Old Mar 13, 2012, 05:40 PM
heliclown is offline
Find More Posts by heliclown
Australia, NSW, Hillsborough
Joined Feb 2008
Fastest viper
Hey Fellas
Sorry to ask this question, its probably been asked many time s in this thread, but there is so much to sift thru.
What is the fastest speed ( doplar or radar) the HK viper has reached up to date, and what is the setup?
Also, are the wings detachable for transport?
Steve F
heliclown is offline Find More Posts by heliclown
Old Mar 13, 2012, 07:49 PM
bobbit4447 is offline
Find More Posts by bobbit4447
Fly it like you stole it !
bobbit4447's Avatar
Australia, QLD, Coolum Beach
Joined Oct 2011
Originally Posted by heliclown View Post
Hey Fellas
Steve F
Early days yet....12S stuff in the pipeline...check the last few pages.
Wings detachable but you have to provide means of securing...there is a couple of methods explained in this thread.
B
bobbit4447 is offline Find More Posts by bobbit4447
Old Mar 13, 2012, 11:07 PM
420flyboy is offline
Find More Posts by 420flyboy
Mile High EDF
420flyboy's Avatar
United States, CO, Denver
Joined Jul 2011
Here it is ready to fly
new configuration on the lipos , split them apart and Velcro-ed them to the walls. Maiden will have to be with 2650mah 6s x 2 nano tech.
420flyboy is offline Find More Posts by 420flyboy
Old Mar 14, 2012, 03:15 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
why do you need 2 life packs?
and what's your overall weight? Ive got those struts too but I realised they are too soft. have you modded them?
pavcon is offline Find More Posts by pavcon
Old Mar 14, 2012, 08:05 AM
Mile High EDF
420flyboy's Avatar
Joined Jul 2011
Using the 2 life packs as balance weight, 1100mah for flight controls and 700mah for speed sensor. I still need to get a scale , as I have no idea what it weighs. I know it's a lot less than the 2 5000mah 6s .
As for the struts,
I'm using the dsr-a from HK on the mains, stock springs are very stiff and keep from bottoming out, even bounce back up when pushed down. The Nose strut is also HK struts, there cheap ones, just using the front is all, I put the wheels from the original rears on the front strut as they are bigger mm . The front strut that came with the dsr has a very weak spring. I also took the wheels from a habu 32 , which are made from rubber and look very nice and put them on the mains in place of the cheap foam tires that came with the dsr struts.
Old Mar 14, 2012, 04:05 PM
vettster is offline
Find More Posts by vettster
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
I hope your next post will be a successful maiden flight video.
Good luck!
vettster is offline Find More Posts by vettster
Old Mar 14, 2012, 05:14 PM
Corelli is offline
Find More Posts by Corelli
Corelli's Avatar
United States, NM, Farmington
Joined Jun 2008
Huge thread. Nice looking builds.Couldnt read the whole thing. Does HK still sell this 90mm version? If so anyone got a link?
Steve
Corelli is offline Find More Posts by Corelli
Old Mar 14, 2012, 05:47 PM
pavcon is offline
Joined Jan 2010
HEre is the fan unit that I just got..
isn't she a beauty?
Old Mar 14, 2012, 06:09 PM
Mile High EDF
420flyboy's Avatar
Joined Jul 2011
isn't she a beauty?
That sure is a fine piece of craftsmanship , can't wait for your maiden
Link to jet
http://www.hobbyking.com/hobbyking/s...dProduct=15536
Old Mar 14, 2012, 06:13 PM
bobbit4447's Avatar
Joined Oct 2011
isn't she a beauty?
Thats sweet....its not just the best rum and motor cars Auzzies make, but also....
Your going to have to enlarge that hatch on that Viper big time to get that mother in, if thats a problem you can just send it to me.
B
Old Mar 15, 2012, 02:43 AM
pavcon is offline
Joined Jan 2010
B
i think i will find a way B. Thanks for the offer :.. Lol
I will split the fuse in half if i have to but i WILL get this fun up and running in this plane. 4000watts and 5.3kgs of thrust and thats with inferior than my 65c nanotech batts...i just hope to get that thrust in the fuse too...
Old Mar 15, 2012, 09:21 PM
choopi is offline
Find More Posts by choopi
choopi's Avatar
New Brunswick
Joined Feb 2006
I got mine finally done, mostly. After changing my plan for the gear it all went smooth from there. I just decided to go with Vettster and get done with it! 10s, 9305 fan with typhoon 1400kv. I'm at 6.5 lbs, with my batteries I should be at max 7.5lbs.
choopi is offline Find More Posts by choopi
Old Mar 15, 2012, 10:42 PM
Rocketboy1030 is offline
Find More Posts by Rocketboy1030
Rocketboy1030's Avatar
Canada, ON, Mississauga
Joined Nov 2011
I am going to test this one out at Maidenfest on April 21st . I am at 2.8 KG without batteries. HobbyKing cockpit adds about 200gms . I am using the CS 12 Blade with the HET 700-60-1865 KV on 8s.With 2 4000 40C 4s Batteries I am at 3,825 gms . The amp draw is high, but the blast out of the thrust tube is awesome!
I am going to belly land , has anyone figured out a good protective guard for the servos/flaps ?
Rocketboy1030 is offline Find More Posts by Rocketboy1030
Old Mar 15, 2012, 11:01 PM
pavcon is offline
Joined Jan 2010
where is the woman pilot???
Old Mar 15, 2012, 11:13 PM
Mile High EDF
420flyboy's Avatar
Joined Jul 2011
I want your batteries
How are you going to only add 1 lb of weight on a 10s ? You say from 6.5 to 7.5 with batteries. Each of those 5s packs is going to weigh about a pound at least. I'm running 12s , 3300mah packs , 522 grams each , that adds on about 2.5 lbs to my empty weight.
Finally weighed mine at just under 9 lbs with lipos, thrust 10-11 lbs range
New Product New HobbyKing Viper Jet 70mm Fibreglass Jet Jagzilla Electric Ducted Fan Jet Talk 1577 Jun 06, 2016 08:52 AM
Wanted SAPAC Viper Jet 70MM ZACATTACK Aircraft - Electric - Jets (FS/W) 4 Oct 04, 2011 03:39 PM
Discussion Hobbyking 90mm viperjet Gaz-b Electric Ducted Fan Jet Talk 29 Sep 29, 2011 07:13 PM
Cool New 90MM Viper, 90MM Hawk and G500 CRCJA Electric Ducted Fan Jet Talk 2 Aug 18, 2011 05:38 AM
Discussion Has anyone seen the Hobbyking Viper Jet? joe_crash Electric Ducted Fan Jet Talk 2 May 03, 2011 04:07 PM
