Old Oct 01, 2011, 07:12 PM
pimbo is offline
Find More Posts by pimbo
Joined Oct 2011
Help!
Pro boat stiletto 29 cooling water
I have just got a pro boat stiletto 29 and I am unable to get the cooling water to pump through the motor and speedy, has anyone had this problem and how do I overcome this ?
pimbo is offline Find More Posts by pimbo
Old Oct 01, 2011, 08:29 PM
ccpardue is offline
Find More Posts by ccpardue
Speed FREAK!
United States, GA, Augusta
Joined Apr 2011
Edit...
Just realized what motor was on the stiletto...
ccpardue is offline Find More Posts by ccpardue
Old Oct 01, 2011, 09:39 PM
ron1950 is offline
Find More Posts by ron1950
ron1950's Avatar
United States, MS, Brandon
Joined Jun 2011
u might have a blockage somewhere....try blowing through the line if it wont go through all the way to the water outlet check the esc it is sometimes what is blocked....
ron1950 is offline Find More Posts by ron1950
Old Oct 01, 2011, 09:55 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Check for blocked lines, and also see if they're bent and kinked.
wparsons is offline Find More Posts by wparsons
Old Oct 02, 2011, 01:12 AM
pimbo is offline
Joined Oct 2011
I have blown out the line and it is not blocked !
Old Oct 02, 2011, 07:49 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
How do you know it isn't pumping through? Is the pickup itself blocked?
Old Oct 03, 2011, 01:01 PM
kmacva is offline
Find More Posts by kmacva
kmacva's Avatar
Hampton Virginia
Joined Feb 2005
I would put everything together the way it would be when you're getting ready to run it. Then take a garden hose with a nozzle on and place it where the water pickup is and see if the water flows out the exit. If it has two pickups on the rudder like my boat has just put your finger over the other outlet. I do this after every run on my boat to flush the cooling system since I run in brackish water, also works to make sure I didn't pick up any trash that might have blocked the cooling system.
kmacva is offline Find More Posts by kmacva
Discussion Pro Boat Stiletto and DX3S giddyuperic Racing Boats - Electric 53 Oct 25, 2012 11:26 AM
Discussion Pro-Boat Runabout Chris Craft and water cooling? Bernhard BB Dock Talk 24 Mar 18, 2012 10:05 PM
Discussion Pro Boat Review - Mystic 29 Darin Jordan Racing Boats - Electric 2 Sep 26, 2011 02:32 PM
For Sale Pro Boat Stiletto heli123 Boats (FS/W) 6 Jan 11, 2011 08:47 PM
Question Boat ESC in plane? air cooling through fuel line like water cooling? flythreedee 3D Flying 7 Apr 01, 2010 01:40 PM
