From the Park 250 Manual:
I also recommend you use a drill press to press out the shaft. You can use a drill bit slightly smaller than the shaft and installed upside down in the chuck as a 'drift pin'. The shaft can be quite tight so be patient. I would also check out the L-4 Grasshopper thread: http://www.rcgroups.com/forums/showthread.php?t=1112900 And some of the Park 250 shaft reversal threads: http://www.rcgroups.com/forums/showthread.php?t=1222246 |
Scorpion has a nice shaft replacement video.
The process is similar for many motors. It'll give you a good idea of the correct way to perform shaft replacement which is similar to what you would do on a reversal. |
USA, ME, Ellsworth
Joined May 2008
It is normal for the shaft to be a sliding fit in the inner races of the bearings and a press fit into the magnet housing. The best way to get a pressed in shaft out is to:
1 - remove the grub screws 2 - Find a deep socket wrench or piece of tubing that will go up into the magnet housing so that it will support the housing as close to the shaft as possible. It should be just a little larger than the shaft and long enough that the shaft can be pressed down into it. 3 - Press the shaft down into the tubing until it falls through. If the shaft is flush with the end of the magnet housing at the start or when it is pressed down flush with the end, put a short cap screw that is smaller than the shaft against the end of the shaft and continue pressing. I usually do the pressing horizontally in a bench vise or vertically on a drill press. If you can find non-ferrous tubing it is easier to use as you don't have the magnets wanting to stick to it. Jack |
United States, IL, Peoria
Joined May 2003
Be careful-there appear to be an older park 250 and newer one -if you try to move shaft in older one the cage collapses and motor is killed..the metal is quite brittle. Me and buddy killed ours- he sent his to horizon and they replaced it no charge as it was new. I have found the Rimfire 250 to be superior in power and friendliness in that model
If I were to do it again, I would just get Ken at Subsonic Planes to set me up with a DM2203-1600 with an extended shaft and prop adapter.
Wait a minute... I just ordered this very same motor for a couple of other planes! Maybe I should just swap one in... |
USA, ME, Ellsworth
Joined May 2008
Doing it that way is specifically intended to localize the pressing forces as close to the shaft as possible and also to avoid putting any pressure on the ends of the magnets where they might be exposed at the open end of the magnet housing. If you have a bent shaft, cut it off close to the end of the magnet housing to get rid of the bent part before you try to press the shaft out. The odds on getting the bend to go through the housing without damaging the housing beyond further use are very small. Then make a new shaft, that is not that hard to do and you either buy a shaft or even get one from a scrap CD or dVD drive. More details here: http://www.rcgroups.com/forums/showthread.php?t=1240725 Jack |
| Thread Tools | |
| Sold Eflite Park 250 & 10A Pro ESC | KKUSA | Aircraft - Electric - Power Systems (FS/W) | 2 | Sep 15, 2011 08:46 AM |
| Discussion Can we move on from choo choo trains now? | plowboy1966 | Life, The Universe, and Politics | 26 | Mar 31, 2011 08:34 PM |
| Sold Eflite Park 250... on crack! $45 shipped | Truglodite | Aircraft - Electric - Power Systems (FS/W) | 6 | Dec 31, 2009 12:13 AM |
| Discussion Can't get Park 250 to run on new 2 cell Tp batts... | Kilo60 | Power Systems | 3 | Jul 21, 2009 12:20 AM |
| Discussion can a Park 370 propshaft be used with a Himax 4100 ? | Nethole | Power Systems | 0 | Jun 21, 2006 06:22 AM |
