Old Oct 03, 2011, 02:37 PM
michaelingp is offline
Find More Posts by michaelingp
United States, MD, Kensington
Joined Dec 2008
Deb spar question
Yardsticks are a little scarce lately. I'm thinking of using a single pine lattice spar. The lattice is straight grained, and 1/4" by 1-1/8". I'll be building a RNAFwing. Will the spar be strong enough?
michaelingp is offline Find More Posts by michaelingp
Old Oct 03, 2011, 06:25 PM
draftman1 is offline
Find More Posts by draftman1
draftman1's Avatar
central CA
Joined Aug 2002
yeah, it should be, I use a hardwood like birch and rip it down on the table saw.
if you have an ACE hardware store, they have or can get them
draftman1 is offline Find More Posts by draftman1
Old Oct 03, 2011, 11:40 PM
JohnsPop is offline
Find More Posts by JohnsPop
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
I use those old finger-jointed yard sticks that Walmart sells and have never had one separate. BUT..... I don't do all kind of maneuvers like most folks do. On a Deb trainer you should be ok. I *do* put a shot of thin CA on the finger joints on the yardsticks to help stick them together. I bet if you ran a bead of thin CA down the length of your yardstick and just let it soak in, the CA sticking the fibers together plus the torsion/tension or whatever it's called that the engineers in the group speak of that the gluing of the spar to the wing skin....... you'll be ok on a Deb whatever maneuvers you decide to do. And if the spar snaps, chop the throttle, drop it on in, repair whatever happens and give it another go.
JohnsPop is offline Find More Posts by JohnsPop
Old Oct 13, 2011, 11:29 AM
jib is offline
jib
Find More Posts by jib
jib
Chief Mechanic for my son
Covington, WA
Joined Oct 2008
I've covered one side of a yardstick with light fiberglass cloth and epoxy. Stong and not too heavy. Sand the edges to clean it all up, so the glass is only on the side.
Jack
jib is offline Find More Posts by jib
Discussion More Pss Pics By Deb Louied Slope 1 May 27, 2007 08:43 PM
Discussion stiffen up deb tail flossandfly SPAD - Simple Plastic Airplane Designs 5 Jul 28, 2006 11:39 AM
Carbon spar question. DeaninMilwaukee Scratchbuilt Indoor and Micro Models 0 Nov 02, 2002 09:57 PM
Zagi 400X spar question FX1SUB Foamies (Kits) 6 Aug 15, 2002 03:01 PM
Zagi 400X Spar Question HavingFun2002 Foamies (Kits) 11 Apr 29, 2002 06:52 AM
