Old Jan 14, 2012, 12:54 PM
420flyboy is offline
Find More Posts by 420flyboy
Mile High EDF
420flyboy's Avatar
United States, CO, Denver
Joined Jul 2011
Originally Posted by vettster View Post
Reminds me of someone I know
Youll find that the bigger they get the better they fly.
That's what's I want to hear , just costs more lol
420flyboy is offline Find More Posts by 420flyboy
Old Jan 15, 2012, 04:15 PM
bobbit4447 is offline
Find More Posts by bobbit4447
Fly it like you stole it !
bobbit4447's Avatar
Australia, QLD, Coolum Beach
Joined Oct 2011
This may be an answer to get changesun retracts operating on Futaba non-programmeable channels (ie 9 & 10 on 10CAP tx )
Anyone tried?
B
http://www.modelradioworkshop.co.uk/...-expander.html
bobbit4447 is offline Find More Posts by bobbit4447
Old Jan 16, 2012, 04:44 AM
albatross_cris is offline
Find More Posts by albatross_cris
albatross_cris's Avatar
Palermo
Joined Sep 2008
Struts
Originally Posted by bobbit4447 View Post
OK nose gear done..pretty conventional, just a few comments.
Strut Type PD25... on hindsight there are bigger/better available.
Strut Pin Ex 5mm electric motor shaft c/w circlip & brass washer. Clip sits in recess in Changesun trunion. Pin was high tensile steel, needed to be ground (not regular lathe tool) in lathe to fit strut (4mm)
Steering Pull/pull 20kg fishing trace, tensioned with 2.5mm whipper snipper nylon heat shrunk to wires. Keeps pull/pull wires clear when retracting.
Now to get on fitting the EDF..oh I wish the intake tubes were removable like the HK Hawk.
Bob
stanordave
PS I got mine at 6AM Aus time..sold out in a coupla hours....as my granny used to say the early bird gets the worm
HI,
can you tell me where I can buy this front strut?
tks
Cristiano
albatross_cris is offline Find More Posts by albatross_cris
Old Jan 16, 2012, 09:08 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
Originally Posted by albatross_cris View Post
HI,
tks
Cristiano
its a set. you can't buy it separately. Search for 7075 alloy struts in hobbyking.
Windrider and x-flight also sells them
pavcon is offline Find More Posts by pavcon
Old Jan 16, 2012, 11:29 AM
Mile High EDF
420flyboy's Avatar
Joined Jul 2011
Originally Posted by 420flyboy View Post
Thinking an Arc 1680kv 36mm motor,
I can't wait, should ship next week , this will be the biggest plane I have ever flown. Not bad for a guy who couldn't fly a little over a year ago. I tried small planes , but once I found edf's and the speed it became all clear
I went with the typhoon 1680kv motor , should put out good power
Old Jan 16, 2012, 02:54 PM
vettster is offline
Find More Posts by vettster
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
Thats the same Kv as my ARC motor. I run it on 8s with a HET fan and get 2700Wp at about 80amp if recall correctly. I also go as high as 10s. Make sure you buy a bigger esc for the times when you want to add extra cells. I use the Turnagy 120hv opto. Its as solid as they come.
vettster is offline Find More Posts by vettster
Old Jan 16, 2012, 02:59 PM
pavcon is offline
Joined Jan 2010
well.. with my Typhoon 1500kv on het fan on 8s I got almost 2700watts on some good 65c nanotechs.. 84-87 amps amp draw (can't really recall the exact numbr)
the 1680 will certainly do around 3000 or more on 8sit's cheaper than the arc
Old Jan 16, 2012, 03:07 PM
vettster is offline
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
When I got those numbers I was using 25-50C nanos. So I would say there the same. I wasnt making a pissing competition out of it. I was just saying
Old Jan 16, 2012, 03:19 PM
pavcon is offline
Joined Jan 2010
I'm just saying there is no reason to pay arc or neu when HET have some very equivalent motors
that were also pushed at 4kw with no probs
Old Jan 16, 2012, 03:43 PM
vettster is offline
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
I would say that ARC is slightly higher in price because they use Titanium bearings. Believe me...Im a big supporter of HET. I love all there products. I only posted to give 420 an idea of the power he will be looking at since he's new to this size of edf
Old Jan 16, 2012, 03:54 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
the Arc motor are the same cost as Het motors, the one you guys are talking about the 1680kv I give the edge to Het because its a bigger motor and will handle more power better and thus transfer more watts to shaft power. they are both great motors but one is 36mm can and the other is 40mm so they are diff, by the way we just fired up our new Arc 3675-1 1680 motor in an Extreme Alloy wemo fan and after maybe 10mins of total run time balancing and such it has a bad bearing in it and has to be sent back.... sucks!
jcdfrd is offline Find More Posts by jcdfrd
Old Jan 16, 2012, 03:55 PM
pavcon is offline
Joined Jan 2010
you can lub yours and have them for a lifetime I thin you can agree with that .. I lubricate mine once every .. every time I'm not bored actually which is once every 5 months :P
Old Jan 16, 2012, 05:49 PM
Mile High EDF
420flyboy's Avatar
Joined Jul 2011
Got the message that the motor shipped. This will be my first het motor, looking at fitting it in the change sun 90mm 12 blade unit. Think your right about the esc, I'm going with a castle 120hv .
Old Jan 16, 2012, 06:01 PM
pavcon is offline
Joined Jan 2010
have they shipped out the hv2 yet?
Old Jan 16, 2012, 07:49 PM
Mile High EDF
420flyboy's Avatar
Joined Jul 2011
I guess they did, I have one coming. I didn't buy it from castle, got it from a online dealer.
New Product New HobbyKing Viper Jet 70mm Fibreglass Jet Jagzilla Electric Ducted Fan Jet Talk 1577 Jun 06, 2016 08:52 AM
Wanted SAPAC Viper Jet 70MM ZACATTACK Aircraft - Electric - Jets (FS/W) 4 Oct 04, 2011 03:39 PM
Discussion Hobbyking 90mm viperjet Gaz-b Electric Ducted Fan Jet Talk 29 Sep 29, 2011 07:13 PM
Cool New 90MM Viper, 90MM Hawk and G500 CRCJA Electric Ducted Fan Jet Talk 2 Aug 18, 2011 05:38 AM
Discussion Has anyone seen the Hobbyking Viper Jet? joe_crash Electric Ducted Fan Jet Talk 2 May 03, 2011 04:07 PM
