Old Oct 03, 2011, 06:11 AM
peggyf is offline
Find More Posts by peggyf
Joined Sep 2011
Help!
Fox 19 Engine
Hi people, l'm wondering if the Fox 19 engine(American) can be converted by changing the carb from fixed flight to rc throttle flight.
Any advise will be more than welcome, thanks
peggyf is offline Find More Posts by peggyf
Old Oct 03, 2011, 06:18 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
If it has a flange mount intake venturi, then yes you could convert it to RC by acquiring a RC carb for it. If the intake is cast into the crankcase it cannot be converted to RC.
The engines that have a carb or intake venturi held on with two small screws can be converted either way by getting a carb or a venturi.
earlwb is offline Find More Posts by earlwb
Old Oct 03, 2011, 06:22 AM
peggyf is offline
Joined Sep 2011
It is flanged, so thats a good start, all l have to do is find one.
Is there any that stand out or better adapted to the Fox 19?
Old Oct 03, 2011, 08:20 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
You have the older Fox two needle carb and the newer Fox .25 Schuerle engine RC carb which is a little larger than the older one. But I do not remember trying to bolt up the new larger carb onto a older .19 or .25 engine. So I don't know if it fits OK. But it looks like it ought to though.
One could machine up an adapter for using some other brand of carb too, such as a small Perry carb.
http://www.foxmanufacturing.com/inde...ndex&cPath=184
The older 2 needle carbs pop up on Ebay from time to time.
In hindsight, I now remember trying out a couple of the newer .25 carbs on a old .25 and they fit OK. At the time I was figuring out which needle valve went with what from a pile of parts I had.
Old Oct 04, 2011, 06:04 AM
peggyf is offline
Joined Sep 2011
Thanks very much for taking the time to answer my question, will try to source a carb or 2.
Sold NIB Enya .19 VI TV R/C engine shooboy Aircraft - Fuel - Engines and Accessories (FS/W) 0 Sep 11, 2011 12:15 PM
Sold Fox Engine Parts Chatenever Aircraft - Fuel - Engines and Accessories (FS/W) 1 Sep 04, 2011 04:44 PM
For Sale fox .19 motor stealthy Aircraft - Fuel - Engines and Accessories (FS/W) 2 May 19, 2011 06:39 AM
Discussion Fox 19 engine ScaleBowler Engines 20 Oct 19, 2009 12:14 AM
For Sale Vintage / Nostalgia Engines: Two Veco 19’s, Fox 15 U control, Fox 25 non-op Daveairway Aircraft - Fuel - Engines and Accessories (FS/W) 1 Feb 28, 2009 08:14 AM
