Old Apr 25, 2012, 10:54 PM
crobar is offline
Find More Posts by crobar
crobar's Avatar
United States, ID, Athol
Joined Apr 2009
Originally Posted by DB in WA View Post
crobar, which 540 the 32 in.?
It's the 32" Ege 540 HB.
crobar is offline Find More Posts by crobar
Old Apr 25, 2012, 11:25 PM
DB in WA is offline
Find More Posts by DB in WA
USA, WA, Lake Stevens
Joined Jan 2011
My hb 540 comes in without battery at 5.7 oz.with the TH light kit. The flash and rs 352 both come in at about 13.7 oz without battery. The flash and the rs352 are compleatly different animals than the 32"planes.I built both one for me and got paid to build the flash and maidened it . They are all around bigger way faster and have the mass to do more stunts where the mass is needed. I love mine. they do have airfoiled wings a 7/8" backbone, landing gear in the kit. I run gens ace 1000mah 3 s and a hyperion 2213 18 and a 10x4.7 it has tons of power. The flash ran the stock TH power pack and is no slouch by any means. Hope this helps. DB.
DB in WA is offline Find More Posts by DB in WA
Old Apr 25, 2012, 11:38 PM
DB in WA is offline
Joined Jan 2011
OH great its gonna be a 3 plane month in May A 3DHS buck huck on its way ,cabon cub with floats when it's finally shipped and a crack bipe I can't wait to hit order on,and a PA addiction in the box with all the bits but the bipe will be pushed to the front of the line as they are just too much fun can't wait. I just Love bipes.
Old Apr 25, 2012, 11:59 PM
crobar is offline
crobar's Avatar
Joined Apr 2009
Thanks DB - That was what I was hoping to hear. I love the way the 32" edge flies but I wanted something a little heavier & larger that would handle the wind a bit better. I appreciate all the detailed info. Are the RS352 and the Flash identical planes or is there a difference in the shape?
Old Apr 26, 2012, 12:09 AM
DB in WA is offline
Joined Jan 2011
The flash has a slightly smaller/differant shape rudder than the rs 352 but run it til it almost hits the elevator it will pull 6 foot ke loops at 3/4 throttle and a differant canopy and has a better /more visible color scheme.It will do the nicest elevators/elevator landings with the nose into the slightest breeze.I think it flys quite close to blasa in the same wing span.
Old Apr 26, 2012, 05:35 AM
Gravitycheat is offline
Find More Posts by Gravitycheat
Don't give in to gravity
Gravitycheat's Avatar
USA, FL, Palm Harbor
Joined Dec 2009
The new plane looks cool. To bad it was not realesed in time for SEFF. Leaving in about an hour to head up there. Looking forward to it.
Gravitycheat is offline Find More Posts by Gravitycheat
Old Apr 26, 2012, 06:24 AM
STLAV8R is offline
Find More Posts by STLAV8R
STLAV8R's Avatar
United States, MO, St Louis
Joined Jan 2009
Originally Posted by Twisted Realm View Post
As promised here are some pics of our new Crack-Series Pitts Biplane. Sorry about photo quality, the pictures don't do the printing justice. Pretty excited for this release since a lot of hard work from multiple teams went into developing this bird the results are truly stellar. Should have these bad boys and all details available for you guys very soon.
Awesomeness!
STLAV8R is offline Find More Posts by STLAV8R
Old Apr 26, 2012, 07:28 AM
Bigugly is offline
Find More Posts by Bigugly
Mesquite Tx
Wow. The Crack Bipe looks awesome. I think its the best looking foamy biplane I have ever seen.
Bigugly is offline Find More Posts by Bigugly
Old Apr 26, 2012, 11:30 AM
aerofundan is offline
Find More Posts by aerofundan
aerofundan's Avatar
Panama
Joined Jul 2005
WOW! that looks spectacular!!!!!!
aerofundan is offline Find More Posts by aerofundan
Site Sponsor
Old Apr 26, 2012, 10:27 PM
shunyata is offline
Find More Posts by shunyata
'tis nothing
shunyata's Avatar
United States, CA, Napa
Joined Dec 2011
Halfway there to a home-built Edge bi. Whatcha think? Can't wait for the dealer, have to take care of biz on my own. Betty Ford is calling!!!!
shunyata is offline Find More Posts by shunyata
Old Apr 26, 2012, 11:17 PM
carr52 is offline
Find More Posts by carr52
carr52's Avatar
United States, SC, Irmo
Joined Mar 2012
That is cool. How'd you do the aile and mount the upper wing? Dual servos? Looks like I have to buy more EPP. I think everyone wants to build a bi-plane. I know I do. Nice looking plane.
Tom
carr52 is offline Find More Posts by carr52
Old Apr 26, 2012, 11:33 PM
itsmillertime is offline
Find More Posts by itsmillertime
United States, TN, Memphis
Joined Dec 2011
Tom
That's digital trickery.
itsmillertime is offline Find More Posts by itsmillertime
Old Apr 27, 2012, 12:21 AM
crobar is offline
crobar's Avatar
Joined Apr 2009
Sounds like a good flyer.
Old Apr 27, 2012, 07:16 AM
MattyB is online now
Find More Posts by MattyB
Taranis Tyro...
MattyB's Avatar
United Kingdom, England, Hitchin
Joined Jan 2004
Cracked the Sbach!
A week or so ago two of you were kind enough to guide me re: set up on my 32” Sbach…
Originally Posted by ccpdx View Post
I think you want to do most of your tweaking with CG and not with thrust angles. I'd move your CG back to the point where it flies the same upside down as it does right side up - without diving or ballooning. Also don't use any elevator trim which isn't needed in the same amount and in the same direction for both upside down and right side up. Hopefully you'll have no trim at all set up. Just my opinions.
Originally Posted by Stark View Post
In my experience this mean that your CG is to far forward. You can confirm that by flying inverted. If it dives when upside down the CG needs to be moved back.
Another thing that is important on this small planes is lateral balance. If the plane roll out of a fairly tight outside loop, one wing is heavier than the other. Try to balance with the battery and if it is not sufficent, use a small screw as a weight in the lighter wingtip.
With good lateral balance will it fly very precise through all manoeuvres.
I’m happy to report that (after a miserable period of weather here in the UK) I finally managed to get out and setup the plane properly, and your advice was bang on! I suspect the CG is not quite at it’s final position (I need more practise at hovering and further experimentation with the rate and expo settings to fully harmonize the controls), but it’s now pretty much hands off inverted. It also exhibits none of the “climb under throttle, nosedive when shut” characteristics of before. Frankly it’s brilliant (but you guys all know that already)!
As a dyed in the wool glider guider I’ll happily admit I’d dismissed profile foamies til now; how wrong I was . In calm conditions this is the most finely controllable form of flying I’ve ever done – I’m guessing that once you’re good enough flying one of these things through a 3D routine is similar to the feeling cats have when they’re playing with a mouse! Just goes to show you should always experiment in with different forms of the hobby, otherwise you might never know what you’re missing…
MattyB is online now Find More Posts by MattyB
Old Apr 27, 2012, 08:32 AM
shunyata is offline
'tis nothing
shunyata's Avatar
Joined Dec 2011
Discussion Twisted Hobbys - RC Factory USA Sbach 342 39" Build Thread & Flight Video!!!!! aerofundan 3D Foamies 497 May 24, 2015 08:01 AM
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 1007 May 21, 2015 03:02 PM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
