Old Feb 05, 2013, 05:27 AM
Mattfoo83 is offline
Find More Posts by Mattfoo83
I like turtles
Mattfoo83's Avatar
United States, FL, Leesburg
Joined Dec 2012
Originally Posted by Jim Lee View Post
hammer833,
It must be from old stock, As Airborne models ( that's where I got my Electric powered Super Taiji) shows the old nitro version, But it's been discontinued. I would like to have one of the 50 size nitro powered ones, As I have a Saito 4 stroke that would fit right in it.
I've seen the new Evolution 10 gas engine, but I've never tried to run any of my planes on gas, If Glo fuel keeps getting higher, I may switch over to gas, since they are bringing out small gas powered engines.
J
Its the only way ill go back to running a fuel powered plane. And after seeing the above link ill consider it now.
Mattfoo83 is offline Find More Posts by Mattfoo83
Old Feb 09, 2013, 08:08 PM
I like turtles
Mattfoo83's Avatar
Joined Dec 2012
Well if all goes as planned ill at least be able to order the kit Tuesday.
Old Feb 09, 2013, 09:24 PM
Jim Lee is offline
Find More Posts by Jim Lee
AMA # 75962
Jim Lee's Avatar
United States, WA, Port Orchard
Joined Apr 2007
The World Models Super Taiji EP (40
That's great Mattfoo83,
If you get it Tuesday and have some time to work on it, You should have it ready to fly by the weekend.
Have you finalized your set-up?
J
Jim Lee is offline Find More Posts by Jim Lee
Old Feb 10, 2013, 11:13 AM
I like turtles
Mattfoo83's Avatar
Joined Dec 2012
Not at all.
Old Feb 15, 2013, 02:50 PM
Neko is offline
Find More Posts by Neko
United States, IL, Chicago
Joined Nov 2007
Getting on the Super Taiji train. Plane ordered, with Hacker A30-10XL, X-70 speed controller, and Hitec HS-65MG's.
Can anyone give a few details about moving the rudder/elev servos to the rear? I've not done that sort of major surgery before.
Neko is offline Find More Posts by Neko
Old Feb 15, 2013, 03:32 PM
hammer833 is offline
Find More Posts by hammer833
Rick
hammer833's Avatar
Canada, MB, Winnipeg
Joined Apr 2007
I just cut a hole the size of the servo in the fuse side about a 1/4" from a bulkhead. then I line the inside one the fuse around the hole with 1/4"x1/4" stock glued the the fuse side. Try to glue the 1/4"x1/4 stock to the bulkhead on one side of the hole and the other 3 sides to the fuse sides. Then just install your servo as normal screwing it to the stock. It's easy and not major surgery. Should take about a half hour per servo.
I hope this helps.
Rick
hammer833 is offline Find More Posts by hammer833
Old Feb 15, 2013, 03:35 PM
Rick
hammer833's Avatar
Joined Apr 2007
Deleted
Old Feb 15, 2013, 10:38 PM
Neko is offline
Joined Nov 2007
I hope this helps.
Rick
Will do. Thanks!
David
Old Feb 27, 2013, 10:59 PM
Neko is offline
Joined Nov 2007
Ok. Got it built. I only moved the rudder servo back and not the elevator servo. CG seems to be good, but there's not a lot of room to move the battery, so the CG is pretty much stuck where it is if one doesn't want to add weight.
In the build: I had a hard time finding the pilot holes for the servo horns. One of the blind nuts for the gear was placed incorrectly. Moving the rudder servo was tough since I ran into the tubing for the standard linkage. That was hard to remove without damaging the surrounding wood. The slots in the plastic wing servo mounts had to be widened to accommodate my servos (JR), or the servo arm ended up in the wrong position. Otherwise, it seems like a nicely built model.
Any tips on the little clips that hold the wings? I find them very difficult to get onto and off the screw. I had to use a needle-nose pliers, and even then it was a struggle. I'd like to be able to remove the wings for transport.
