Old Sep 17, 2003, 12:25 PM
BrianRickman is offline
Find More Posts by BrianRickman
United States, PA, Hatboro
Joined May 2002
Old Timer/floater kit or plans for Speed 400 or smaller motor?
I'm starting to look for a winter building project. I think I'd enjoy an Old Timer type model. Something very stable and relaxing to fly. The kind where once the model is trimmed properly you can fly it with just rudder and throttle, or even let it go free-flight on calm days.
I have 8 cell 500mah nicad packs (~ 6 ounces) and 2 cell 820mah lithium ion (1.8 ounce) packs. I'd prefer to use these packs, which limits me to speed 400 class or smaller motors. Don't want to go brushless at this time.
I'd prefer a laser cut kit if one exists, but I'll work from plans if necessary. I do not want a foamie or ARF. I want something that'll keep me busy in the workshop when it's too cold to fly.
I've done a few searches and found the following that look like possibilities:
- Mountain Models Dusk Stick and Dandy
- BMJR Ugly 30 and Baby Phoenix
- MAT Miss Stik, Slowmowatt, and Le Parquewatt
I've read plenty of threads on the Dusk Stick, Dandy, Ugly 30, and Miss Stik, but have not found much information on the others.
Have you built and flown a Baby Phoenix, Slowmowatt, or Le Parquewatt?
What else is out there?
BrianRickman is offline Find More Posts by BrianRickman
Old Sep 17, 2003, 02:03 PM
babblefish is offline
Find More Posts by babblefish
Yes, that is Jamie
babblefish's Avatar
SF Bay Area, CA
Joined Jul 2002
I haven't flown any of the planes you mentioned, but I can suggest a few others:
1) SIG Rascal (kit version) (http://www.sigmfg.com/cgi-bin/dpsmar...FV3.html?E+Sig)
2) HOB (House Of Balsa) Cub, 52" wingspan version (http://www.houseofbalsa.com/e/env/00...=products:k-70)
3) Hobby Lobby Mini Telemaster (www.hobby-lobby.com
BTW: the Mountain Models planes will probably only keep you busy for about 4 hours 'cause they build fast.
babblefish is offline Find More Posts by babblefish
Old Sep 17, 2003, 02:58 PM
Joined May 2002
Thanks babblefish. I'll take a look at those planes too.
Old Sep 17, 2003, 03:42 PM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
Spirit of Yesteryear do nice kits, quite a few of which are suitable for S400. Have a look at the Lil Viking, the Dallaire Sportster or the new Atomizer at http://www.soy.on.ca/
Steve
steve lewin is offline Find More Posts by steve lewin
Old Sep 17, 2003, 03:53 PM
Joined May 2002
Thanks Steve,
I think the Spirit of Yesteryear planes are more like what I was looking for.
Old Sep 17, 2003, 04:03 PM
Bob Chiang is offline
Find More Posts by Bob Chiang
Ithaca, NY USA
Joined Oct 2000
Hi Brian,
Lots of plans here, including old timers.
http://plans.rcmodell.hu/
Bob Chiang is offline Find More Posts by Bob Chiang
Old Sep 17, 2003, 04:47 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
I won't comment on the kits, because what we have here is probably not obtainable over there, but on yteh power issues - yes the 8x500AR is fine, and teh Li-ion probably is. You are lkley to need about 7A in teh climb, and 4-5A just pottering about.
Best motor for pottering at those cell counts is 6v sp400, and I would gear 2.33:1 and start with APC 8x6. If the AUW is 20 oz or less, and wingspan around 40", it will fly very adequately. I have tried other combinations, but that was the most successful.
Old Sep 17, 2003, 04:54 PM
Mo Jiggy is offline
Find More Posts by Mo Jiggy
Joined Mar 2003
Have you looked into the "Cutie" from SR Batteries?(www.srbatteries.com/kits.htm)
-Mo
Mo Jiggy is offline Find More Posts by Mo Jiggy
Old Sep 17, 2003, 04:59 PM
tim hooper is offline
Find More Posts by tim hooper
Single-task at best...
tim hooper's Avatar
Telford, UK
Joined Feb 2000
Brian,
Ben Buckle Kits do a wide range of vintage kits and plans here in the UK, although posting aplan overseas shouldn't be a problem;
http://www.benbucklevintage.fsbusiness.co.uk/index.htm
Here's a brief look at my Scorpion 44. S400 geared, 7 cells, 23oz. Lovely!
http://www.rcgroups.com/forums/showt...light=scorpion
tim
tim hooper is offline Find More Posts by tim hooper
Old Sep 17, 2003, 05:09 PM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
That's a lovely model Tim. Unusual for you...
Actually, rolling your own is easy - just think keil Kraft Rubber model, and it all comes back.
This was my first scratch built own design - at least the third iteration of it. I still have the wing...
Old Sep 17, 2003, 08:01 PM
Joined May 2002
Thanks guys. Now I've got lots of options to consider. Maybe I'll get inspired to do more then one over the winter .
Old Sep 17, 2003, 08:25 PM
rcflyer0021 is offline
Find More Posts by rcflyer0021
Joined Feb 2003
Brian
I have built and flown the LeParquewatt, slowmowatt and other
MAT designs, and my personnel favorite is the LeParquewatt.
easy and fun to build, but one of the very best RC airplanes
I have ever flown.
It flies like a oldtimer, You can get info in the plans only section at www.modelair-tech.com and where to purchase.
Gordon
rcflyer0021 is offline Find More Posts by rcflyer0021
Old Sep 17, 2003, 08:49 PM
Joined May 2002
Thanks Gordon,
LeParquewatt is attractive to me too. Looks like an old timer and I like the stick method of construction. Makes building from plans much less of an ordeal compared to cutting out ribs, formers, etc.
Old Sep 18, 2003, 08:57 AM
Megowcoupe is offline
Find More Posts by Megowcoupe
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
Brian
For the smaller packs- check out some of the Midway models stuff at Penn Valley Hobby Center. (pennvalleyhobbies.com) Look up R/N kits- there's a bunch of stuff out there in the TD 020 class which converts well. Also- Bob Holman is now laser cutting parts to match his plans- and these semi kits are really a great way to go. bhplans.com
Buzzard Bombshell's make a very nice old timer-I'm tempted to build another.
BMJR kits have a nice rep- and they've got more than you've listed.
buy a copy of Flying Models and start looking through their ads.
If you haven't built much before- the Ben Buckle kits are umm challenging. Let's say that parts fits and plans accuracy can leave something to be desired- don't know if that's improved.
Sam
Megowcoupe is offline Find More Posts by Megowcoupe
Old Sep 18, 2003, 09:37 AM
Yes, that is Jamie
babblefish's Avatar
SF Bay Area, CA
Joined Jul 2002
Brian
For the Ben Buckle kits (and I think these are exactly what you're looking for), a US distributor is GCBM. Here's their website:
www.gcbmrc.com
lipo 2S or 3S for speed 400 ? Tom héli Batteries and Chargers 4 Nov 03, 2005 03:25 AM
Need plans for a speed 400 powered flying wing Prashanth Foamies (Kits) 21 Jun 12, 2004 01:24 AM
FS: Speed 600 motor, prop, or WTT for speed 400. Kitsu Aircraft - Electric - Airplanes (FS/W) 0 Nov 19, 2002 03:47 PM
