Old Oct 04, 2011, 04:35 PM
J.Douglas is offline
Find More Posts by J.Douglas
Old Skool
J.Douglas's Avatar
Joined Dec 2003
Build Log
The World Models Super Taiji EP (40)
I'm a sucker for 40 size pattern ships. This was at the door when I got home today. I dont have gear yet but I'm thinking around 700 watts.
JD
J.Douglas is offline Find More Posts by J.Douglas
Old Oct 04, 2011, 05:18 PM
Old Skool
J.Douglas's Avatar
Joined Dec 2003
The manual is here. Specifications are
Wing span:52 in
Area:490
Fuse lenght:53.5 in
Jd
Old Oct 05, 2011, 09:20 AM
RCBRUSKI65 is offline
Find More Posts by RCBRUSKI65
United States, MI, Saginaw Charter Township
Joined Feb 2007
Looks Nice.
RCBRUSKI65 is offline Find More Posts by RCBRUSKI65
Old Oct 05, 2011, 03:53 PM
lipoflyer is offline
Find More Posts by lipoflyer
lipoflyer's Avatar
Australia
Joined Nov 2010
I've got two TWM planes and i found the build quality to be very good.
lipoflyer is offline Find More Posts by lipoflyer
Old Oct 05, 2011, 06:17 PM
Old Skool
J.Douglas's Avatar
Joined Dec 2003
Yes the quality is very good it also has some unique features the self tightening wing latch system is one. I just had to see how this system works Here are some pic's. I should have my gear soon and will take pictures of the build.
JD
Old Oct 05, 2011, 08:24 PM
lipoflyer's Avatar
Australia
Joined Nov 2010
how does the wing latch work?
Old Oct 05, 2011, 09:44 PM
Old Skool
J.Douglas's Avatar
Joined Dec 2003
It is a tapered wedge that is spring loaded into the wing tube.
JD
Old Oct 06, 2011, 05:35 PM
Old Skool
J.Douglas's Avatar
Joined Dec 2003
The manual is very complete so I will post some changes I do.
I seal all control surfaces. Here I use some clear covering cut 1 inch wide.
Old Oct 06, 2011, 06:53 PM
Jim Lee is offline
Find More Posts by Jim Lee
AMA # 75962
Jim Lee's Avatar
United States, WA, Port Orchard
Joined Apr 2007
JD
JD, If you are going to do 700 watts on yours, I'm going to do 1150Watts on mine. And I already have the gear for it.
J
Jim Lee is offline Find More Posts by Jim Lee
Old Oct 06, 2011, 08:09 PM
Old Skool
J.Douglas's Avatar
Joined Dec 2003
Ooooh! where you been out east ? I was out to the field last weekend had some good flying.
One thing on this bird if you use a bigger motor I would not use the stock mount it is for a motor with a length of 48.5mm I think tower was some mounts that would do the trick.
FYI: This plane has no motor mount or motor box just a strait fire wall.
JD
Old Oct 07, 2011, 09:26 PM
Shangrila is offline
Find More Posts by Shangrila
Joined Oct 2011
Nice plane!
Shangrila is offline Find More Posts by Shangrila
Old Oct 09, 2011, 07:36 PM
Old Skool
J.Douglas's Avatar
Joined Dec 2003
I have all thr gear now to complete the Super Taiji, So moving forward.
Aileron Servo: I'm using Hitec HS 82 MG servo's all around as they fit the hole spacing for the mounts.
Old Oct 11, 2011, 05:37 PM
Old Skool
J.Douglas's Avatar
Joined Dec 2003
Next is the H.Stab this is just like the wing instal as it has a tube and anti rotation pins. It is secured with screws. One thing with this plane is the parts bags are numberd with the manual.
Old Oct 12, 2011, 06:24 PM
Old Skool
J.Douglas's Avatar
Joined Dec 2003
On the Vertical just hinge the rudder and some 30min. epoxy and thats completed.
Old Oct 17, 2011, 07:18 PM
Old Skool
J.Douglas's Avatar
Joined Dec 2003
The elevator has no joiner but uses pushrods. This setup works nice and smooth.
Sold NIB World Model Little Toni EP 40" wing span Reno Racer ARF gabrielisrael Aircraft - Electric - Airplanes (FS/W) 0 Sep 12, 2011 02:07 PM
Wanted power system for a .60 P-40 and super sporster .40 sagomon Aircraft - Electric - Power Systems (FS/W) 2 Sep 05, 2011 02:32 PM
Found Super Tiger 40 or Thunder Tiger .40 pro Tetex79 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jun 03, 2011 03:51 PM
Discussion Modeltech Super Cub Gen-II Glow/EP 40 ARF FlyingBeaver Scale ARF/RTF 5 Feb 03, 2010 06:29 PM
