Old Sep 29, 2011, 08:03 PM
pilotrcuk is offline
Find More Posts by pilotrcuk
Soggy Scotland
pilotrcuk's Avatar
Central Scotland
Joined Jun 2004
Habu 32
Span: 1.03cm
Length: 1.25cm
HK VJ
Span: 1.25m
Length: 1.25m
pilotrcuk is offline Find More Posts by pilotrcuk
Old Sep 29, 2011, 08:21 PM
Gaz-b is offline
Find More Posts by Gaz-b
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
Originally Posted by vettster View Post
The fiberglass for the nose gear needs to be cut out. Thats fine, as that will obviously become the door. I will be adding doors to the main gear aswell.
No cutting gear doors for me
Gaz-b is offline Find More Posts by Gaz-b
Old Sep 29, 2011, 08:33 PM
vettster is offline
Find More Posts by vettster
Canada, ON, Beeton
Joined Aug 2008
I have to agree Gaz. I am a long time NON-beleiver in gear on EDF, but this sucker is so big, it just screams for gear.
BTW.. There are no pockets for the elevator servos in the Hor stabs. There is also no holes in the fuse to run push rods. You will have to be creative. Luckely, I ran into this situation with the HK 70mm version. Here's how I did it.
vettster is offline Find More Posts by vettster
Old Sep 29, 2011, 08:36 PM
Gaz-b is offline
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
Exactly what I have planed I have studied all the pics quite closely
Old Sep 29, 2011, 08:39 PM
Soggy Scotland
pilotrcuk's Avatar
Central Scotland
Joined Jun 2004
LOL, just read your review on the HK site for this!!
On my SAPAC Viper, it used pushrods to an ele servo - ele & rudd servos were mounted on a ply tray installed between the intake ducting, just behind the canopy. There's every chance this kit is based on the SAPAC model so strange they haven't fitted pushrods/exits in the fuz per that design.
I'm a fan of direct linkages though so might consider letting them into the surfaces too, will see how the balance goes as I build.
Old Sep 29, 2011, 08:40 PM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
Hey V !!!!1
I remember from the intro video that Scott said that it had dual elevator servo on the stab.
it's worth checking to see if their is a perforation or cut-out under the covering. J
jayb1rdz is offline Find More Posts by jayb1rdz
Old Sep 29, 2011, 08:42 PM
vettster is offline
Canada, ON, Beeton
Joined Aug 2008
Good stuff! Then your next question should be... What is the dimention of the Hor stab at the root, so I can select a servo that will fit? Whell! Since you asked Gaz Its 15mm exact. Remember to leave some fudge room. So your looking at around 12.5mm-ish.
Old Sep 29, 2011, 08:44 PM
vettster is offline
Canada, ON, Beeton
Joined Aug 2008
Originally Posted by jayb1rdz View Post
Hey V !!!!1
He lied
I checked thoroughly. Theres only one pocket for the rudder.
Old Sep 29, 2011, 08:45 PM
Gaz-b is offline
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
yep got loads of 12mm thick metal geared digis ready
Old Sep 29, 2011, 08:51 PM
jayb1rdz is offline
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
So the build is the same as the jet teng VJ on the H-stabs. I'm glad you are doing this first. You should be ready to maiden on the weekend ?
Old Sep 29, 2011, 08:54 PM
Soggy Scotland
pilotrcuk's Avatar
Central Scotland
Joined Jun 2004
I like this setup for the ele servos in the JT VJ:
http://www.rcgroups.com/forums/attac...mentid=4294634
Old Sep 29, 2011, 08:57 PM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
Originally Posted by pilotrcuk View Post
Habu 32
Span: 1.03cm
Length: 1.25cm
HK VJ
Span: 1.25m
Length: 1.25m
Dang! I didnt know the Habu 32 was so small. They running a 2mm or 3mm fan in that one?
Sorry, Im a smartass, I couldnt resist. Back to the build!
scatsob is offline Find More Posts by scatsob
vettster is offline
Canada, ON, Beeton
Joined Aug 2008
You bettcha! but, what weekend are we talking about
So they Clearly Copied me Does anyone have the # to a good Lawyer
What am I saying?.....is there even such a thing as a "good Lawyer"
Old Sep 29, 2011, 09:00 PM
Soggy Scotland
pilotrcuk's Avatar
Central Scotland
Joined Jun 2004
LOL, looked like you build the servos into the tails, then cut pockets in the fuz, whereas the JT has the servos mounted to the fuz - maybe an easier mod that way? TBH I prefer driving a control surface from the middle, but I'm sure this'll be just fine.
Old Sep 29, 2011, 09:01 PM
vettster is offline
Canada, ON, Beeton
Joined Aug 2008
Yup.. someone needs to work on the metric system.
sorry Pilot..
New Product New HobbyKing Viper Jet 70mm Fibreglass Jet Jagzilla Electric Ducted Fan Jet Talk 1554 Nov 23, 2015 04:17 PM
Wanted SAPAC Viper Jet 70MM ZACATTACK Aircraft - Electric - Jets (FS/W) 4 Oct 04, 2011 04:39 PM
Discussion Hobbyking 90mm viperjet Gaz-b Electric Ducted Fan Jet Talk 29 Sep 29, 2011 08:13 PM
Cool New 90MM Viper, 90MM Hawk and G500 CRCJA Electric Ducted Fan Jet Talk 2 Aug 18, 2011 06:38 AM
Discussion Has anyone seen the Hobbyking Viper Jet? joe_crash Electric Ducted Fan Jet Talk 2 May 03, 2011 05:07 PM
