Old May 16, 2012, 10:05 AM
cdee is offline
Find More Posts by cdee
Team Twisted!
cdee's Avatar
United States, CO, Denver
Joined Jun 2011
Originally Posted by buster7467 View Post
For the guys that fly the TH planes with the little 2s and 3s setups, what chargers are you using to charge your lipos? I am wanting to get a good cheap charger that will allow me to charge the packs at up to 5c. I would love to be able to charge more than one pack at a time. Any help would be great.
I am using the Hitec x4... good for the lipos that are used on these size foamies and even slightly larger like the Telink stuff. Mid range on price, but you can do 4 at a time, that is nice. I usually charge at 3c (but is capable of more) just to give the batteries a little buffer.
http://www.hitecrcd.com/products/new...x4-eighty.html
cdee
cdee is offline Find More Posts by cdee
Old May 16, 2012, 10:47 AM
buster7467 is offline
Find More Posts by buster7467
morgantown, wv
Joined Mar 2004
Thanks for the info.
buster7467 is offline Find More Posts by buster7467
Old May 16, 2012, 11:00 AM
MattyB is offline
Find More Posts by MattyB
Taranis Tyro...
MattyB's Avatar
United Kingdom, England, Hitchin
Joined Jan 2004
I have an iCharger 106b and it's amazing value for money.
MattyB is offline Find More Posts by MattyB
Old May 16, 2012, 11:57 AM
3flyguy3 is offline
Find More Posts by 3flyguy3
3flyguy3's Avatar
United States, IL, Waukegan
Joined Apr 2012
cdee
I'm still confused by that. What does that mean to charge at, in this case 3c?
3flyguy3 is offline Find More Posts by 3flyguy3
Old May 16, 2012, 12:04 PM
jamesrini is offline
Find More Posts by jamesrini
USA, NJ, West Paterson
Joined Feb 2008
3c is the charge rate. For example a 2200 mah battery is 2.2 amp hour so a charge rate of 3c = 3x 2.2 = set charger for 6.6 amps.
So just substitute the 2.2 for what ever size battery you want to charge.
2200= 2.2
500= .5
jamesrini is offline Find More Posts by jamesrini
Old May 16, 2012, 12:09 PM
3flyguy3 is offline
3flyguy3's Avatar
Joined Apr 2012
Ok, that's what I thought. But isn't that harmful to the battery?
For instance, the largest battery I have is 2S 450 mah. I was advised to charge at no more than 0.4. Based off what you said, a charge rate of say 3c is 1.2 or 5c would be 2 amp. (Gens Aces 2S 450mah - per the site it says 5C charge rate acceptable)
So my biggest question is, does charging the battery at these higher rates cause damage? Should I stick with the 1c I've been using?
I just looked at the charger I have Thunder AC6 (http://www.hobbypartz.com/thac6smbachw.html)
and it says max current of 2.2a. So with the 2200 mah battery you mentioned, I could charge that battery no faster than 1 hour, correct?
Old May 16, 2012, 12:40 PM
MaddSkillz is offline
Find More Posts by MaddSkillz
Intergalctic Coffee Enthusiast
MaddSkillz's Avatar
United States, OK, Tulsa
Joined Jun 2011
The new charge rates specified by the battery manufacturers are not supposed to harm the battery. I charge all my GensAce at 5C with no ill-effects at this point.
MaddSkillz is offline Find More Posts by MaddSkillz
Old May 16, 2012, 12:49 PM
Madratter is offline
Find More Posts by Madratter
Joined Jul 2011
My opinion is that for most people, more damage is being done by leaving batteries around fully charged than by charging at more than 1c, as long as the battery is rated for it. As Madskillz indicates, my GenAce batteries are rated at 5c as are my Nanotechs. I go slightly conservative and charge at just under 4c (1.8 amps).
Of course do be careful when charging. The last thing you want to do is burn down your house.
Madratter is offline Find More Posts by Madratter
Old May 16, 2012, 01:25 PM
cdee is offline
Team Twisted!
cdee's Avatar
Joined Jun 2011
+1... agreed on the storage part, if I know I am flying the pack(s) for the last time for a little while, I will purposely cut back my flying time so that there is 40% or left in the pack when done.
cdee
Old May 16, 2012, 01:59 PM
asosestrom is offline
Find More Posts by asosestrom
United States, CA, Santa Rosa
Joined Mar 2011
Originally Posted by mattyb View Post
i have an icharger 106b and it's amazing value for money.
+1
asosestrom is offline Find More Posts by asosestrom
Old May 16, 2012, 02:02 PM
morgantown, wv
Joined Mar 2004
I am leaning toward a cheap charger and just use a paraboard for charging more than one pack at a time. I really want to be able to charge 6 packs at once. I plan on ordering one this weekend and i still need to place my order for 12 gens ace 2s packs.
Old May 16, 2012, 02:24 PM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
I went with a cheap charger when i started so i could charge 6 of these little batteries at once, but when you get into the bigger stuff like the telinks or even balsa you'll want to charge 6 big batteries at once which the icharger line are great for. I'm looking into getting the 206b. Charges up to 6s batteries at up to 20 amps or one of the http://www.progressiverc.com/fma-powerlab-8.html
they charge at up to 40 amps. I'll never need a better charger than that in my entire time in the hobby i'm sure. The only thing is you need a power supply as well. Buy big, buy once
hone1er is offline Find More Posts by hone1er
Old May 16, 2012, 03:26 PM
morgantown, wv
Joined Mar 2004
Yea i am trying to avoid having to purchase the separate power supply at the moment and i don't want to make one out of a pc power supply. I am going to get a charger that has a built in power supply and will charge at 6 amps. So that will be fine for these little packs. And my only other plane has an 1800mah 3s lipo so it can charge that one also. I am not into the big planes. Same with helis, a 450 is the biggest that i owned and never wanted anything bigger. I like the small helis and planes.
Old May 16, 2012, 06:06 PM
3flyguy3 is offline
3flyguy3's Avatar
Joined Apr 2012
What's a paraboard? I'd like to be able to charge more than one at a time also. Is that possible with the charger I have? (Thunder AC6)
Old May 16, 2012, 06:45 PM
lugnutz is offline
Find More Posts by lugnutz
The Twisted Elf
lugnutz's Avatar
USA, NJ, Trenton
Joined Nov 2010
i am using the 3010 icharger with a para board from epbuddy, works awsome
lugnutz is offline Find More Posts by lugnutz
Discussion Twisted Hobbys - RC Factory USA Sbach 342 39" Build Thread & Flight Video!!!!! aerofundan 3D Foamies 497 May 24, 2015 08:01 AM
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 1007 May 21, 2015 03:02 PM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
