Old Jan 10, 2013, 03:08 AM
fooyukvoon is offline
Find More Posts by fooyukvoon
The Need4Speed
fooyukvoon's Avatar
Malaysia, Perak, Ipoh
Joined Aug 2008
Originally Posted by Downwind3Zero View Post
Haven't flown yet. Most of the problems with the early kits have been solved (paint flaking, cutouts for elevator servos).
Chris
Is yours a newer version? Can you post some pic?
Thanks.
fooyukvoon is offline Find More Posts by fooyukvoon
Old Jan 10, 2013, 07:28 AM
Issus is offline
Find More Posts by Issus
Issus's Avatar
Joined May 2012
i'm looking at building one of these for FPV, I think i've figured out all the parts required. I'd love some comments on my parts list:
https://docs.google.com/spreadsheet/...F9lYWhtT2JOc0E
Most of it's from hobbyking as that is the easiest/cheapest place I know for most of the little bits and pieces. Locally is just too damn expensive (Would double the price of this plane easily.)
Specifically:
How will the plane go with the 6000mah 6s?
Will the Mercury Alloy 12 blade 90mm 1900kv EDF unit fit the aircraft?
Anyone have any idea of what top speed can be expected?
Issus is offline Find More Posts by Issus
Old Jan 10, 2013, 09:48 AM
Downwind3Zero is offline
Find More Posts by Downwind3Zero
It's like an addiction!
Downwind3Zero's Avatar
NY, Rochester
Joined Oct 2003
Jets typically don't lend themselves very well to FPV due to the speed.
The Mercury will fit. Speed likely 100-120 mph on good 6S.
@foo: I'll post some pics.
Chris
Downwind3Zero is offline Find More Posts by Downwind3Zero
Old Jan 10, 2013, 08:15 PM
The Need4Speed
fooyukvoon's Avatar
Joined Aug 2008
Thanks..
Old Jan 10, 2013, 08:52 PM
Issus is offline
Issus's Avatar
Joined May 2012
Chris
Hmm, well that's slower than I was hoping. Not bad though I guess for 6S.
The fastest I've fpved is 295km/h. I've been doing this since 2008, my first FPV plane was a massively overpowered F-27 Stryker I'm getting bored of flying far and high again, getting bored of helicopters, so now I want something for fast and low again - it's been 2-3 years since I've had something properly fast (over 150km/h)
I might have to get some larger 4S batteries to make some 8s packs out of (can always use 4s by themselves!)
One of my clients (I work in the R/C industry as an electronic design consultant) purchased the jet and fan for me because i was complaining about being bored with gliders.
Now I just need to get the other bits and pieces - most of the FPV gear I already have lying around as with many of the other parts. Servos is going to be the big expense and the ESC.
Old Jan 11, 2013, 04:36 AM
NY, Rochester
Joined Oct 2003
OK well then speed wont be an issue
This would actually be over 150km/h as I quoted in mph.
Old Jan 11, 2013, 06:57 AM
Issus is offline
Issus's Avatar
Joined May 2012
Sounds good! I switched my ESC choice to a Kforce 120A HV, so I have the option of 8S if I want more. My friend and I fly 850W bixlers, and 1200W Easygliders... so I'm guessing that more is going to be the order of the day, "because we can."
I may order some of the parts this weekend.. do the servos I have in my spreadsheet (for convenience: https://docs.google.com/a/rris.com.a...tT2JOc0E#gid=0) look like a good choice? I have most of the other parts lying around - just need the servo and esc.
Old Jan 11, 2013, 07:06 AM
NY, Rochester
Joined Oct 2003
I looked over your spreadsheet - impressive!
I would probably go with something stronger for the flaps but other than that it looks OK.
Old Jan 11, 2013, 07:19 AM
Issus is offline
Issus's Avatar
Joined May 2012
Thanks, you're right - that is a bit pathetic, how about:
http://www.hobbyking.com/hobbyking/s...sec_22_5g.html
BMS-390DMH High Performance Digital Servo (Extra Strong) 5.4kg / .11sec / 22.5g
Old Jan 11, 2013, 07:54 AM
NY, Rochester
Joined Oct 2003
I haven't used those but the numbers look better! I always build above specs, but thats just me, I dont like stuff to fail.
Old Jan 11, 2013, 08:41 AM
Issus is offline
Issus's Avatar
Joined May 2012
I completely agree. Failure in flight is far far more expensive than doing it right the first time. An extra $7 per servo vs $2000 of onboard equipment and airframe... seems an easy choice to me.
Old Jan 12, 2013, 03:05 PM
NY, Rochester
Joined Oct 2003
Here is an example of the preexisting cutouts.
Old Jan 14, 2013, 02:10 AM
The Need4Speed
fooyukvoon's Avatar
Joined Aug 2008
Downwind3zero,
Where did you get that retract from? Got a link?
Thanks.
Old Jan 14, 2013, 04:06 AM
NY, Rochester
Joined Oct 2003
Tamjets, custom made.
Old Jan 14, 2013, 08:13 AM
420flyboy is offline
Find More Posts by 420flyboy
Mile High EDF
420flyboy's Avatar
United States, CO, Denver
Joined Jul 2011
Originally Posted by fooyukvoon View Post
Downwind3zero,
Thanks.
Here you go , Tam makes multiple sizes
http://www.tamjets.com/original/inde...4362dd2dbc08c9
420flyboy is offline Find More Posts by 420flyboy
New Product New HobbyKing Viper Jet 70mm Fibreglass Jet Jagzilla Electric Ducted Fan Jet Talk 1554 Nov 23, 2015 03:17 PM
Wanted SAPAC Viper Jet 70MM ZACATTACK Aircraft - Electric - Jets (FS/W) 4 Oct 04, 2011 03:39 PM
Discussion Hobbyking 90mm viperjet Gaz-b Electric Ducted Fan Jet Talk 29 Sep 29, 2011 07:13 PM
Cool New 90MM Viper, 90MM Hawk and G500 CRCJA Electric Ducted Fan Jet Talk 2 Aug 18, 2011 05:38 AM
Discussion Has anyone seen the Hobbyking Viper Jet? joe_crash Electric Ducted Fan Jet Talk 2 May 03, 2011 04:07 PM
