This thread is privately moderated by sid.huang, who may elect to delete unwanted replies.
Old Jan 06, 2012, 06:29 PM
Avenger GBU-1H is offline
Find More Posts by Avenger GBU-1H
Avenger GBU-1H's Avatar
Acworth, GA
Joined Mar 2007
5V feed and inverted PPM?
Sid,
I have been following your thread and I am VERY interested in your Rangelink product. I hope to be using my JR 9303 2.4 Ghz 9-channell TX to feed the PPM to the Rangelink unit. It is my understanding that many different models of JR/Spektrum transmitters can be modified to produce a 5v inverted signal through the trainer port.
Question: Will the Rangelink accept an inverted 5V PPM signal? I have been following the JR9303 Mod on another group here:
http://fpvlab.com/forums/showthread....-PPM-mod/page3
Please let me know if this will work.
Avenger GBU-1H is offline Find More Posts by Avenger GBU-1H
Old Jan 06, 2012, 06:57 PM
sid.huang is offline
Find More Posts by sid.huang
Chinglish-funny
Joined Mar 2011
yes,check first post:
7: Compatibility: RangeLink can work with any popular 4-12 Channel radio in the market, and it does not matter if the PPM signal is positive or negative! (Plans to make rangelink works with Futaba radio 12ch ppm mode)
Sid
sid.huang is offline Find More Posts by sid.huang
Old Jan 07, 2012, 05:52 AM
Acworth, GA
Joined Mar 2007
Sid,
I am getting together my order, but was curious about the USB2TTL (CP2102). Is this used for programming? Please advise.
Old Jan 07, 2012, 07:12 AM
Chinglish-funny
Joined Mar 2011
yes, it can be used for rangelink fw upgrade, if u have ,so it no need more.
Sid
Old Jan 12, 2012, 08:30 PM
hairbag is offline
Find More Posts by hairbag
hairbag's Avatar
Joined Oct 2010
are there firmware updates available? where will we get them when they are?
hairbag is offline Find More Posts by hairbag
Old Jan 13, 2012, 08:00 AM
Chinglish-funny
Joined Mar 2011
After chinese new year.. start modify the fw.
BTW your 7C cannt works at 12ch ppm mode.
http://www.futaba-rc.com/systems/feature-compare.html
8FG,12FG,12Z,14MZ Serial type radio support 12ch ppm mode.
Just i think the T8FG would be great, low price. ^_^
Old Feb 01, 2012, 01:31 AM
crazy1pilot is offline
Find More Posts by crazy1pilot
What goes up, must come down
crazy1pilot's Avatar
United States, MI, Midland
Joined Sep 2009
when will you be receiving more stock of the RangLink Set?
also is this system pretty consistent at 16km LOS? i don't believe i am in too bad of an RF environment.
Crazy1
crazy1pilot is offline Find More Posts by crazy1pilot
Old Feb 01, 2012, 07:58 AM
Chinglish-funny
Joined Mar 2011
will back in stock soon, mate.
about the range ,i dont know how to answer, because it really depend to your rf environment...
Old Feb 10, 2012, 06:10 AM
mmormota is online now
Find More Posts by mmormota
mmormota's Avatar
Budapest
Joined Jul 2003
A slow serial uplink (surface to aeroplane) would be very useful for autopilot controlled UAV flight. For example in-flight waypoint modifications etc.
Do you have a plan making such a firmware version? Can't be too complicated, the Tx already has the serial input, and even a very slow baudrate is acceptable. This is something the competition misses - so it should make your system first choice for the UAV fan.
mmormota is online now Find More Posts by mmormota
Old Feb 10, 2012, 07:27 AM
Chinglish-funny
Joined Mar 2011
Hi, Thanks for your attention, I know what you means, I can make a fw for this special application. but not now. so many work need to do...
BTW, UAV need a license. fans???
Sid
Old Feb 12, 2012, 10:18 AM
hairbag is offline
hairbag's Avatar
Joined Oct 2010
just got a new futaba 8 FG and the plug and play cables i got do not work with this transmitter either.
will you be sending out working replacements Sid?
Old Feb 12, 2012, 05:59 PM
Chinglish-funny
Joined Mar 2011
Confirmed,that pnp cable for futaba (i sell to you),is right.
for T8FG,
http://www.rcgroups.com/forums/showp...&postcount=361
On the trainer port , weak signal out, so you need open the tx,and remove the two diodes
make sure the t8fg works at 8 ch ppm mode.
Sid
Old Feb 12, 2012, 06:08 PM
hairbag is offline
hairbag's Avatar
Joined Oct 2010
do you have a link with pictures of the two diodes that have to be removed?
Old Feb 12, 2012, 06:09 PM
Chinglish-funny
Joined Mar 2011
open the link, download the weak.pdf.
Old Feb 13, 2012, 06:00 AM
hairbag is offline
hairbag's Avatar
Joined Oct 2010
thanks Sid... i will pull these out today and hopefully all will be good.
Discussion Hawk Sky!Upgrading the Tx/Rx? Dakine48 Beginner Training Area (Aircraft-Electric) 9 Sep 22, 2011 08:45 AM
Discussion Upgrading from esky nano, going 6ch cp sgt.smith Beginner Training Area (Heli-Electric) 17 Sep 16, 2011 12:14 AM
Discussion help with upgrading plane from amazon.com speedyAK Beginner Training Area (Aircraft-Electric) 3 Aug 14, 2011 01:55 PM
Discussion Upgrading from MCX duncan749 Electric Heli Talk 12 Jul 29, 2011 05:26 PM
Discussion Thomas's LRS now available from TrueRC Canada! Hugeone FPV Talk 14 Mar 23, 2010 10:01 AM
