Old Oct 01, 2011, 07:35 PM
Danyal is offline
Find More Posts by Danyal
Canada, ON, Milton
Joined Feb 2010
Question
What hinge tape to use
I want to add flaps to my Parkzone T-28D, Im wondering what Hinge tape is best to use, that will suit the plane the best
Danyal is offline Find More Posts by Danyal
Old Oct 01, 2011, 09:57 PM
enracer is offline
Find More Posts by enracer
enracer's Avatar
United States, VA, Williamsburg
Joined Jul 2011
3m Blenderm is probably the best tape for hinges. I just added flaps to my T-28D, and I used 3m Transpore tape because I couldn't find any Blenderm locally. Transpore is basically the same tape as Blenderm but with micro holes to help it breathe. I'm definitely pleased with it so far.
enracer is offline Find More Posts by enracer
Old Oct 01, 2011, 10:58 PM
Danyal is offline
Canada, ON, Milton
Joined Feb 2010
Would a 1" roll be okay, or would 2" be better
Old Oct 02, 2011, 12:51 AM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Tape has negligible weight on a plane like the Trojan, and the extra width will be good for a little more staying power, but I think either would be fine.
I'd personally go with the 2" stuff because there might be a future application that needs a wider piece of tape, and you can always cut it smaller if needed.
Ordinary packing tape will also do the job, but Blenderm is just... More awesome. It's very flexible and it can be formed to curves much more easily than regular cellophane-type tapes, and it has a nice soft surface to it. It's also hypoallergenic, just in case that matters
Piece is offline Find More Posts by Piece
Old Oct 02, 2011, 12:55 AM
Danyal is offline
Canada, ON, Milton
Joined Feb 2010
had to get the 1" cause I couldnt find the 2" in stock anywhere
Anyways
Old Oct 02, 2011, 09:47 AM
Rickochet is offline
Find More Posts by Rickochet
Card Carrying Old Fart
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Anyways
Blenderm is super stuff. I have never seen another tape that sticks so well. And it is very tuff. The biggest aircraft I have used it on for some 1.5" x 17" ailerons on a plane and it has worked well. The 1" wide will do just fine.
Rickochet is offline Find More Posts by Rickochet
Old Oct 03, 2011, 10:32 PM
Dakine48 is offline
Find More Posts by Dakine48
REAL old new guy!
United States, HI
Joined Jul 2011
Do you run the tape the entire length of the aileron or just a few short pieces every few inches.
Dakine48 is offline Find More Posts by Dakine48
Old Oct 03, 2011, 10:59 PM
enracer is offline
enracer's Avatar
Joined Jul 2011
Run it the entire length of your flap. Do the top first, then fold the flap all the way up and run another piece along the underside. The 1" tape should fit the underside perfectly.
Old Oct 03, 2011, 11:19 PM
Piece is offline
Piece's Avatar
Joined Aug 2009
The way that works best for me is to take the tape and apply it to the control surface first (do the entire length of the hinge). This should be done on a flat, hard surface to avoid any slight warps. Then take the part and slowly, carefully place it in its final position, keeping it slightly deflected to prevent the tape from grabbing too early, and making sure everything is nice and even.
Start pressing the tape down at the hinge line from the center outward, moving slowly and carefully to avoid wrinkles. Once it's all nice and tight, give the surface a few experimental up/down cycles to see if it's moving smoothly.
Now flip the wing over and fold the flap all the way back flat against the wing. Take a second piece of tape and apply it in a similar manner to the first, making sure to keep wrinkles to zero...
These hinges will outlast the plane.
Old Oct 04, 2011, 05:01 AM
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Do it as enracer suggested. Be careful not to get the Blenderm stuck to itself because it won't come loose. Good stuff.
Old Oct 04, 2011, 05:47 PM
Dakine48 is offline
REAL old new guy!
United States, HI
Joined Jul 2011
Thanks guys!
Old Oct 07, 2011, 04:54 PM
Danyal is offline
Canada, ON, Milton
Joined Feb 2010
Thanks everyone for the great tips and help!
Discussion What do you use for hinge tape? byrocat Foamies (Scratchbuilt) 42 Apr 20, 2008 05:59 PM
What do you use for hinge tape? gr8johnson3 Beginner Training Area (Aircraft-Electric) 24 Mar 07, 2005 09:19 AM
What is hinge tape made of? What else can I use? Magna Electric Plane Talk 11 Jan 28, 2004 07:20 PM
What to use for Elevon Hinge Tape? Dunqun Slope 16 Aug 29, 2003 07:42 AM
Hinge tape for Omega 1.5; what do you guys use? jbrundt Electric Sailplanes 8 Mar 23, 2002 09:08 PM
