Old Oct 17, 2011, 08:59 PM
Jim Lee is offline
Find More Posts by Jim Lee
AMA # 75962
Jim Lee's Avatar
United States, WA, Port Orchard
Joined Apr 2007
JD, Are the Elevator Pushrods the ones that came with the Kit? They look thicker than the one's that I have in Mine. Maybe it's just an optical Illusiion or I need new glasses
J
Jim Lee is offline Find More Posts by Jim Lee
Old Oct 17, 2011, 09:01 PM
Jim Lee is offline
AMA # 75962
Jim Lee's Avatar
Joined Apr 2007
I looked at the Motor Mounts that T.H. Has, But I decided to build my Own.
J
Old Oct 17, 2011, 09:22 PM
J.Douglas is offline
Find More Posts by J.Douglas
Old Skool
J.Douglas's Avatar
Joined Dec 2003
J
Yes they are ones come with the kit.
JD
J.Douglas is offline Find More Posts by J.Douglas
Old Oct 17, 2011, 09:31 PM
Old Skool
J.Douglas's Avatar
Joined Dec 2003
I put the motor & mount on as the plane was getting tail heavy on my work stand here are some pic's. of it.
JD
Old Oct 17, 2011, 10:10 PM
Jim Lee is offline
AMA # 75962
Jim Lee's Avatar
Joined Apr 2007
That looks like the Stock Motor Mount, But what motor are you using?
I decided to go with a Scorpion Sll-3020-890Kv, and I'm looking to get around 650 to 750 Watts. That will depend on how many Amps it pulls.
The Scorpion is rated for 45Amps Continious, But I'm going to try to go just a little above that. I'm looking at using a 11x8e APC or a Xoar 12x7. Bench testing will determine what I'll go with.
J
Old Oct 17, 2011, 10:55 PM
Old Skool
J.Douglas's Avatar
Joined Dec 2003
It is the stock mount and the motor is ............ Green
Old Oct 17, 2011, 11:09 PM
Jim Lee is offline
AMA # 75962
Jim Lee's Avatar
Joined Apr 2007
Well, That's Good. At Least I know that I'm Not Color Blind. I know that it's not the Stock Motor, Because the stock motor is ................BLUE
Old Oct 19, 2011, 07:03 PM
Old Skool
J.Douglas's Avatar
Joined Dec 2003
On the main LG the wheel pants are different as they use a nylon rivet. Here are some pic's.
JD
Old Oct 20, 2011, 07:28 PM
Old Skool
J.Douglas's Avatar
Joined Dec 2003
The Super Taiji EP ended up at 3lbs 11oz with a 2650 blue lipo. I need to get some different props but with the 14x7 that she is wearing now I get 705 watts. I may not need that but.....
JD
Old Oct 20, 2011, 09:10 PM
Jim Lee is offline
AMA # 75962
Jim Lee's Avatar
Joined Apr 2007
Looking Good JD, When is the Maiden?
J
Old Oct 20, 2011, 09:22 PM
Old Skool
J.Douglas's Avatar
Joined Dec 2003
J
Not sure, Have you started on yours ? I need to move everything back as far as I can to get CG.
JD
Old Oct 20, 2011, 10:50 PM
Jim Lee is offline
AMA # 75962
Jim Lee's Avatar
Joined Apr 2007
Mine is almost done, I'm waiting on a servo extension for the aileron servo, Should be here tomorrow. I thought I had the ones I needed. But I only had one.
I'll finish it tomorrow, Balance it, and do some prop tests. I just know that as soon as I get it ready for maiden, It'll start raining.
J
Old Oct 20, 2011, 11:05 PM
BTerry is offline
Find More Posts by BTerry
BTerry's Avatar
USA, WA, Bremerton
Joined Aug 2001
J. D. That plane looks great! I will need to venture down to Port Orchard to watch it fly.
Do either you or Jim have any experience with the Vanquish? It is slightly smaller than the Taiji, but I wonder how it compares otherwise. I would love to get a 4s pattern plane and the only real options I can see are the Vanquish, the Osiris, and the Tai-ji. And the foamie from HK, but I would put that a step below.
In my experience the World Models planes are very well built, and the Taijis I have seen fly very well (though they were big, almost 2m size).
BTerry is offline Find More Posts by BTerry
Old Oct 21, 2011, 09:53 AM
Old Skool
J.Douglas's Avatar
Joined Dec 2003
BTerry, I think Jim has a Vanquish and a Osiris, He would be the one to talk to on that.
JD
Sold NIB World Model Little Toni EP 40" wing span Reno Racer ARF gabrielisrael Aircraft - Electric - Airplanes (FS/W) 0 Sep 12, 2011 02:07 PM
Wanted power system for a .60 P-40 and super sporster .40 sagomon Aircraft - Electric - Power Systems (FS/W) 2 Sep 05, 2011 02:32 PM
Found Super Tiger 40 or Thunder Tiger .40 pro Tetex79 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jun 03, 2011 03:51 PM
Discussion Modeltech Super Cub Gen-II Glow/EP 40 ARF FlyingBeaver Scale ARF/RTF 5 Feb 03, 2010 06:29 PM
