This thread is privately moderated by Chrizz, who may elect to delete unwanted replies.
Old Oct 03, 2011, 09:51 PM
Chrizz is offline
Find More Posts by Chrizz
OY-5542
Chrizz's Avatar
Denmark, Central Denmark Region, Silkeborg
Joined Nov 2009
Gallery
Ultra Micro Dead Simple Wing
Description: Name: thumb-DSWing.jpg
Description:
Plans are from: http://www.rcgroups.com/forums/showthread.php?t=1252282
(does not include the profile fuselage)
Description: Name: 5.jpg
Description: Name: 3.jpg
Description:
The wing and winglets are made of 3mm Depron, the profile fuselage of 6mm Depron.
The wings leading edge and the nose have been covered with clear tape.
The electronics come from a Parkzone Ultra Micro Sukhoi.
Description: Name: 6.jpg
Description:
The Dead Simple Wing lives up to its name!
It is in fact extremely simple to build and very easy to fly.
The construction is nothing to talk about and i imagine that it could be customized
in various ways or used as a platform for other builds. It is dead simple.
In flight it is just as simple and flawless. Once in the air, when put on a trajectory, it flies like on rails.
Turns are clean and can be large and gentle or very tight. There's no sign of any bad tendencies.
The control surfaces responses are quick and precise around the center, even with a lot of travel.
Roll rate is satisfying, about 1 roll per sec..
Max flying speed seems about the same as with U.M. Sukhoi, but the wing accepts to fly pretty slow to.
Description: Name: 8.jpg
Description: Name: 9.jpg
Description:
Chrizz is offline Find More Posts by Chrizz
Old Dec 01, 2011, 08:47 PM
alex111 is offline
Find More Posts by alex111
alex111's Avatar
Australia, QLD, Ashgrove
Joined Nov 2009
nice you have does a nice job on then
alex111 is offline Find More Posts by alex111
Old Feb 19, 2012, 07:31 PM
numanair is offline
Find More Posts by numanair
numanair's Avatar
United States, WA, Kirkland
Joined Sep 2010
Nice. Could you explain how you did the torque rods? I'm trying to figure out a good way to make the part where the pushrod and torque rod meet.
numanair is offline Find More Posts by numanair
Old Feb 21, 2012, 07:18 AM
Chrizz is offline
OY-5542
Chrizz's Avatar
Joined Nov 2009
Hi Numanair! Thanks!
The torsion bars and pushrods are linked together with heatshrink and a drop of CA. The heatshrink allows for enough mouvement while not presenting any slack.
To obtain enough travel at the elevons, I've shortened the torsion bars a little. It's important that the torsion bars/pushrods/elevons move freely, before connecting them to the servos. It's too easy to obtain different travels, when you compare the two elevons travel at different points...
Hope this does help you? Don't hesitate to ask if there's anything else!
Happy landings :-)
Old Oct 10, 2014, 05:46 PM
jh1985 is offline
Find More Posts by jh1985
United States, MN, St Paul
Joined Jul 2014
hey could you tell me your dimensions 24 seems big for micro gear
jh1985 is offline Find More Posts by jh1985
Old Oct 11, 2014, 06:44 AM
Chrizz is offline
OY-5542
Chrizz's Avatar
Joined Nov 2009
Hi!!
Yes 24" is way to large for this Ultra Micro gear, I did scale the plan down to just under 40cm.
Here's another version of the plan with different scales added: the original 24" (60,96cm), 39.84cm e.c.t ...
Name: Dead Simple Wing - plan, inch + cm.jpg
Description:
Happy landings :-)
Discussion 24" DS (Dead Simple) Flying Wing - Pics, Video, Plans forlack Foamies (Scratchbuilt) 797 Apr 04, 2016 10:49 AM
Build Log Heavy lifter Dead Simple Wing Ottomite Flying Wings 5 Jul 24, 2011 11:56 AM
Question Jerbear's Simple Wing Flyboy Steve Foamies (Scratchbuilt) 8 Apr 05, 2011 10:03 PM
Discussion Simple SK membrane wing isn't simple ..at all !!!??:) khaled_abobakr Ornithopters 7 Apr 04, 2011 05:29 PM
Discussion Simple wing design? Autotechwagon SPAD - Simple Plastic Airplane Designs 8 Mar 14, 2011 01:45 AM