David
Old Feb 28, 2013, 01:08 AM
Jim Lee is offline
AMA # 75962
Jim Lee's Avatar
Joined Apr 2007
Wing Clips
Neko,
I use a small hemostat scissor to fasten the spring clip. I only take one clip off. I leave the other one on, cuts the frustration in half of trying to get the clips fastened. If you do it that way, Be sure and put the wedge somewhere you won't lose it.
http://www.rcdude.com/servlet/the-20...-Curved/Detail
J
Old Feb 28, 2013, 11:40 PM
riot3d is offline
Find More Posts by riot3d
Joined Apr 2011
David
Be careful, the wing tube slot at the end where the clips goes in has two different sizes - rotate the tube & you can tell the difference. Make sure you're using the bigger slot, slip it in rotate the tube to ensure the spring hook catches the head of the screw. Once it's fasten, it's very tight, even for numerous snap rolls.
Adrian
riot3d is offline Find More Posts by riot3d
Old Mar 03, 2013, 02:40 AM
Chris Tindall is offline
Find More Posts by Chris Tindall
eflynow
Sydney, Australia
Joined Nov 2002
Moving the elevator servo to the tail
When I set up my Super Taiji a year ago, I went to quite a bit of trouble to move the Taiji's elevator servo to the tail, make a joiner for the elevator halves etc. On the final dry run before glueing in the fuzzy hinges for the elvator I realised it wasn't going to work!
On my Taiji, the elevator hinge line has a slight sweep. If I put the tailplane halves (without the elevators) onto the joiner tube, the trailing edges at the tip are about 1/8" behind the trailing edge at the root. It's hard to see because the fin gets in the way of looking along the hinge line. A solid elevator joiner causes all sorts of distortions in the tailplane and elevators when the elevator is moved from the neutral position. Not to mention placing a huge load on the elevator servo.
If you want to move the elevator servo aft, put it inside the rear of fuselage and retain the two pushrods - as outlined on a post early in this thread.
I have no way of knowing whether all Taiji's are have the sweep in the elevator hinge line. If you do consider using a solid elevator joiner, check the hinge line very, very carefully.
In my case the solution was simply to put the rudder servo into the cutout I had made for the elevator servo.
Chris Tindall is offline Find More Posts by Chris Tindall
Old Mar 03, 2013, 10:00 PM
Jim Lee is offline
AMA # 75962
Jim Lee's Avatar
Joined Apr 2007
Ah, The joy of being a Beta Tester.
J
Old Mar 04, 2013, 06:50 PM
Neko is offline
Joined Nov 2007
Thanks guys. Very helpful. 4-8 inches of snow predicted here. Looks like I'll have to maiden on skis.
Old Mar 22, 2013, 04:16 PM
Neko is offline
Joined Nov 2007
Finally got a first flight in on the Taiji. Not bad. The one thing I find a bit off is the elevator. For level flight, I need many clicks of up, to the point that the back edge of the elevator is about 1/8" above the back edge of the horizontal stabilizer.
I would have suspected that my CG is too far forward, but in inverted flight, there is not that much of a tendency to dive, and the plane balances pretty near what the specs say. (I put the elevator servo in the rear.)
Sold NIB World Model Little Toni EP 40" wing span Reno Racer ARF gabrielisrael Aircraft - Electric - Airplanes (FS/W) 0 Sep 12, 2011 02:07 PM
Wanted power system for a .60 P-40 and super sporster .40 sagomon Aircraft - Electric - Power Systems (FS/W) 2 Sep 05, 2011 02:32 PM
Found Super Tiger 40 or Thunder Tiger .40 pro Tetex79 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jun 03, 2011 03:51 PM
Discussion Modeltech Super Cub Gen-II Glow/EP 40 ARF FlyingBeaver Scale ARF/RTF 5 Feb 03, 2010 06:29 PM
