find More Posts by buster7467
Old May 16, 2012, 07:13 PM
shunyata is offline
Find More Posts by shunyata
'tis nothing
shunyata's Avatar
United States, CA, Napa
Joined Dec 2011
Well, sort of.
Let's say you have an iCharger 106B. It can deliver up to 10 amps and with a 6 battery parallel and balancing board you could charge:
6 - 450 mah batteries at 1C would be using 2.7amps total. At 3C you'd use 8.1amps. So, you could charge 6 of these batteries close to 4C. It would be about 3.7C.
4 - 2200 mah batteries at 1C or 8.8 amps
2 - 2200 mah batteries at 2C or 8.8 amps
6 - 2200 mah batteries at less than 1C
shunyata is offline Find More Posts by shunyata
HarryOh is offline
Find More Posts by HarryOh
HarryOh's Avatar
United States, OH, Trenton
Joined Feb 2010
Originally Posted by 3flyguy3 View Post
What's a paraboard? I'd like to be able to charge more than one at a time also. Is that possible with the charger I have? (Thunder AC6)
I have the Thunder AC6 Dual Power charger and it charges upto 5a. Not sure if they have changed the max amps since I got mine, which has been awhile. I also use the ebuddy paraboard with it with no problems. I charge 6 2s 460 packs in around 37 minutes with the charger set on 5a.
HarryOh is offline Find More Posts by HarryOh
Old May 16, 2012, 07:20 PM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
Yes - I have an AC6 and it is fine for this size battery. I can do a single Gens Ace 2S 450 at 5C (2.2 Amps) in about 12 minutes.
You can get 5 Amps max out of the AC6 but using a paraboard at 5 amps you can do multiple packs pretty quickly.
JC
ps - when you want to go BIG, get a PowerLab 6 or 8. I have a PL 6 and that does a max charge of 40A for 6S (40A on 8S for the PL 8).
JC Spohr is offline Find More Posts by JC Spohr
Old May 16, 2012, 07:21 PM
lugnutz is offline
Find More Posts by lugnutz
The Twisted Elf
lugnutz's Avatar
USA, NJ, Trenton
Joined Nov 2010
i dont think that is correct,i believe that if you have a charger with enough wattage you can charge up to 6 packs,the reason i think this is because when you charge in pararell its like chargeing 1-2 cell pack but at a higher amperage.
i use the 3010 icharger with a paraboard that has a provision for 6 packs,but when i setup my charger to charge it is set for 2 cell lipo at 2.7 amps,the batteries are 450 mah.
the way this works is , you are charging 6 -450 mah packs
1-add up your mah,in this case 6x450=2700 mah
2-set your lipo charger to 2.7 amps,that is 1c charge rate
3-connect your balance leads to the paraboard then your main connector,this case a JST,to the paraboard
4- charge ,40 minutes later all done
if you want to charge faster then double the amp rate which is 5.4 amps
this is just what i do and this is only a suggestion,if you dont understand please ask for more info
lugnutz is offline Find More Posts by lugnutz
shunyata is offline
'tis nothing
shunyata's Avatar
Joined Dec 2011
So, you're charging the batteries at almost 2C using 5amps. Full 2C would require 5.4amps.
edit: I am referring to HarryOh
Old May 16, 2012, 07:22 PM
lugnutz is offline
The Twisted Elf
lugnutz's Avatar
USA, NJ, Trenton
Joined Nov 2010
wow i type slow
Old May 16, 2012, 07:25 PM
shunyata is offline
'tis nothing
shunyata's Avatar
Joined Dec 2011
If one wants to parallel charge 6 450mah bats at 5C, you'll need a charger that can put out 15amps or more.
Old May 16, 2012, 07:30 PM
lugnutz is offline
The Twisted Elf
lugnutz's Avatar
USA, NJ, Trenton
Joined Nov 2010
shunyata what are you using for a power supply,i was thinking of getting one from the classifieds with the hp power supplies wired for 24 volt 1000w
was wondering if you have any experience with them
Old May 16, 2012, 07:38 PM
HarryOh is offline
HarryOh's Avatar
Joined Feb 2010
Yes, I set the ac6 to 5a, which is max. With the paraboard hooked up, that charges them a little under 2C. I think the batteries I have are rated 4 or 5c charging rate,. I have 24 2s batteries, 450 Gens Ace and 460 nano-techs. I have 5 of TH crack series planes the my son and I fly. Well actually 4, I have not had time to build the new bipe yet. So we go thru batteries pretty fast.
Old May 16, 2012, 07:40 PM
JC Spohr is offline
3D Hack
JC Spohr's Avatar
Joined Jul 2010
I have the 24v setup from rclemmons - $80 shipped is a deal!
JC
Old May 16, 2012, 08:05 PM
3flyguy3 is offline
Find More Posts by 3flyguy3
3flyguy3's Avatar
United States, IL, Waukegan
Joined Apr 2012
Thanks all!
3flyguy3 is offline Find More Posts by 3flyguy3
Old May 16, 2012, 08:06 PM
3flyguy3 is offline
3flyguy3's Avatar
Joined Apr 2012
Thanks! PM sent.
Old May 16, 2012, 08:11 PM
shunyata is offline
'tis nothing
shunyata's Avatar
Joined Dec 2011
1000w should be enough. lol
I have this, along with the iCharger 106B. I do charge 2200 3S but never more than 3-4 at a time. Fits my needs at this point.
http://www.progressiverc.com/prc220-power-supply.html
Old May 16, 2012, 08:46 PM
morgantown, wv
Joined Mar 2004
As long as i can charge 6 of them quicker than i can charge 1 pack on the charger i have now i would be happy.
Discussion Twisted Hobbys - RC Factory USA Sbach 342 39" Build Thread & Flight Video!!!!! aerofundan 3D Foamies 497 May 24, 2015 08:01 AM
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 1007 May 21, 2015 03:02 PM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
