Espritmodel.com Heli Air
Old Sep 30, 2011, 04:36 AM
Joined Sep 2011
RC kits for experimenting with flight control systems
Hi all,
I'm currently looking for a RC model kit which has been designed specifically for testing and experimenting with flight control systems. Whether it comes with components / modules, or has the capacity to have PCBs attached doesn't matter too much - just that you can actually do it. I would even be interested in kits with come with components for flight control systems - altometer, air speed inertial reference, gps, etc.
Anyone know of anything like this?
SubZer0 is offline Find More Posts by SubZer0
Old Sep 30, 2011, 07:37 PM
"Unnecessary Necessity"
coriolan's Avatar
Canada, BC, Vancouver
Joined Sep 2006
The market would be very small for such a specialized model, almost any model can be equiped with such thing if desired and if large enough to accomodate the extra weight. Electric would be simpler than IC and some experience with models flying would help. Not a good first project!
coriolan is offline Find More Posts by coriolan
Old Sep 30, 2011, 09:34 PM
Joined Sep 2011
Hi Coriolan,
I have experience in firmware development and microcontrollers, therefore, I basically wanted an existing airframe which I could develop the hardware with. Any existing airframe capable of placing several controllers on a PCB or prototype board would suffice. Preferably the kit would allow simple control of the flight control surfaces, and engine speed.
Old Oct 01, 2011, 08:10 AM
Haifa, Israel
Joined Nov 2009
Any kit which requires that you use your own radio would do that. The signals between the receiver and the servos and ESC are pretty standard and it's easy to intercept or generate these signals by firmware. You need to use a microcontroller that has enough IO pins to handle them all.
You want to have a model that's big enough to carry your electronics, with large openings for easy maintenance.
itai n is offline Find More Posts by itai n
Old Oct 01, 2011, 09:22 AM
Florida
Joined Aug 2004
There are a number of models that can carry the weight and equipment you are talking about, a couple would be the Telemaster or the large Kaydet.
Rodney is offline Find More Posts by Rodney
Old Oct 10, 2011, 12:36 AM
Joined Sep 2011
Thanks for the replies, everyone. The Telemaster looks like a good choice, but are there smaller, cheap aircraft that will carry smaller components as well, so that I can easily sacrifice them, and not lose a bucketload of money?
Anything that could carry from a couple hundreg grams to 500 grams...
Old Oct 10, 2011, 07:00 AM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Look at any number of cheap foam sailplanes..
..a
Old Oct 10, 2011, 01:45 PM
Haifa, Israel
Joined Nov 2009
..a
The fuselage of most cheap foam sailplanes hardly have any room for a payload. They tend to be too narrow and with walls that are too thick. Also 200-500 grams on a small sailplane may be too much.
I would look for a sailplane with fiberglass or ABS fuselage and a wingspan of 170cm or more.
Another option - seen on HobbyKing site a category for FPV models. These are supposed to carry a video camera and transmitter so I assume they would be capable of carrying other electronics as well.
Old Oct 10, 2011, 07:47 PM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
He specifically asked:
I add 12oz of ballast (steel rod in the wing joiner) to my Radian when the wind is bad.
..a
Old Oct 11, 2011, 03:28 PM
Haifa, Israel
Joined Nov 2009
I agree that a sailplane is a good choice. I just say that foam-fuselage sailplanes rarely have enough room to carry a payload. That's why I suggest to look at fiberglass or ABS that are usually wider with thinner walls.
Can you give some dimension of the Radian? If you wanted to add an electronics board of a 2"x3" size where would you put it?
Old Oct 11, 2011, 04:10 PM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Under the canopy. Tons of room there.
You could also just strap an ABS enclosure to the fuselage, above the wing. Many fly with GoPro camera's hanging off the top, for example..
..a
Old Oct 12, 2011, 08:58 AM
Nederland, LI, Herkenbosch
Joined Jul 2011
http://www.hobbyking.com/hobbyking/s...R_C_Plane.html
Aliander is offline Find More Posts by Aliander
Discussion Control rc plane over internet with 3G CDMintA2000 450MHZ zkilzz Radios 0 Sep 11, 2011 04:07 PM
For Sale free flight and control line model kits for sale kenny e Aircraft - General - Miscellaneous (FS/W) 5 Aug 26, 2011 12:23 PM
Discussion flight control systems nickwad Multirotor Talk 5 Jun 09, 2011 01:04 PM
Discussion Do GWS Kits with brushed power systems include ESC? 87knox GWS (Grand Wing Servo) 6 May 26, 2011 07:18 PM
