Old May 12, 2012, 02:33 PM
3flyguy3 is offline
Find More Posts by 3flyguy3
3flyguy3's Avatar
United States, IL, Waukegan
Joined Apr 2012
Yep that's what I'm goona do. Found the gun but no glue. Welders it is.
3flyguy3 is offline Find More Posts by 3flyguy3
Old May 12, 2012, 03:26 PM
Madratter is offline
Find More Posts by Madratter
Joined Jul 2011
On my Telink Edge 540, I have noticed with my original ESC that the motor will sometimes start in the wrong direction. If I increase throttle, it will then stop. If it starts in the correct direction, then throttle behaves as expected.
The replacement ESC I ordered doesn't seem to do this. (I haven't observed wrong direction starts).
Is this fairly common? Does it indicate a bad ESC? A bad motor? Is it normal?
I have never seen this behavior on my 32" birds.
Thanks!
Madratter is offline Find More Posts by Madratter
Old May 12, 2012, 03:38 PM
cwojcik is offline
Find More Posts by cwojcik
Extremely Twisted
cwojcik's Avatar
United States, NH, Epping
Joined Oct 2005
Some ESC's on larger setups will stutter/barely rotate in the opposite direction for a half a turn before correcting and running properly...the ESC doesn't know where the motor is or what coils to energize when it's not turning, so it has to guess until it starts and can read the position correctly. If it runs backwards for more than a second then it's either a bad ESC or a poor connection to the ESC...make sure your bullets are properly seated, and if it can't be fixed, a new ESC is a good idea.
cwojcik is offline Find More Posts by cwojcik
Old May 12, 2012, 03:58 PM
Joined Jul 2011
Thanks. It will actually sustain it at low throttle levels. Looks like that ESC goes into the only-use-if-desperate parts bin.
Old May 12, 2012, 04:10 PM
shunyata is offline
Find More Posts by shunyata
'tis nothing
shunyata's Avatar
United States, CA, Napa
Joined Dec 2011
ESC motoring timing off maybe?
edit: Also, try setting the throttle position on the ESC as well. Cody could be right, though. Motor bullets might be wonky.
shunyata is offline Find More Posts by shunyata
Old May 12, 2012, 05:58 PM
cdee is offline
Find More Posts by cdee
Team Twisted!
cdee's Avatar
United States, CO, Denver
Joined Jun 2011
If you have any interest in the Bipe, a short while ago, I posted some thoughts after my first flights with it this morning.
cdee
cdee is offline Find More Posts by cdee
Old May 12, 2012, 08:40 PM
shunyata is offline
'tis nothing
shunyata's Avatar
Joined Dec 2011
I've been threatening to do this, now I have.
Silly Edge (0 min 31 sec)
Old May 12, 2012, 08:50 PM
pugsam is offline
Find More Posts by pugsam
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
ROFLMAO
Flight vid, please!
pugsam is offline Find More Posts by pugsam
Old May 13, 2012, 02:52 AM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
http://youtu.be/wj0cX-U0Uek
wooow that's crazy.
I thought about doing a two servo wing but never thought of three. Ingenious mechanical setup on what was the aileron servo. Crow braking and everything Why stop there, how about a four servo wing. You must have a big ass rx on there. Interested to hear how it handles the extra weight and if the braking is effective. You could have some mad mixes going on there, how about crow braking mixed to your throttle channel. Good luck with the flight's, have fun.
Aviefly is offline Find More Posts by Aviefly
Old May 13, 2012, 07:47 AM
carr52 is offline
Find More Posts by carr52
carr52's Avatar
United States, SC, Irmo
Joined Mar 2012
I'm with the rest of em. I'd love to see it in action. That is pretty cool.
Tom
carr52 is offline Find More Posts by carr52
Old May 13, 2012, 09:09 AM
shunyata is offline
'tis nothing
shunyata's Avatar
Joined Dec 2011
Avi, I thought about 4 servos but decided that this first round I'd stick with three, that way I can return to stock without much concern. If this results in some unique flying, then I'll try 4. Not getting enough throw on the ailerons, will improve that if flight proves it's worth it.
It has an Orange 8 channel FASST rx - it's HUGE in size and weighs a ton. Also, the ESC can't handle the extra servos and I ran out of my stash of UBECs, a new batch should be here this next week. Then we'll see.
It is getting a bit porky...
Old May 14, 2012, 09:48 AM
MattyB is offline
Find More Posts by MattyB
Taranis Tyro...
MattyB's Avatar
United Kingdom, England, Hitchin
Joined Jan 2004
All in a spin...
Quick question guys... I've always liked flat spinning my planes on the slope, but despite my Sbach flying awesome in every other respect I'm yet to find a way of initiating a nice, flat spin. Any tips? Is this all about CG and control inputs, or do these flat foamies not spin well because of all the side area? All suggestions welcomed...
Matt
PS - On searching this thread for "spins" I came across two acronyms to describe different types - KE and KF. I assume KE indicates a knife edge spin, but what does KF mean?
MattyB is offline Find More Posts by MattyB
Old May 14, 2012, 09:59 AM
StormJunkie is offline
Find More Posts by StormJunkie
Whoooo!
StormJunkie's Avatar
Summerville, SC
Joined Jan 2009
While you're at it with that funky setup, you should throw one of those new aero variable pitch prop motors on there.
StormJunkie is offline Find More Posts by StormJunkie
Old May 14, 2012, 01:03 PM
Aviefly is offline
Aviefly's Avatar
Joined Feb 2005
Matt
My guess is KF is a typo, can't think what else it would be. I find it hard to do a real nice flat spin with these too. I never have worked out what I've done different when one works out and looks good. I think maybe it just a very fine balance of just the right amount of throw, yes you can have too much, and just the right amount of power, not enough and it just falls out of it, too much and it flips out of it. Practice makes perfect
Old May 14, 2012, 04:00 PM
e-gull is offline
Find More Posts by e-gull
Joined Feb 2008
Twisted Hobbys EDGE 540 (5 min 39 sec)
At about :42, :57, 1:42, 2:20, and 3:35, ect. Daniel did some upright and KE tiny spirals. Would you call that Flat and KE Spins? Does the plane need to be more stalled? Does the plane need to rotate about one leg of the plane or on it's wing tip?
e-gull is offline Find More Posts by e-gull
Discussion Twisted Hobbys - RC Factory USA Sbach 342 39" Build Thread & Flight Video!!!!! aerofundan 3D Foamies 497 May 24, 2015 08:01 AM
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 1007 May 21, 2015 03:02 PM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
