Old Sep 17, 2003, 08:58 AM
kindjordan is offline
Find More Posts by kindjordan
kindjordan's Avatar
Westchester, NY
Joined Jun 2003
Potensky Eagle hard to build?
Hey guys...i just picked up an eagle...and was wondering if it was difficult to build. Ive done lots of checking up and reading about the plane...and it seems that people have had some issues....just trying to learn as much as i can b4 start the build....with any luck i should have it built by the time this hurricane blows on by!...any advice would be apreicated ...thanks-J
kindjordan is offline Find More Posts by kindjordan
Old Sep 17, 2003, 09:38 AM
jsn is offline
jsn
Find More Posts by jsn
jsn
Dis-member
jsn's Avatar
USA, VA, Ashburn
Joined Mar 2003
hmmm not really hard.. I have the cobra..
the 2 things that i didn't like are
1. It is kind of hard to line up the wings , Use the big template that came with the kit..
2. I don't like that you just glue the control horns on. You might want to get some 3 party ones (gws)
3. ( know i said there was only 2) You have to carve out the nose from a block of foam.. that just sucks...
But.. It is a great plane it flys like a dream and can take (very) hard landings all day long. You will love it.. Have fun..... jsn
jsn is offline Find More Posts by jsn
Old Sep 17, 2003, 09:51 AM
kindjordan's Avatar
Westchester, NY
Joined Jun 2003
hey..thanks for the info....keep the tips coming....presheateit!!-Jordan
Old Sep 17, 2003, 12:50 PM
BatmanOSX is offline
Find More Posts by BatmanOSX
WA
Joined Jul 2003
Biggest challenge I had was in getting the tape to stick for the ailerons. The foam is corse, on the wing, that tape peels off easily. I have laid down some white glue, on the wing where the ailerons attach, and the tape seems to stick better. I used an iron to heat the tape after applying.
Also, the pinion gear on the motor. I didn't even attempt to use the plastic one included. I order a brass (metal) pinion gear and installed that before my first flight. Several threads on that subject.
Enjoy....
Chuck
BatmanOSX is offline Find More Posts by BatmanOSX
Old Sep 17, 2003, 03:38 PM
navyflier is offline
Find More Posts by navyflier
Heli Noob
Washington D.C.
Joined Aug 2002
Depends
It's not a Sky Scooter , but it's not too difficult. I have had complete ARF up till this point so I found it a bit challenging at first, but the key is to take your time and print out Greg Covey's article. It helped TONS in the building. Mine flew great until I had a touch and go that touched a bit too hard. Now no more go! About 20 minutes and some epoxy and I'm sure she'll be back up. Great plane!!! ---Navyflier
navyflier is offline Find More Posts by navyflier
Old Sep 17, 2003, 06:17 PM
kindjordan's Avatar
Westchester, NY
Joined Jun 2003
thanks for the tips...yeah i intend on printing out all the online reviews!!....i just got hooked after seeing the video on hobbylobby......and recently crashed my roto..so perfect opturnuty to further crash into the abiss of debt for my favorite hobby
Old Sep 17, 2003, 07:05 PM
Kwesdog is offline
Find More Posts by Kwesdog
I fly Army UAVs!
Kwesdog's Avatar
West Saint Paul, MN
Joined Aug 2002
Another thing you may want to think about before you get it all built up is putting a GWS motor and mount in it. The gear box that comes with the Cobra and eagle is garbage because the gears are made out of pretty soft plastic that will strip at the slightest bump.
Harry
Kwesdog is offline Find More Posts by Kwesdog
Old Sep 17, 2003, 07:30 PM
Ledbetter is offline
Find More Posts by Ledbetter
Central California
Joined Aug 2003
You can replace the plastic pinion gear with a metal one from Hobby Lobby.
MJ8020 PINION FOR SPD 280/300, 5:1 $2.60 (same as stock)
MJ8021 PINION FOR SPD 280/300, 4.5:1 $2.60 (spins slightly faster)
Ledbetter is offline Find More Posts by Ledbetter
Old Sep 18, 2003, 01:43 AM
kindjordan's Avatar
Westchester, NY
Joined Jun 2003
Harry...will the GWS motor provide the thrust that the stock motor will?...also which gws should i get a,b,c,..i assume those are different gearing???..let me know thanks-J
Potensky Eagle build question thomer Foamies (Kits) 6 Mar 25, 2004 04:42 PM
Potensky Eagle with Mini LRK Andreas Parkflyers 2 May 08, 2003 12:42 PM
Potensky Eagle? or other ideas for tough, aerobatic 2nd plane? duganderson Parkflyers 0 Apr 05, 2003 12:23 AM
Hard to build a Zagi ? brudford Foamies (Kits) 6 Oct 25, 2002 12:55 PM
Man that Micro Pitts is hard to build. Jim McPherson Scratchbuilt Indoor and Micro Models 5 Sep 26, 2002 12:31 PM
